Go Back   HeliFreak > R/C Electronics Support > Align 3G FBL System > Align 3GX FBL System
Align 3GX FBL System Align 3GX FBL Flybarless System Software and Hardware Support
Old 06-12-2011, 07:46 AM   #1
jayfrs
Default Align 3GX gov set up on TX
Hi guys i fitted my 3GX on my 700 Nitro that was running an align governor so i plugged the sensor wire into the 3GX, now before on my other set up with my DX7 AUX2 was my gov and Gear was my gyro but as the 3GX AUX2 is gyro and Gear is gov so on my old set up i had these settings in my TX
Prog MIX1. AUX2 - AUX2 SW:F-NR
Prog MIX2. AUX2-AUX2 SW:F-S12
Prog MIX3 AUX2-AUX2 SW:F-S2
so i have three different head speeds
So i thought as the gov is now gear should my prog mix be GEAR-GEAR i tired this and nothing works when i up the percentage it just has the same head speed in every switch position!
could some on please help me on this one as i am doing something very wrong! and share there TX set up for the governor
Many thanks guys!
jayfrs is offline        Reply With Quote
Old 09-12-2011, 04:00 AM   #2
coolj1m
You will still be using the same switch which is on AUX 2 you would have to use the gear switch to activate govoner mode
coolj1m is offline        Reply With Quote
