Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 06-20-2011, 10:03 AM   #1
TeeRex001
Default 520s or 550s for 3D Flying?
Hey Folks,
What blades should I use for my Trex 550 for a 3D style of flying (Flips, Loops, Tictocs, etc) . Will be using the KBDD 84.5mm for the 550s and the stock align tail blade for the 520s. Any suggestion will be much appreciated!
TeeRex001 is offline        Reply With Quote
Old 06-20-2011, 02:05 PM   #2
kouasupra
520mm with 90mm tail
kouasupra is offline        Reply With Quote
Old 06-20-2011, 02:13 PM   #3
philipfrank
not a thing wrong with the 550's.
philipfrank is offline        Reply With Quote
Old 06-20-2011, 03:08 PM   #4
rtmoore4
I love my 553 Edge blades, but this is one case where I think beauty is in the eye of the beholder. In other words, you can make an argument either way. For me, the heli "feels" bigger with the 550s. Autos are reportedly easier, but I haven't done any from altitude yet, so I can't say. You also don't need as much headspeed with the bigger blades, so you are a little more efficient if you are just sport flying.
Smaller blades are less expensive (at least than the Edge blades), but there are less expensive options starting to appear in the 550mm size that may change that equation.
Blade mSR, michroheli CNC flybar
Blade 400 - HS56 servosx3, HS5048MGx1 (boom mount)
Trex 450 Pro FBL, SK720
Trex 550 FBL (x2), BeastX
rtmoore4 is offline        Reply With Quote
Old 06-20-2011, 03:28 PM   #5
deegs
+1 for 550's, but I think rtmoore4 is right. It's down to personal preference, there's no one right answer.
I like that little bit of extra pop and stability that the 550's seem to give.
Try them, if you like them keep them, if not you can always go back to 520's.
TRex 550e 3G
deegs is offline        Reply With Quote
Old 06-20-2011, 10:05 PM   #6
raptorz499
Well said on the above 2 posts
I absolutely love the Edge 553's. The heli really does feel a lot bigger and it is very stable, but still 3D bangin at the same time
raptorz499 is offline        Reply With Quote
Old 06-20-2011, 10:14 PM   #7
TeeRex001
Ok thanks to all, I think I will give the edge 553 a shot, but i know my 550 isn't comparable to the 600e pro, in terms of stability and autos. Anyway, I love both helis nontheless
Old 06-20-2011, 11:53 PM   #8
chakotay
+1
I tried Edge 553 after almost a year of flying 520's and the heli feels more like the sim now (I fly a 700E on the sim so this not a big surprise actually ). It's incredible how much of a difference those 30 mm make.
Kontronik - the most commonly misspelled RC heli brand name
Fusuno - the runner-up
chakotay is offline        Reply With Quote
Old 06-21-2011, 10:01 AM   #9
donahue3
553's all the way. I actually have my 550 stretched w/600 boom and I love the way the heli flies. I don't think you can go wrong with the heli being stretched with 553's.
Trex 700E V2
donahue3 is offline        Reply With Quote
Old 06-21-2011, 10:16 AM   #10
TeeRex001
donahue, is your 550E running a 6s pack or a 12s pack?. did you make any other changes when you stretch your 550E with the 600 tail boom?
Old 06-23-2011, 01:57 AM   #11
TeeRex001
Ok, i have finally decided to get a 550mm size blade to try out on my 550 . So, which brand should I get? Edge or Align, and why?
Old 06-23-2011, 09:35 AM   #12
donahue3
6s 5000 pack 40c Zippy and it flies really well, get the EDGE 553's and you will love your heli even more. Have fun
Trex 700E V2
Old 06-23-2011, 09:37 AM   #13
donahue3
I believe the chord of the EDGE blades may be slightly wider too, which helps for auto's. They are a little more money though. Honestly, I think you will be happy with either or.
Trex 700E V2
Old 06-23-2011, 09:58 AM   #14
markleyland
Still love the Align 520's. Flips and rolls quick. May try the 553 some day.
"Sort your head out and fly with your heart"
Trex 450 SE V2: 9257 tail, Spartan Quark, HS65mg cyclic, DX7-AR7000, NEU 1107h/2y, Jazz Esc,
Trex 550 FBL: Jive 100+LV, KDE/NEU 1907H/1/N42, Vbar 5.3, Futaba BLS 251
markleyland is offline        Reply With Quote
Old 06-23-2011, 10:04 AM   #15
breathe rc
Just used 550's for the 1st time yesterday. I think I may like the 550's over the 520's. It might be my imagination, but it seemed to float a little smoother, and respond better to + and - pitch moves. I will be upgrading to the 700 main gear though, because one hard transition from + to - pitch stripped my main gear out completely. Got lucky and brought her back in without incident.
If there's better, I want it.
HDCell 500, Scorpion HKIII 4025-890,
Compass 6HVU, Scorpion HKII-4225LE,
9K4O
breathe rc is offline        Reply With Quote
Old 06-24-2011, 10:20 AM   #16
TeeRex001
Ok, I just got the Align 550mm blades on my 550. First feeling of the 550 was that it feels large and "floaty" in the air. but i noticed that the tail is vibrating slowly a little bit. Is there any cause for this? btw, i am using the 84.5 kbdd tail blades
Old 07-05-2011, 02:11 PM   #17
hydev
If your using the 550mm blades do you need to get smaller tail blades? Just wondering if the blades may clip them in hard manoeuvres?
I'm tempted but was unsure on this issue.
Mike
Goblin 770, Goblin Nitro, Gaui NX7 Many come and gone but all V-bar'ed!
hydev is offline        Reply With Quote
Old 07-05-2011, 02:46 PM   #18
OnTheSnap
550 blades requires 86mm tail blades. 92mm will hit.
I prefer the 550 blades for 3D and aerobatic autos. There is a big difference in auto performance. Enough to make the difference of landing or crashing more extreme autos.
Flight time suffers with 550s. Obviously you need to run a lower headspeed on 550's, but even then I ended up with 30s less. Also 550's are harder on the ESC and batteries.
All worth it to me since I auto every flight. But for the longer 3D flights with less wear and tear on the electronics/batts 520's are better.
MSH USA
Xnova
Xpert
OnTheSnap is online now        Reply With Quote
Old 07-05-2011, 03:26 PM   #19
evoIX
the 520 align blades would not auto?
evoIX is offline        Reply With Quote
Old 07-06-2011, 12:23 AM   #20
OnTheSnap
Of course they auto. Just less hang time compared to 550's.
MSH USA
Xnova
Xpert
