Go Back   HeliFreak > R/C Helicopter Support > Kyosho
Kyosho Kyosho Caliber, Kyosho Helicopters
Old 03-20-2007, 09:37 PM   #1
geerbangr
Default Assist on setup
Could someone help me with some set up procedures for this old bird ??
I purchased this thing brand new 11 years ago . I built the entire aircraft and the thing never would fly correctly . So I parked it and recently was introduced to a couple guys that fly helis and would'nt you know it i'm involved again . This time with some more understanding . Anyhow i'll cut the bullshitting out and get on with my questions .
I set the rear tail rotor up , pitch slider center of the shaft . Servo set at full travel . Now , when I left stick the rudder I have full travel . When I let off full left stick the slider isn't coming back to dead center . When I right stick the rudder it is coming back to dead center of the shaft . The issue w/ left stick is about and 1/8 " . I don't understand wth is going on . If I full left stick the rudder and let off the stick , bump it to the right it is sitting at dead center . I don't see any binding of the linkage anywhere . Hell I don't even know if i'm setting the rudder up correctly or not . Help anyone ????
geerbangr is offline        Reply With Quote
Old 03-20-2007, 10:48 PM   #2
kevinator9
What heli...what radio...what servo's please.
Andrew
Futaba 8FGS | Spektrum DX4e
Atom 500 FBL (Microbeast) | Blade MCP X | Sukhoi SU-26XP
kevinator9 is offline        Reply With Quote
Old 03-20-2007, 11:54 PM   #3
geerbangr
Concept 30 , futaba skysprt 6H , FP514B servos
Old 06-24-2007, 05:56 PM   #4
shesha
Which gyro are you using ?, souns to me that you are in heading hold and not in rate mode, take out all the numbers in the gyro menu and leave everything in 0 to make sure that the tr servo zero back if it does not then your servo or gyro may be out or your hacving some binding.
shesha is offline        Reply With Quote
