Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600 PRO Class Electric Helicopters
600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 05-28-2013, 03:43 PM   #621
GRIMX
Most use 700 skids for a little bit more height, or at least 700 skids on the rear
T-Rex 600 EFL PRO,KDE XT MAIN ROTOR HEAD SYSTEM. DFC600 Swashplate.
SPEKTRUM AR7200BX DS610 X3, DS650 X1, Phoenix Ice2 HV 80 ESC. KDE600XF
GRIMX is online now        Reply With Quote
Old 05-28-2013, 07:39 PM   #622
johnahamelv
Originally Posted by GRIMX View Post
...at least 700 skids on the rear
Same here. 700 skids on the back. After sitting on the shelf during the winter, the stock short skids sagged and the vertical fin was touching the ground. I just changed the rear skid.
Whiplash E, Synergy E5/S (my favorite), Synergy E5 (building), T-Rex 550, TT Mini Titan v2 (building), B130X, mCPx
VBar Silverline x4, DX8, Sims: Aerofly5.7 /RF6.5/Phoenix 4
johnahamelv is offline        Reply With Quote
Old 05-31-2013, 02:55 PM   #623
Turttle
Thanks guys.Is there a part number seems the 550/600/700 all use the same newer skids with the lower profile.
Northern California RC Unlimited RC Flyers.
www.ashcreekrcflyers.com
Turttle is offline        Reply With Quote
Old 05-31-2013, 04:40 PM   #624
johnahamelv
Isn't so frustrating trying to figure out which skid is which when there are so many versions?
The tall rear skid that i am using is the AGNH70059. I believe the shorter one (the one that came stock) in the front is the F3C AGNH70060.
The helicopter will be canted forward in the bench, but flies fine. See the different carpenter level bubbles.
This is the skid I am using in the rear.
BTW. I am taking the electronics off the 600Pro. I am done dealing with the Align frustrations. T550 is next.
Old 06-01-2013, 06:15 PM   #625
Turttle
Sweet.Thanks..........Yeah I here you I am just now installing the kde and all the electronics and right now I am taking a break before I blow my top.There is just simply no room for the servos and the motor just way to close and getting a clean wiring set up is frustrating.So far a pain as far as that goes.This will be my last align 600 plus size heli.They just seem to be having new parts with way to much maintenence.500 Is pretty nice and the 550 as well with its simple and proven lay out.But I will get this one figuerd I puchased the kit with out elec.I knew it was going to need a couple hop up parts before starting the build.
Old 06-03-2013, 12:12 AM   #626
Turttle
Here is my new project.Not quite done yet but things are starting to come togeather a little mind boggled on the wiring at first but overall not a bad heli
ID:	425618   Click image for larger version
Old 06-17-2013, 04:22 AM   #627
atneworld
my Trex 600E DFC Pro
+ Radix 92mm tail blades
+ TM1000 Telemetry
videos from HeliFlyer on Youtube
atneworld is offline        Reply With Quote
Old 06-17-2013, 08:55 AM   #628
anmatheextreme
You must be brave to use 92mm tail blades on this heli. Align decided to go with a lower tail ratio so the tail is already weak with 95mm blades unless you are running crazy high 2500+ headspeed.
Sent from my HTC Sensation XE using Tapatalk 4
-Andrew
Align Trex 600EFL Pro - BeastX
Blade 450X - Scorpion 2221-6 motor
Blade 130x / mCPx HP05s
anmatheextreme is offline        Reply With Quote
