| Atom 7HV Compass Atom 7HV Model Helicopter Discussion |
How 'bout it guys? A 7HV setup thread. I'll start. Please feel welcome to suggest alternatives:
= R To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. b43 = Team Compass Support |
7HV FBL
Stock Motor PunchRC 120HV Esc Stock Blades / 693mm Edge FBL Mikado Vbar Full Size 5.1 Pro Hyperion Phase Sensor Futaba BLS451 @ 8v on Cyclic Outrage Torq BLS9188 @ 8v on Tail Edge 105 Tail Blades Voltz 2500mah RX Pack
Chris D. |
Here's what mine would be like:
- I still haven't tried a Vbar, but if it works as well as they say it does, I would love to try the governor function., otherwise it's BeastX all the way! I've tried a few different machines with the MBX on there and it's an extremely capable and consistant piece of equipment. - Can't say I know anything about the phase sensor, but what the heck...why not? -Super BEC is badass on my 6HV, so it's an obvious choice. - I was torn on the Torq servos -VS- the JR 8917's. I took the Torqs and am not regretting it one bit. They're incredibly quiet and smooth and you definitely can't complain about the torque. The JR's definitely are faster, but paired up to to an FBL unit and they all feel the same (speed-wise anyways [8717's, 610's, Ino-lab 760's, Torq's]). Even if the Torq's aren't the "best" out there, they sure as heck look wickedly awesome!!! The ruby red cases set them well apart from the crowd. - I don't think it gets any better than the 9188 on the tail. At 8V, it's got an incredible amount of torque and ridiculous speed. So far, it's the only tail servo I've found to be as good, if not, better than my 8900G's, plus you can run the 9188 on straight 2S, so no step-downs or other fandangled gear to worry about failing. - KBDD's are kick-butt for sure and I'm digging the heck out of the new EE's. ![]() - I got to rip on some Sky lipos this weekend on my 6HV (3300 40C's) and they are pretty incredible. They already had over 20-30 cycles on them and felt brand-new. Much better than any other battery I've tried so far in my bigger machine(s) so I definitely give them a high vote of confidence. Haven't had a chance to try the Gen Aces yet, so cannot comment.
Tim - Atom 500, 6HV, 3D+, eAurora KBDD TEAM PILOT Compass support/Nankin Hobby.com --Si vis pacem, para bellum-- |
Mine would be pretty much as Tim describes with minor changes:
* 7HV FBL * Stock motor * Punch RC ESC w/programming interface * Mikado V Bar Full Size 5.1 Pro * WR Hercules Super BEC * JR DS8917' * JR 8900G on tail * KBDD 104 t/r blades *JR921 Receiver w/two satellites For batteries I will probably run the Punch R/C batteries. The V-Bar and servos are here and standing by, waiting for the release of the 7HV. In the meantime-practice, practice, practice!
KBDD-Team Pilot Team Compass / ProStar Hobby Gens Ace Field Representative Warp 360, 7HV,Knight Pro,Knight 3D, Atom 500, Odin II, 6HV, 3D Plus, Knight 50 |
Mine will be as follows :
* 7HV FBL * Stock motor * Stock blades * Hobbywing 120A HV ESC * BeastX or CGY 750 * CC BEC Pro with extra reciever pack * Savox 1257 on cyclic * Savox 1290 MG on tail * KBDD 104 t/r blades * Futaba SBUS reciever R6203SB For batteries I will use Turnigy's. And just as Ah Clem eagerly awaiting the release of this beast Grtz, Dirk
The heli virus has infected me and i hope that there is NO CURE !! Compass Support Team __________________________________________________ _____ ATOM 500 FBL (BeastX) / ATOM 6 HV FBL (BeastX) / 7HV FBL (BeastX) / Henseleit TD R |
#6 |
Why the receiver? Just curious
Chris D. |
#7 |
I definitely wouldn't trust satellites only on anything bigger than a 450 or 500. Sure it probably works, but for some it's not worth the risk. $1500+ and upwards of 10lbs-13lbs of angry helicopter flying around deserves much more respect IMHO. Not trying to knock your setup whatsoever Crawl, just saying what his reasonings will undoubtedly be (I know Richard pretty well).
I fly with an AR6200 on my 6HV when most people wouldn't touch that RX with a 10' pole (so I understand where you're coming from at least). I run it on 8.4V, so I'm pushing it that much more than "most" people would consider acceptable. However, the 700 would be a different monster all on its own and I have seen too many sats. fail to trust them 100%.
#8 | |
Chris D. |
#9 | |
My HF Map location Join Date: Jul 2007
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
Richard is talking about using 3 receivers essentially, which I can sort of understand on an airframe the size of a 700. I'd probably still use two satellites, strategically placed.
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Nankin Hobby Field Rep, Compass Support Team Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX Experience is something you obtain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
#10 |
The problem is using BeastX which support only one sat (for heli 250-450). But with vstabi there is no problem about range using 2 sats. Also now that dsmx sats are out i heard that they works really better even if used in dsm2 mode, vstabi seems to log a lot less to none "antenna switch".
I use vstabi from a lot of time since v3.6 and i have used sat since first support release. No problems so far only two times i have to rebind but i think that the weak part of sat is the cable. I have changed it.
Compass 7HV - Vstabi 5.3Pro Trex 600 EFL Pro - MiniVstabi 5.3Pro MiniProtos 3s - MSH Brain |
#11 |
The question was why Richard was using a separate receiver with his VBar instead of just using satellites. I agree that a BeastX on this size of heli warrants a separate receiver, at least until they can get support for a second satellite added.
#12 |
Crawl,
"Why the receiver? Just curious . I went none receiver (just 2 satellites) on both of my Compass ships and it works flawless." I am sure it does and I do not questions your set up either Crawl. Tim said it better than I could have (above). What he described is exactly how I feel about it. "Richard is talking about using 3 receivers essentially, which I can sort of understand on an airframe the size of a 700. I'd probably still use two satellites, strategically placed." Alan nailed it too. I have the main rx and two satellite Rx's on my Odin, and the main Rx and three satellite Rx'x on the Raptor 90 3D (it has a JR1221 Rx in it which allows three satellites). uragano47812, "But with vstabi there is no problem about range using 2 sats." Range is not the issue. Even the "Parkflier" receivers have superb range. The issue is "shadowing" (i.e. a conductive structure of the helicopter-motor, battery, CF side frame, etc.-getting between the signal source (transmitter) and the very small receiver antennae). I try to go overkill on BEC's, receivers, servos, anything that might increase the reliability and safety, even a small amount. I overdo it, and realize that, but considering the amount of damage these machines could do, I would rather err on the side of caution. The fact that I am representing two manufacturers and want to demonstrate their equipment in as positive a light as possible also motivates me towards making sure the machines and electronics are as safe and reliable as possible.
#13 | |
#14 |
Great input, I can certainly understand your reasons!
Chris D. |
#15 |
"Agreed. I wasn't saying that the sats are less capable of receiving and demodulating the signals, but I have had a few of them go belly up on me in flight before"
The cable from the main receiver to the satellites is fragile where the wires enter it. I have had one of these (cables) fail also.
#16 |
Shoe goo works wonders as a strain relief in that case. I have it on some of my sat plugs; I just need to do the rest of them.
#17 |
I should do that too, Alan!
#18 |
I have never dreamed of having this issue. Indeed, I can't say I've not been warned. I had some trouble with the AR7100R I had in my Fury 55 last summer. I sent it in, and they replaced the satellite. It always seemed to lose bind after firing the engine - maybe due to vibration. I will have to think on this one. I would be all for a meaure of reliability. What would the ideal receiver be? Can you connect sats to the V-Bar and Spektrum Rx at the same time?
PS - this looks like a rx comparible to Ah Clem's JR.
#19 |
This is how mine looks like atm:
I range test my setup every field day 30+ meters away and trust me it's good enough. Each sat got two receivers btw My beef is more with dsm so just waiting for the new dmss from jr now and I'll be happy
Klaus Myrseth Team Compass 7HV FBL fullsize VBar - 3Dplus FBL fullsize VBar - Atom 500 FBL mini VBar JR 11X <3 - KBDD |
#20 |
On the RX issue I'm running BeastX as well, what is the general recommendation for the Spectrum RX then?
