Old 06-02-2011, 07:14 PM   #1
kavic5150
Question night blade wiring help
Almost done with my DIY 325mm night blades, first set and ran into a dilemma. I've got a 3pin strip connector so I can use the align night blade charger left over from those lackluster 3k night blades, and a tiny 3 position switch I got from mouser.com. I'm at kind of a loss as to the best way to wire them. The positive copper strip is on top and ground is underneath. On the switch the two center pins are ground and the outer pins are positive, tho they could be reversed.
I used a micro switch to avoid those pesky jumpers even tho I have half a dozen of them. I'm looking for a way to wire this up without any overlapping copper tape, even If I have to do a lap around the blade with copper wire. Any suggestions?
BTW the part number for the switch is 611-ayz0103agrlc. They were super cheap and Im pretty sure digikey has them as well.
kavic5150 is offline        Reply With Quote
Old 06-02-2011, 10:27 PM   #2
TheBum
Moved to the Night Flying forum.
HeliFreak Support
DT520Ev2 (VBar), Protos Max Evo 700 (Brain), Protos Max V2 770 (Brain2; under construction)
TheBum is offline        Reply With Quote
