Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCP X Brushless Mods
mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions
Old 06-17-2011, 01:14 AM   #1
tntburnett
Blade Forum Support
Default Here is my mcpx brushless conversion with pics ,still video and flight video
Here is some pics of my brushless conversion mcpx.
I am using the helimax novus cp brushless conversion kit I got it from http://www3.towerhobbies.com/cgi-bin...8015&search=Go
the 9tooth pinion from
http://www.bphobbies.com/view.asp?id...18&pid=S739658
and the steve converter from
http://thesteve.ca/walkera/
Heres video also
The pics with the yellow wire shows how I done it and it works well. I solder the yellow wire to the old main motor plug on positive side and plug it into the plug on the board.
This thing is
Enjoy
Have a blessed week
ID:	234520   Click image for larger version
ID:	234521   Click image for larger version
ID:	234522   Click image for larger version
ID:	234524   Click image for larger version
ID:	234527   Click image for larger version
ID:	234528   Click image for larger version
ID:	234529   Click image for larger version
ID:	234530   Click image for larger version
Jesus Rep Its all Good,Its all GOD
FPV Everything Now
GOD BLESS
tntburnett is offline        Reply With Quote
Old 06-17-2011, 04:53 AM   #2
Pigs dont fly
Cool, so the signal wire for 'thesteves' converter can just plug in to the motor socket, rather than soldering to the PCB....that makes things much easier, nice find.
I'm waiting on my parts, I have my motor and new frame, just waiting on thesteves converter and the ESC to arrive, I'll be brush-less too soon
Warning this hobby is very addictive and may damage your wealth.
Pigs dont fly is offline        Reply With Quote
Old 06-17-2011, 06:37 AM   #3
Stevin
can you post a video of it flying, looks to be a bit simpler to obtain the parts for your version in comparison to others and I am looking to go brushless as well so I would like to see how it compares in flight to others I have seen. Nice Job
Stevin is offline        Reply With Quote
Old 06-17-2011, 08:24 AM   #4
TwinTurbo95
How bout some flight video's?
That the most important thing!
Compass 7HV: BeastX - MKS HV
Gaui X4 V2: BeastX - Scorpion
Blade 300X: Hyperion - Hitec - JR
TwinTurbo95 is offline        Reply With Quote
Old 06-17-2011, 09:06 AM   #5
tntburnett
Blade Forum Support
Here is a flight video peps :-). Enjoy
Sent from my DROIDX using Tapatalk
FPV Everything Now
GOD BLESS
Old 06-17-2011, 09:41 AM   #6
Katch
Can you tell me where the other wires from the Steve go?
Yellow signal goes onto the positive of the old motor plug.
Then White goes to white on the ESC
Red & Blue - do these go to the ESC or somewhere else - I'm a little confused about the battery side.
Edit - am I right in thinking it all goes in parallel. Red & Blue to Red & Black on ESC to Posi & Neg on Lipo?
Katch is offline        Reply With Quote
Old 06-17-2011, 10:32 AM   #7
tntburnett
Blade Forum Support
In this pic the blue is going to the black wire, the red wire is going to the red wire and the white is going to the white wire the two thicker wire red and blk I have solder on the board. Hope this help
FPV Everything Now
GOD BLESS
Old 06-17-2011, 10:46 AM   #8
Katch
got it. thanks.
Old 06-17-2011, 08:55 PM   #9
Ampdraw
Red and blue are the power feed for the "thesteve".
So they can be powered from wherever you prefer. TNT's style of powering it from the esc is a better option imo than soldering to the 3in1.
Means you only have three contacts to solder to on the board or two if you use the motor plug.
From memory the Walkera 003 is actually approx 15000kv and weighs 11g or so incl plug. That heli must be capable of pretty high rpm but that motor would cope...certainly a better option than the Turnigy 1220 which needs frame mod.
Amp
Ampdraw is offline        Reply With Quote
Old 06-18-2011, 08:21 AM   #10
adroc3905
Just curious, you mention using the stock tail....how is it holding up with the BL mod?
I see Helimax also makes a BL tail kit..........hmmmmmmmmm
Great vid and good idea about the yellow wire. Loving my mCPx
TBS Discovery
Rave 450 FBL - miniVbar
Trex 500 ESP FBL - Beastx
Trex 600 ESP FBL - Beastx
adroc3905 is offline        Reply With Quote
Old 06-18-2011, 10:38 AM   #11
Heli-Yeah!
So your running stock tail motor/rotor blade, and 120SR tail wires and plug. Have you had many blow-outs, and does it seem more forgiving as far as it's need for collective management?
Heli-Yeah! is offline        Reply With Quote
Old 06-18-2011, 10:48 AM   #12
tntburnett
Blade Forum Support
Yeap I am running the factory tail motor and tail blade. Yes it is way more forgiving where I was running 95% pitch travel now I am running 70 to 75 pitch travel and with that pt it has enough pop :-). Have a blessed week
FPV Everything Now
GOD BLESS
Old 06-18-2011, 10:54 AM   #13
tntburnett
Blade Forum Support
Yeap the tail holds fine :-). I may try the sr120 tail motor. There's a Guy who tried it and it seems to work well.
FPV Everything Now
GOD BLESS
Old 06-18-2011, 11:20 AM   #14
Stevendavis
tnt,
What is your throtle atv set at? Thanks.
Blade MCP-X Brushless, 300CFX, , Trex 600 ESP 6s 3GX v.3.1 and KDE head, Trex 600 LE, OS 55 Hyper Limited Edition, Trex 700 Nitro, Futaba 12Z controle!!
Stevendavis is offline        Reply With Quote
Old 06-18-2011, 12:07 PM   #15
tntburnett
Blade Forum Support
Originally Posted by Stevendavis View Post
tnt,
I am using the jr9503 transmitter
Norm is 0 25 50 75 100
St 1 90 90 90 90 90
St 2 100 100 100 100 100
Pitch travel H 75 L 75
D/r 100 expo 20
Thro travel 100 100
Normal Pitch curve 36 40 45 50 67 83 100
St pitch curves 0 25 50 75 100
Hope this help
Sent from my DROIDX
FPV Everything Now
GOD BLESS
Old 06-19-2011, 01:45 AM   #16
blbills
What's your AUW with the conversion?
blbills is offline        Reply With Quote
Old 06-19-2011, 08:07 AM   #17
tntburnett
Blade Forum Support
What do auw stands for
Sent from my DROIDX
FPV Everything Now
GOD BLESS
Old 06-19-2011, 08:15 AM   #18
Heli-Yeah!
AUW = All Up Weight ( How much does it weigh, ready to fly with battery installed? )
Old 06-19-2011, 08:40 AM   #19
tntburnett
Blade Forum Support
thank you heli-yeah . I dont know what is the weight I havent weighed it yet. I will take it to my LHS and see how much it weighs . Have a blessed week
Old 06-19-2011, 08:42 AM   #20
tntburnett
Blade Forum Support
Here is some more things i done. I didnt think to post it on here forgive me for that. Have a blessed week.
http://www.helifreak.com/showthread.php?t=315509
