| Ufly Walkera Ufly Helicopter Support |
I've seen the Henge 922's mentioned often in the forums.
Has anyone tried any other? Like the Corona or EXI? I've replaced two stock servos in the last two weeks. Look forward to hearing what you think. Thanks |
If you have the uflys it requires that the servo responds to proper servo direction ,as well as gyro direction,that's the problem with Walkera ,you can change servo direction on your tx but gyro reverse is not available so most servos won't work.I've tried the exi213 and the corna 929 and both are gyro reverse,if you fly with the gyro turned off you could use them.The henge is bolt on no mod required and is very fast,I bought from a EBay site because Hobby King took 3 months to arrive!
without a doubt the Henge MD922G are the best servo for the uflys....there faster stronger ball bearing and all metal gears....and only $10 each which is what the stock walkera servo costs....
Thanks for the info. I'm gonna go check ebay right now.
got mine from Hobby King and it took 3 weeks to get here but was well worth the wait in my opinion...
#6 |
Will I need to modify them to make them work? The ones I saw o. Ebay are running about $14 plus shipping. Not much more than stock servos.
#7 |
Bolt on,well worth the money ,you will be impressed with the speed and very durable.Make sure after you install that the extent on all servos doesn't over travel !I cracked the case on my henge tail servo because of servo binding when not adjusted right!
#8 |
only thing i did which was not necessary but i did it anyway was i shortened the servo wires to the same length as the stock servos....but you can just tie the extra wire length down with zip ties in stead....next time i get more i wont bother shortening them cause it was a pain in the rear re-soldiering the pins in the connectors ....
#9 |
Wish I would've bought these instead of the stock set. I orderered 3 today. Hopefully they'll get here before I need them. Thanks for the great advice.
#10 |
werre can i get those sevos Henge MD922G thanks mark
#11 |
