Go Back   HeliFreak > R/C Helicopter Support > Outrage Velocity 90 Nitro
Outrage Velocity 90 Nitro Outrage Velocity 90 Nitro Helicopter Factory Support Forum
Old 06-04-2011, 01:48 PM   #1
mahathyr
Default V90 Build problems
after 6 months in the box decided to take her out and start working on it...frames were of no issue but the tail...there's got to be a lot of work...my v50 did not gave too much issue but the v90 case when i fixed all the small lil screws everything was nice and smooth...need to sandpaper the tail shaft for a smoother tail pitch slider movement and it improves quite a lot...but when i fix the tail case to the tail boom and start to tightening all the screws, my tail pitch slider does not move smoothly and the tail shaft gears and rear bevel gears were tight against each other..i will still not give up and hope that some will be able to give me tips and advice on how to solved this issue...watch Capi's mod and it is a good idea but for the time being my resources are limited to that mod..anyway cheers for reading...hope someone will be able to help me here...
another thing wat is the item for in Bag 14...i know 2 of it is for aliging and setting up purposses but the short and stubby part is the one i could not figure it out...tried reading the manual again but im so freaking tired..anyway cheersss all
Gravity Always Wins
mahathyr is offline        Reply With Quote
Old 06-05-2011, 02:11 AM   #2
Tradhunt
My tail was like that as well. I just snugged up the screws next to the arm a bit at a time until tight then tightened the others up and that helped alot and let it move smooth.
Other part the Ball link sizer? Sorry I picked this kit up used so not sure what was in the bags but just from seeing what I have I would think it's the Ball link sizer... Next kit will be NIB I get but I have to get my Fusion first.
George
I don't crash. I land with style.
Bowtech and Hoyt
Tradhunt is offline        Reply With Quote
Old 06-05-2011, 03:11 AM   #3
Tradhunt
Is this what you're talking about?
http://helidirect.com/r90n4511-outra...ty-p-20640.hdx
George
Bowtech and Hoyt
