| Compass Model Helicopters Compass Model Helicopter Discussion |
just ordered tail pitch control rod set of carbon and thinking of pimping my flyte
http://www.centuryheli.com/products/...¤tid=535 and the rod guides http://www.centuryheli.com/products/...¤tid=535
Trex 500 : Atom FBL head AR7200BX | Atom 6HV : vbar 5,3 pro | Goblin 700 : vbar 5,3 pro | Goblin 500 : vbar 5,3 pro |
Century also sells a complete kit. I know you're in Norway, but I sourced mine from Espritmodel.com. I wound up removing the small bushing which intended to slide vertically in the guide, and do not use it at all. The clearance to the control rod was too tight for my 6HV. The guide alone will have lots of clearance, but prevent any severe oscillations. Mine works just fine. Lots of adjustability in the CNC ends. I almost installed my second assembly on the 7HV, but the stock one seems okay for now.
Best wishes,
= R To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. b43 = Team Compass Support |
thanks Rob43
its your pics that insired me , thanks for that everywhere I looked was out of stock , found a hobby shop i the UK and ordered there just to get an email they were out of stock too, restocking on friday , I will probably order from Espritmodel for my Trex 500
I installed one on a Hawk 30. Not too bad of a setup even though I'm not much of a fan of the company that produces it. The rod comes really long so you can use it on anything from a 550 up to a 700 no problem. I wouldn't doubt it if you could use it on an 800 as well. I cut off near 1.5' of rod off the one I built, so there's a lot in there.
You can also use Compass links instead of the crappy gray ones included. Just make sure you sand, clean, and CA the snot out of the metal ends so they don't pop off in flight. Maybe heat-shrink over it to make doubly sure it doesn't come off. Be careful not to add so much CA that it gets on the metal threads and makes it unusable (you can break the excess off, but it could ruin your links if it gets globbed on there too bad).
Tim - Atom 500, 6HV, 3D+, eAurora KBDD TEAM PILOT Compass support/Nankin Hobby.com --Si vis pacem, para bellum-- |
thanks guys
now it installed and looks sweet
#6 |
I have carbon rods for my 500 and 5.5.
Rods for a Logo 600 that I trim down to size and rod holders from a Synergy heli. Both work perfectly, must agree that it gives a very cool look to the heli.
We do accept FB parts for Compass 5.5 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by sly the dogman; 07-28-2011 at 11:41 AM.. |
#7 |
can you feel the diference with the carbon rod ?
--- - Sent from my iPhone using Tapatalk
SAB Gobblin 630 12s Vbar mCP-X + 130X + mCP-X brushless DSX9 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. follow us on facebook ! |
#8 |
The way I fly and the things I do or don't do with the heli
don't think has an impact on its performance. There's no flaw in the tail design that makes this mod a must. But it sure looks cool.
We do accept FB parts for Compass 5.5 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#9 |
I can't feel a difference because I never flew it with the wire. Too much curvaure to enter the guides at each end IMO.
#10 |
with my flying , no difference but like the looks
#11 |
My HF Map location Join Date: Jul 2007
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
Is there enough gap between the rod and the guide to fit a piece of Teflon heat shrink tubing? I had that on my Logo 500 and it really saved wear on the rod where it made contact with the guide.
BTW: I've always flown the stock pushrod on my Atom 500 and 6HV and never had a problem with it. My Knight 3D had a CF pushrod but only because I relocated the tail servo to the front to get it out of the exhaust slime.
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Nankin Hobby Field Rep, Compass Support Team Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX Experience is something you obtain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
#12 |
so it's more a piece of eyecandy then ?
#13 |
On the Century rod kit, the answer is "no - there isn't room for heat shrink...would need to ream out the bushing in the guide". I removed the bushing completely, and the guide is only a very loose fit to prevent excessive deflection.
As to eye candy, I never thought of needing it as such...I hated the notion of control rod binding when everything I was reading on this model related to sticky tail control causing wags. Simple as that. No binds, no wags. Fly what you want. I do. It certainly isn't required. But, another approach likely is needed. For example, polish the stock rod with 600 wetodry sandpaper to get it very slippery in the guides. They say it works well that way.
#14 |
i actually have no problem whatsoever with binding or sticking...
i recently also did some teflon grease in the guides and now it slides like a wet piece of soap :-) - Sent from my iPhone using Tapatalk
#15 |
Binding is also alleviated by not putting the guides too close to either end of the boom. Another consequence of extreme guide placement is if it's too close to the tail case, the slider control arm will eventually flex enough to rub against the bottom of the tail case or tail fin clamp unless you put a small Z bend in it.
#16 |
I just felt the guide set had the support centerline too close to the boom for best design. I know it may well have worked fine. I just chose the carbon route. To be safe, I kept my wire set and guides in a safe place with the wire stored straight so I could put it back in if needed.
#17 |
me too
#18 |
me too.
Atom 500 V-bar FANG IT! |
