Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger Electric Helis
Thunder Tiger Electric Helis Mini Titan E325, Raptor E550 and E620 SE Helicopters
Old 06-01-2011, 05:45 PM   #1
legacy115833
Default e325 servos
i noticed a lot of people running the hi tecs but align ds410m servos are just a little faster and i like a fast machine but here is the big question will they fit??
legacy115833 is offline        Reply With Quote
Old 06-02-2011, 03:15 AM   #2
KouDy
I will use hobbyking as example site because they have nice measure pictures and descriptions.
Let's see 3 different servos :
HXT900
D922MG
Hitec HS-65MG
See the measure table on the pages. I found that most important measurements for e325 are B and F. You can see B is 23 or 22 mm for these three and you will be able to squeeze those 23 between the grips.
F is different story. HXT900 is 16mm, D922MG is 19mm and HS-65MG is 17mm. For aileron and pitch servo (those are mounted on the sides of e325) you will not be able to fit 19mm without adding some extra distancer. You will fit 16mm. You should be able to fit 17mm as well.
shelved : Titan e325 SE flybarred | Titan X50 flybarred torque tube
Futaba 10C in mode 3
KouDy is offline        Reply With Quote
