Old 06-18-2011, 08:56 PM   #1
BruceHuang
Default Jive 80HV with buffer pack
Hello, I have got my buffer pack today. I do connect the slave port to my rx. However, I would like to use a buffer pack as well. Can I just plug in a 4.8v Nicd/NiMn battery in any open channel even with the slave cable connected, that wouldn't do any harm, right?
Also, can I use the align external voltage step down a 2s battery to 4.8v instead of a Nicd/NiMn buffer pack? I don't really like Nicd/NiMn packs.
Cheers
BruceHuang is offline        Reply With Quote
Old 06-18-2011, 09:17 PM   #2
FSAMedia
Either port will work but you shouldn't use a lipo as a back up, as the BEC voltage may vary from your lipo pack. Someone else chime in if I am incorrect.
FSAMedia is offline        Reply With Quote
Old 06-18-2011, 09:58 PM   #3
PhotoShip One
do NOT use a regulated lipo pack!!.
Use a 4 cell nimh or nicad. It doesn't matter if you plug directly into the slave port on ESC or an extra channel port on RX.
DJ Vegh
PhotoShip One
PhotoShip One is offline        Reply With Quote
Old 06-18-2011, 11:34 PM   #4
BruceHuang
Thanks guys.
So DJ, am I doing right by plug in slave cable to the rx and also connect buffer pack directly to the rx?
Regards
Old 06-19-2011, 10:48 AM   #5
onlocation
Originally Posted by BruceHuang View Post
Thanks guys.
Regards
Yes, this works fine. What we do is have the buffer pack on a normal RC switch that then plugs into the Rx. This way you can easily power up the Rx and servos with the switch to do a preflight check before you plug your main packs into the ESC.
Also if you are running a FBL unit, then depending on what unit you have, you may want to plug the slave from the ESC into the FBL unit, since the servos actually draw the power from this unit.
onlocation is offline        Reply With Quote
Old 06-20-2011, 12:11 AM   #6
BruceHuang
Hello onlocation,
Thanks for your suggestions, the switch and plug in to FBL unit does make a lot of sense to me.
Old 06-20-2011, 05:04 AM   #7
BruceHuang
Btw, guys, I couldn't find the right length tail rod, can I cut it down and glue it to a ball link? Is it safe to do? Regards
Old 06-20-2011, 08:10 AM   #8
raytang
I do This Now
Jive can charge to 4.8v Battery Pack
raytang is offline        Reply With Quote
Old 06-20-2011, 08:53 AM   #9
BruceHuang
Originally Posted by raytang View Post
I do This Now
Thanks Ray, I see only one cable from the ESC to rx. Do you also connect the slave?
BTW, the HKUST process applications really slow. Iooking forward to check out your work in HK.
Old 06-20-2011, 06:32 PM   #10
POWERFTK
http://helifreak.com/showthread.php?t=304140
POWERFTK is offline        Reply With Quote
