Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600 PRO Class Electric Helicopters
600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 10-05-2012, 02:37 AM   #381
smsodhi
Originally Posted by Stevin View Post
I have been using rail 606 blades and running 95mm align blades but I want to opt for running the 105mm tail blades so I just ordered a pair of radix 600mm. Can anyone verify that this is fine when using the DFC head?
I am running radix 600 with 105 tails. No concerns with DFC head and KBBD hard dampers. I have managed a small dent on the boom after a hard auto. No interaction with tail blades so far and have clocked up a lot of flights on it so far.
TRIABOLO P800 Kosmik HC3-SX 255/256
DIABOLO 4530 Kosmik HC3-SX 690/105 255/256
Futaba 12 FG
smsodhi is offline        Reply With Quote
Old 10-06-2012, 01:31 PM   #382
mirmanchuck
cool
mirmanchuck is offline        Reply With Quote
Old 10-14-2012, 11:06 AM   #383
Praztek
What is the suggested ball distance , center to center for the rudder servo screw to ball link on the horn ?
Praztek is offline        Reply With Quote
Old 10-14-2012, 12:48 PM   #384
johnahamelv
According to page 28 of the 2011 Jun revision of the TREX 600EFL PRO (Model KX016017T) manual, the tail servo link should be 13mm from center as pictured below.
However, if you are using a FBL unit other than the 3GX, or a more sophisticated tail servo, you may want to bring the ball closer to the center from improved resolution.
Name:	Screen Shot 2012-10-14 at 13.42.11 PM.jpg
Whiplash E--ICE2HV160/KDE-495/MKS HV's, Synergy E5/S--ICE2HV120/KDE-530/Futaba HV's
T-Rex 600Pro XT--ICE2HV120/KDE-530, T-Rex 550--ICE100/KDE-1175, B130X, mCPx
VBar Silverline x4, Lots of KDE, DX8, Sims: Aerofly5.7 /RF6.5/Phoenix 4
johnahamelv is offline        Reply With Quote
Old 10-14-2012, 01:00 PM   #385
Praztek
Thanks, ar7200bx, ds650 servo.
Old 10-15-2012, 11:06 AM   #386
Praztek
So, in order to elimate the tail blow out, I could:
Either run at the bare mininum 2350, with tail setup correctly in rate mode with acceptable dregree's of pitch.
or
Lower headspeed, will require larger tail blades, vertical fin, and rear landing gear raise ground clearance.
Old 10-15-2012, 11:10 AM   #387
Mike A.
Originally Posted by Praztek View Post
So, in order to elimate the tail blow out, I could.....
Either those options and you will be fine. 2350 is completely safe, I've got several hundred flights at 2250 w/ 95mm tail blades.
Trex 600EFL - KDE'd Out - iKon // Nano
AMA# 8675309
Mike A. is offline        Reply With Quote
Old 10-15-2012, 11:22 AM   #388
Praztek
