Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Atom 500
Atom 500 Compass Atom 500 Model Helicopter Discussion
Old 06-16-2011, 09:41 PM   #1
Apples
Default FB Atom 500 - Asymmetrical Pitch values
For some of you here in this forum, my dilemma is probably a no-brainer. But, for me, it's been a challenge, a head scratcher. Using the AFR values for aileron, pitch, elevator, Mixing Arms positioned downward 5 degrees, the basic linkage lengths listed in the last version of the assembly manual, and, with no subtrim on Futaba S9650 servos, I get +12, 0, -14 for the pitch range.
I've tried raising and lowering the swash to see if I could get symmetry, with no result. Currently the base of the swash is at 11 mm from the bearing block. When I did get a +13, -13 pitch value, the value at mid stick, with a linear pitch curve, was +3.. Turning the pitch link on the grip to achieve 0 degrees at mid stick, only resulted in lowering the positive pitch and increasing the negative.
Can anyone advise on what I may be doing wrong?
Thank you for your consideration
Apples is offline        Reply With Quote
Old 06-16-2011, 10:27 PM   #2
fenderstrat
you are on the right track I think you just did not do things in the right order.
try re-centering the swash
then re-set 0 pitch at mid stick
then take your pitch measurements
make sure the pitch curve you are using for set up is 0-25-50-75-100.
some guys run 0-50-50-50-100 for set up as you are at mid stick(for 0 pitch)everywhere but the extreme ends.
double check your radio for no mixes,trims or anything out of the ordinary
dont worry we'll get this straightened out
ATOM 500 Knight 503D
6HV,TT MINI TITAN/MTSE
Compass Helis Support Team
TEAM KBDD
fenderstrat is offline        Reply With Quote
Old 06-16-2011, 10:54 PM   #3
Apples
fenderstrat,
Thank you for your swift offer to help. The are no mixes, trims, expo, nor subtrim. During setup I did use the 50, 50, 50 to check at mid stick, but used a linear pitch curve when checking the range.
Forgive my ignorance, but when you say, "try re-centering the swash", what do you mean?
Old 06-17-2011, 11:13 PM   #4
Apples
Ok, "fenderstrat"... I centered the swash anti-rotation pin in the anti-rotation guide using a 50% pitch curve all around. Result? Same as before: +12, 0, -14, using a linear pitch curve.
Not wanting to spend much more of my "Golden Years' trying to find a solution to a problem which Atom owners don't seem to have, I went on to make the pitch symmetrical, +12, 0, -12 using the Pitch AFR and an altered pitch curve.
Thanks for your initial help.
Old 06-17-2011, 11:16 PM   #5
TheBum
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
Are the links attached to the upper mixer arms at a 90 degree angle to the arms?
HeliFreak Support
Nankin Hobby Field Rep, Compass Support Team
Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX
Experience is something you obtain only after you need it.
TheBum is offline        Reply With Quote
Old 06-18-2011, 12:07 AM   #6
fenderstrat
'Not wanting to spend much more of my "Golden Years' trying to find a solution to a problem which Atom owners don't seem to have, I went on to make the pitch symmetrical, +12, 0, -12 using the Pitch AFR and an altered pitch curve."
No dont do that that that will cause problems later
when I say "adjust the swash" I mean change the distance from the servos to the swash by adjusting the 3 links from servo to swash.you will not need too many turns.then reset 0 at midstick and procede from there.
You are not wasting anyones time.I would much rather see your heli set up CORRECTLY,then covering up the issue using your radio
TEAM KBDD
Old 06-18-2011, 12:12 AM   #7
Apples
@ Bum,
This is how the link looks at mid stick, 0 degrees, after the change to the AFR pitch and altered pitch curve. No, it's not quite 90.
Old 06-18-2011, 12:18 AM   #8
TheBum
The upper mixer arms are down at too sharp of an angle. Try setting them so that the links connected to them are at 90 degrees to them and check pitch again.
HeliFreak Support
Old 06-18-2011, 12:19 AM   #9
fenderstrat
cool a picture really helps,now we are on the right track
TEAM KBDD
Old 06-18-2011, 12:21 AM   #10
Apples
fenderstrat,
Thank you for your support, but, I have raised and lowered the swash by turning the 3 links, more times than I can remember..(on second thought I have the notes) LOL At one point I couldn't go lower because I couldn't turn the pitch servo link in any more. The results were all the same- uneven pitch.
Old 06-18-2011, 12:25 AM   #11
Apples
Man, I'm behind your responses...
@Bum...I'll start all over again tomorrow to make sure of the 90 degrees and report back.
@fenderstrat..."A pic is worth 1000 words". Cell phone pic - Evo 4G
Old 06-18-2011, 12:28 AM   #12
Apples
@ Bum and fenderstrat
Do I get to 0 degrees at mid with the mixing arm linkage or the grip pitch link?
thanks
Old 06-18-2011, 08:27 AM   #13
TheBum
thanks
If you can, use the grip linkage to maintain that 90 degree geometry of the links relative to the mixer arm. If not, it's OK to use the other link.
HeliFreak Support
Old 06-18-2011, 09:52 AM   #14
fenderstrat
just a thought but are your EPA's all at 100 for both directions of travel?
also when you were raising and lowering the swash did you re-set 0 pitch each time then check your range??
just so we are on the same page,even if you only move the swash links 1 turn you have to re-set 0 pitch at mid stick THEN take your blade pitch measurements.
you cant adjust the links then measure pitch.if its NOT this.we will have to start looking elsewhere.Stuff like this drives me nuts and its not even my heli..LOL..we WILL get this
TEAM KBDD
Old 06-18-2011, 12:12 PM   #15
Dflyer
As Alan said your mixer arms are on a too sharp angle. Make sure when you are at midstick that the bottom side of the mixer arms is approximately level with the flybar, as mentionned in the manual.
Grtz,
Dirk
The heli virus has infected me and i hope that there is NO CURE !! Compass Support Team
__________________________________________________ _____
ATOM 500 FBL (BeastX) / ATOM 6 HV FBL (BeastX) / 7HV FBL (BeastX) / Henseleit TD R
Dflyer is online now        Reply With Quote
Old 06-18-2011, 07:06 PM   #16
Apples
"Bum", fenderstrat, DFlyer... Sorry for the delay, but I have been "piddleing" with the 500 for about 5 hrs, and, I continue to scratch my head.. My nose has been so buried in this heli (because of your support) that the wife got ticked that I was focusing solely on this, so she marched off to gamble at the casinos in Atlantic City.
@"Bum"
Thank you again for your keen observation and suggestion that I manage the geometry. Before redoing the geometry to get the 90 degrees @linkage to mixing arm, I set servo to swash linkage lengths and swash AFR percentages for Aile, Elev, Pitch, as per manual.
I tried everything combination of Mixing Arm linkage length to Grip pitch linkage length to arrive at the 90 degree geometry. Each combination mysteriously resulted in +12, 0, -14. After depleting both my Tx and Rx battery and, replacing them, I tried one more time. Result - + 13.7, +1.5, - 12.2. (see pic). My experience has been that if I now bring the grip down to zero by turning the pitch link in, that will result in bringing the pitch at full stick down.
@fenderstrat,
Yup....EPA's are at 100 in both directions. And, yes, I did reset for zero pitch at mid. Each time I did that, I lost positive pitch at full. If this is driving you nuts, then, you better join my wife in Atlantic city. LOL
@Dflyer
Thank you for sharing your expertise.. I tried doing as per the bum's suggestion. I hope I didn't go way past the 90. If I did, blame it on my eyesight.
To all.... I have been reading your instructive posts, along with AhClem's for over a year in this forum. I want to doubly thank all of you for the time that you are investing in this matter. HAPPY FATHER'S DAY!
Old 06-18-2011, 08:54 PM   #17
fenderstrat
if you were losing positive pitch at full,did you then adjust the links the other way?I am assuming yes
so if your epa's are 100,your pitch curve is 0-50-100,the pitch setting in the swash menu is allowing for full travel.and the head is set up right,what are we not seeing?????HHHMMMM,this one is a head scratcher.
one time I was having a set up issue and it was because I was thinking that my normal curve was 0-100 but I was setting up in throttle hold which had a different pitch curve.LOL I wasted a bit of time on that one.
I'm really out of ideas on this one.
Don't give me any excuses to go to AC, its only 90 min from me and some blackjack sounds like fun right now
TEAM KBDD
Old 06-18-2011, 09:11 PM   #18
Apples
@fenderstrat,
Out of ideas? Not a problem.... If I set up the mixing arm geometry at 90 by the means I mentioned before, I invariably got more positive pitch than negative. That was good, but, to get to zero at mid stick with a linear pitch curve, I would have to lower the grip (turn in on the link), resulting in loss of the positive pitch, i.e., +12, 0, -14.
Right now I'm at +13.7, +1.5, -12.2 after a combination of 1/2 turns on the links....LOL I may just have to go back to the Finless Bob work around for uneven pitch range
Old 06-18-2011, 09:28 PM   #19
fenderstrat
I still think we are talking about 2 different things here.
if you say you have +12 0 and -14 then you adjust the links FROM SERVO TO SWASH,in the negative(sorry had to fix it) direction 1 deg then reset 0 pitch at mid you should get +/- 13.
the fact that you are off by even ammounts tells me that the set up is correct,its your 0 point of the swash that needs adjusting,am I making sense?
if you have say 26 deg total.if the swash is correctly in the middle you get 13 and 13.if the swash is one deg either way you get 12 and 14.again the total movement is correct and remains the same only the 0 point of the swash is different.If you were getting say -5 0 and 11 then there would be something off.but your travels seem even
TEAM KBDD
Old 06-18-2011, 09:49 PM   #20
Apples
fenderstrat,
"the fact that you are off by even ammounts tells me that the set up is correct,its your 0 point of the swash that needs adjusting,am I making sense?"
Ok.. I understand what you're saying. And, no, I didn't want to move the swash up or down to keep one variable consistent. At +13.7, +1.5, -12.2, you've given me something to work on. I'll report back.
