Old 06-01-2011, 08:09 PM   #1
400 flyer
Default battery temp. ?
hi guys, i was just flying my 250 for about 4 mins and battery temp is 140 is that to hot??
im useing the scorpion motor ,,cc 25 esc,, nrg 800ma battery.
2-evo 50's>1-sdx>hawk pro bell 222 /3g/rjx>evo90>freya 70.
trex500esp, scorpion/ ice 75/ 3g/rjx>hirboo embla 450 fbl,ice50,>lepton ex
2 bl mcpx's
futaba 8fgs,,dx7,,phoenix v3.0r
Last edited by 400 flyer; 06-01-2011 at 08:13 PM.. Reason: added what i was useing.
400 flyer is offline        Reply With Quote
Old 06-01-2011, 08:20 PM   #2
newbheliusr
Seems hot. How many C is the battery? If it's less than 20 I think that may be the problem. I have an eflight 800mah battery. It doesn't say it's c rating, but I am almost sure it's 15. And that battery comes down pretty darn warm. I don't think it's 140 though. That is pretty darn hot I think. but I am new.
newbheliusr is offline        Reply With Quote
Old 06-01-2011, 09:00 PM   #3
400 flyer
its rated at 35c .
heres the battery i have.
http://helidirect.com/outrage-nrg35-...ma-p-17067.hdx
2 bl mcpx's
Old 06-01-2011, 09:27 PM   #4
newbheliusr
I think you should let someone more experienced than I comment. It sounds like you do some hard flying to get a battery that warm. I am too new to comment. Sorry.
Old 06-02-2011, 10:15 AM   #5
tonydig11
i fly a 30c pack and it comes down worm but not hot
Align T-Rex 550E FBL with CNC tail upgade,ICE 100, viper 1300,beastx with edge 523's
Align T-Rex FBL 3G 250 SE , viper 3600kv
Align T-Rex 600n FBL, CNC tail upgrade, OS55, 3Gx
tonydig11 is offline        Reply With Quote
Old 06-03-2011, 07:33 AM   #6
ahahn
I've read that anything over 130 degrees F is bad for the pack.
A high C rating should be coming down cool, not hot.
Something sounds screwed up.
Let me change that second sentence to
A true high C pack will be coming down cool, not hot!
ahahn is offline        Reply With Quote
Old 06-03-2011, 08:55 AM   #7
zeeflyboy
That does sound hot - what settings do you have on your castle ESC? pwm for scorpion should be low (8khz), and which pinion are you using? Are you using govenor? What battery connectors?
I have same setup, with 15t pinion and 4,400 rpm set in the govenor, but with 800mah 20C lipos and they come down warm but not hot.
Blade mCP X - Brushless, XP-7A, HP05S
Gaui X2, BeastX/Scorpion 3400kv/YGE-30A/GS-093/DS95i
Align AH-1 Cobra (T-Rex 500)
Align T-Rex 600 EFL Pro, SK720/600MX/YGE-90HV/BL9180/BL9188
zeeflyboy is offline        Reply With Quote
Old 06-03-2011, 10:23 AM   #8
400 flyer
im running the 8khz plus 5* timming and useing mini dean plugs on all my 250 batterys, and no govenor.and useing a 15t pinion.
i have no binding anywere gear mesh is good. i have another 800 pack plus a 860 pack im going to run and see if they get hot. if not then its the battery , if so then i have other probloms.
2 bl mcpx's
Old 06-03-2011, 11:00 AM   #9
QueadlunnRau
Looking at the review of that battery at helidirect, someone says it's more like 15c then 35c. Which would make sense on why it's hot.
I used to only run the Outrage 860mAh 35c's which were awesome till 3 of them had bad cells (After over 50 uses each so I'm not really complaining), never ran the 800's tho.
I run Align 30c's and still have an outrage 860mAh 35c and they both come down slightly warm well under 110deg F. I'm at a 15t pinion with stock motor/esc and used to run a 16t with same battery temp.
Chopper Crew: MCX S300, T-Rex 150 DFC, T-Rex 250 DFC, T-Rex 450L Dominator, T-Rex 550e DFC
Multi Chop Crew: Nano QX, 200 QX, Diatone FPV250, Scratch V-Tail 355
QueadlunnRau is offline        Reply With Quote
