Old 05-27-2012, 07:47 PM   #21
dbennettya
Originally Posted by ss4344 View Post
Don't think so, Don. The little guy does exactly the same thing whether I bind it to my DX6i or DX4e.
Monitor is stable on the DX6i, and it's nicely calibrated.
Sent from my GT-I9100 using Tapatalk 2
So it could be temperature drift in the main board somewhere like gyros or a reference.
Originally Posted by maarset View Post
Are we talking V1 or V2 that has cyclic drift?
Both of mine are V1.
Don
dbennettya is offline        Reply With Quote
Old 05-27-2012, 08:16 PM   #22
maarset
My v1 did the same thing. Just how it is. If you mix your flying up more it will not do it do bad. V2 doesn't do it.
Logo 500 VBAR GOV/YGE
MSH mini-p VBAR
mcpX V2
mikeaarset.zxq.net
maarset is online now        Reply With Quote
Old 05-27-2012, 08:20 PM   #23
ss4344
Hmmm. Mine's a V2. It's only a few months old.
Steve
ss4344 is offline        Reply With Quote
Old 05-28-2012, 01:09 AM   #24
maarset
Make sure you don't have any vibrations.
MSH mini-p VBAR
mcpX V2
mikeaarset.zxq.net
Old 05-28-2012, 01:55 AM   #25
ss4344
No vibration at all... Main motor is not running during the test. But good suggestion.
Steve
Old 05-30-2012, 09:19 AM   #26
maarset
Main motor needs to run to check for vibrations. How are you testing for vibrations?
MSH mini-p VBAR
mcpX V2
mikeaarset.zxq.net
Old 05-30-2012, 05:10 PM   #27
ss4344
There are no significant vibrations with the motor running.
My test involves disconnecting main motor and then throttle up. In that state the cyclic will gently, but constantly tip ever more to the right hand side, just as if trim had been applied for aileron. It's a DX6i tx without any trim set, though.
After about three minutes with lipo plugged in to the mCP X and no throttle, the effect of drift to the right goes away when throttle is applied (with motor disconnected)...
In a flight test, the effect manifests itself by the mCP X requiring far more cyclic control unless the bird is left to sit on the ground powered but idle for three minutes. After three minutes it flies with hardly any cyclic input required to maintain a stable hover.
If I disconnect and reconnect the same battery after three minutes the drift returns. Three minutes later, the drift is gone... Then disconnect, reconnect, and drift comes back. Of course, I can only test this without flight as the little guy does eat batteries.
Cheers,
Steve
Old 05-31-2012, 06:11 AM   #28
spykez
Interesting. I'll take a look at it. I need to strip down one of mine for a service anyways. With the short days and crappy weather we're having now, I'm back flying my mCP X's.
Prôtos mini's - trying desperately not to hit the ground...
spykez is offline        Reply With Quote
