Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Atom 500
Atom 500 Compass Atom 500 Model Helicopter Discussion
Old 06-13-2011, 02:03 PM   #1
brian94066
Default New aftermarket motor for the Atom 500 - possibly
Scorpion 4015-1070kv
http://www.readyheli.com/MIK4465-Sco...E_p_38416.html
could get good, who knows
Brian Tran
Amainhobbies.com
Protek R/C
( ͡° ͜ʖ ͡°)
brian94066 is offline        Reply With Quote
Old 06-13-2011, 05:33 PM   #2
TheBum
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
You couldn't use any of the Compass pinions on it: it only has a 5mm shaft. The 500 and 6HV stock motors both have 6mm shafts.
HeliFreak Support
Nankin Hobby Field Rep, Compass Support Team
Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX
Experience is something you obtain only after you need it.
TheBum is offline        Reply With Quote
Old 06-13-2011, 05:57 PM   #3
arcweld
One of the reasons I love Compass is you just don't need aftermarket motors etc.
Sure it's fun to play around but for power and efficiency the compass motors just can't be beat.
I'm starting to notice a few Compass motors appearing in other brand machines too.
Atom 500 V-bar
FANG IT!
arcweld is offline        Reply With Quote
Old 06-13-2011, 06:32 PM   #4
crawl
Ditto. I have seen the 6hv in a bunch of Fusion 50's, and even in a few Trex 700's lol.
Chris D.
crawl is offline        Reply With Quote
Old 06-13-2011, 07:36 PM   #5
Ghostrider267
isn't the 500 motor a 5mm shaft?
At least all the atom 500 motors that I have are 5mm....
7HV, 6HV, atom 5.5, atom 500, warp 360
Compass rep / Team Gens Ace
Prostarhobby.com / Hobbypartz.com
Ghostrider267 is offline        Reply With Quote
Old 06-13-2011, 07:58 PM   #6
TheBum
Not unless the 1050Kv motor went to 5mm, which I have a hard time believing. My 1080Kv motor is definitely 6mm.
HeliFreak Support
Old 06-13-2011, 08:26 PM   #7
Jimmy!
*Just checked w/ calipers
The main part of the shaft (measured at the bottom of the can) is 6mm, but reduces to 5mm. The pinions have a 5mm bore.
At least this is the case on my 2 Atom motors and 3 pinions.
Jimmy! is offline        Reply With Quote
Old 06-13-2011, 08:31 PM   #8
TheBum
I guess I just never measured outside the motor. I know the motors take 6mm ID bearings and a 6mm snap ring.
HeliFreak Support
Old 06-13-2011, 08:52 PM   #9
Ghostrider267
I have the scorpion 4020 1100 motor in my atom now. This and the stock atom motor are very close as far as power goes. But the atom motor has a liitle more torque if you ask me. I will say that the scorpion motor is much more quiet in flight. They are both 5mm shaft so you can just switch the pinion right over.
Old 06-13-2011, 08:58 PM   #10
Ghostrider267
also if your want to take the time, you can get the 4025 1100 motor and change the mainshaft from a 6mm to a 5mm. it's pretty easy and they sell just the shaft too. the 4025 1100 has more power than the 4020 1100 and it's the same size so it will fit in the atom frame.
just a thought.....
Rob
Old 06-14-2011, 06:29 PM   #11
skunkworx
I've never found the motor to be the weak link, rather the packs. If you are seeing a lag in instantaneous power, try going with a smaller, higher C pack. The Compass motors produce nothing but INSANE amounts of power! If it's not snappy enough for you, up your pinion a tooth or two and I guarantee even the most fearless of pilots will get their heart racing with any machine powered by one these monsters. They produce tons of torque so you can load them down a lot more without bogging unlike with the Scorps (I've never had good results with Scorpion motors). Even flying in comparison with a Neu motor, the Compass motors keep neck-and-neck. Pretty tough to beat that.
Tim - Atom 500, 6HV, 3D+, eAurora
KBDD TEAM PILOT
Compass support/Nankin Hobby.com
--Si vis pacem, para bellum--
skunkworx is offline        Reply With Quote
Old 06-15-2011, 11:35 AM   #12
jchen
+1 Skunkworx but if you factor inn the cost of good high C batts, it might
be cheaper to buy a Pyro or go 8S
jchen is offline        Reply With Quote
Old 06-15-2011, 12:08 PM   #13
crawl
low C packs won't work any better on a Scorpion/Pyro. If anything it's going to work worse as those motors are going to EAT your packs.
Likewise with 8s if you continue to use low C packs you are just going to add weight and gain very little power. It will be a wash in the end but your machine will fly heavier.
Chris D.
Old 06-15-2011, 06:08 PM   #14
skunkworx
The higher the cell count you go, the less C you need to back it up. Running at the same power level, 8S VS 12S you will pull about 25% less amps in the same maneuver. If you did all the math, you could easily get away with doing only 25C packs and have equivalent or better power than 30C to 50C packs on 6S and 8S. If you wanted totally insane power, you could go high C on HV and it would fly a lot more like the 6HV.
KBDD TEAM PILOT
Old 06-15-2011, 07:40 PM   #15
jchen
Hi Skunkworx,
Totally agree with you.
Old 08-12-2011, 02:34 PM   #16
Ivamos
Hi guys!
I accept, that the Compass motor is powerfull, but the quality of used materials is not really good.
I killed two Motors in normal use. A lot of power means high forces on the shaft. But this shaft is not hard enough and its in only two relativelly small bearings.
Just see how it looks under the top bearing. Even the small imbuss screw in Pinion did make visible trace on it. Shaft on my new (1050kV) Motor looks now exactly the some as a shaft in "old" 1070kV Motor. Both are no more usable, and there ist no options to change only the shafts. Bearings are still top!
I do not want to buy a new motor every half year - even if its powerfull and relativelly cheap.
So i use Scorpion HK4025-1100 now. Overall quality is uncomparable better as in this "new one" Compass Motor. Mikado in Germany sell it with 5mm Shaft End for 89 Euro including VAT.
Ivamos is offline        Reply With Quote
Old 08-12-2011, 08:32 PM   #17
sly the dogman
Simple question ?
Isn't the HK4025-100 for the 600
and the HK3026-1400 for the 500.
For a 5.5 which is more suitable,
just curious.
We do accept FB parts for Compass 5.5
sly the dogman is offline        Reply With Quote
Old 08-13-2011, 07:21 AM   #18
Ivamos
We are flying Atoms - not Trexx.
4025 fits and performs very well. I did try a very expensive Hacker A40 10L Turbine - but this has terrible sound and runs very hot. Not the deal for me.
Name:	2011-08-06 17.19.42.jpg
ID:	246095   Click image for larger version
Name:	2011-08-12 13.47.02.jpg
ID:	246096   Click image for larger version
Name:	2011-08-12 14.39.03.jpg
Old 08-13-2011, 07:47 AM   #19
crawl
I have to admit that is sexy looking haha.
How is the power on the 1100kv Scorpion Vs the stock Atom motor?
How about heat (battery/motor)?
Flight time?
What ESC are you running? I see the 4025 is rated for 100a continuous, most are running ~60-70a ESC's with this heli.
If anything I would think the new scorpion motor made for the 400SE would be ideal replacement. Weighs 121g less but still rated for 1900w (vs 2200w for the 4025).
Chris D.
Old 08-13-2011, 02:04 PM   #20
sly the dogman
I do not want to get a Scorpion for my 5.5,
it was just "a simple question"
