Go Back   HeliFreak > R/C Electronics Support > Align 3G FBL System > Align 3GX FBL System
Align 3GX FBL System Align 3GX FBL Flybarless System Software and Hardware Support
Old 06-21-2011, 05:27 PM   #1
sprocketdog
Default radio help
New to fbl, using 3gx on jr 9303 what do i need for radio mixing to make work. Have system bound to each other. but only ail servo works. Thanks for any help I"m complete noob at this
The 9303 ia an fm model with dsm2 module. .
sprocketdog is offline        Reply With Quote
Old 06-22-2011, 03:29 PM   #2
sprocketdog
It is a radio programming issue. I think i have it figured out thanks, just need to learn how to map channels for 3gx.
Old 06-23-2011, 05:45 PM   #3
recurry
Unless you are using satellites there is no channel mapping to do - just connect it properly. If you are using satellites the 3GX instructions tell you what channels need to mapped to where then it's just q matter of figuring out how to do it in your radio.
I found the 3GS to be really easy to setup. I hope you do as well. Best of luck!
Ron
Stuff I fly....
Mikado, a couple of Aligns, VBar/SK720, an old Robbie Nova,
some multirotor stuff w/ AutoQuad6, Naza, APM, PX4, and full size Exec162F and a T210 just for fun!
recurry is offline        Reply With Quote
Old 06-23-2011, 10:47 PM   #4
sprocketdog
sent it off to align it has a problem works fine with a standard receiver but with satellites only only one servo works. The aileron servo does pitch and elevator Should have a working unit next week.
Old 06-25-2011, 04:16 AM   #5
takasan
im having a similar issue. i have a futaba with a spektrum dsm2 module. i had purchased dsmx sat. receivers and had trouble binding the 3gx so i pulled off my older dsm2 sat receivers off my plane and it bound. i set everything up and was about ready to fly then, and then suddenly it acted like it wasnt bound again. i bound it to a friends spektrum, and it worked but the swash acted funny. i may have to give align a call
takasan is offline        Reply With Quote
Old 07-01-2011, 10:28 PM   #6
sprocketdog
Just an update. repaired unit came in mail all is good.
Old 07-02-2011, 03:13 AM   #7
takasan
still waiting for mine
