Go Back   HeliFreak > R/C Helicopters > Painting and Airbrushing Tips / Techniques
Painting and Airbrushing Tips / Techniques Painting and Airbrushing Tips / Techniques
Old 03-23-2007, 02:25 PM   #1
Mike SVOR
Default Fuel proof paint in clear?
Does anyone know if there is a clear fuel proof paint for nitro?
Raptor Titan .50
Blade 400 modded: servos, carbon blades etc
Li-po batts: They puff when you cook `em.
I think you need a broom. - GunnyGlow
Mike SVOR is offline        Reply With Quote
Old 03-23-2007, 02:49 PM   #2
Kurdy
All car paint are fuel proof including the clear. Real car paint, not Tamyia car paint :wink: .
Real men can put the brand new chopper on the kitchen table, brag about it, and get sex the same night...
Kurdy is offline        Reply With Quote
Old 03-23-2007, 03:53 PM   #3
Mike SVOR
What about the car paint found at walmart and places? I think they're duplicolor car paint.
I read the can, but couldn't find where it stated if it was epoxy enamel or not.
Raptor Titan .50
Old 03-23-2007, 04:27 PM   #4
WJackson
Can clears will last for a little while. You need the two part automotive stuff to last. Easiest way is to get the colors done and prep for clear and take it to an auto body shop.
Bill Jackson
Team AlignUSA
WJackson is offline        Reply With Quote
Old 03-23-2007, 05:50 PM   #5
squintsf16
Rustoleum is fuel proof.
squintsf16 is offline        Reply With Quote
Old 03-23-2007, 10:14 PM   #6
Mike SVOR
lol, no it's not. Axe me howe I no
Raptor Titan .50
Old 03-23-2007, 10:18 PM   #7
Mike SVOR
I have a compressor and an hvlp gun, but it's too big to paint this raptor 50.
I've never bought auto paint in quantities smaller than a quart. But it looks like I'll need an air brush gun size and less than a quart of paint to do my raptor's body.
I was just wondering if the auto paint found at walmart/discount auto was epoxy enamel or whatever. (fuel proof)
Raptor Titan .50
Old 03-23-2007, 10:32 PM   #8
Rodan
You should be able to get paint from an auto paint supply in pints. Another option is House of Kolor paints, which IIRC can be obtained in smaller amounts. Try eBay...
You can use a touch up gun for the raptor canopy's base color, then airbrush the detail stuff...
TRex 600E/ JetRanger
TRex 600E/ AStar
"we are the people our parents warned us about" - J. Buffett
Rodan is offline        Reply With Quote
Old 03-23-2007, 10:49 PM   #9
WJackson
I used duplicolor and it held up for awhile , w/ 30% it got gummy on the exhaust side , so i would have to say no . A harbor freight touch up gun and a quart of clear and hardener and your set. Suppose mentioning NEVER breathing that clear goes without saying, that stuff WILL kill you.
Bill Jackson
Team AlignUSA
Old 03-24-2007, 09:56 AM   #10
Rodan
That's a very good point to mention, as most haven't dealt with paints before. Most auto quality clears are quite nasty... definitely set up good ventilation, and wear a respirator...
TRex 600E/ AStar
Old 03-24-2007, 11:38 AM   #11
sleddog7
Not true! ONLY their epoxy paints are. You can ask me how I know this too.
Top Flite has flat and clear topcoats in spray cans that are good to 15% nitro but Do end up breaking down after time.
AMA# 365566 AOPA# 5081747
AMA Turbine # 15130
... Intercepting the Localizer...
Guidance by Futaba 14MZ Heli 2.4 GHz ......FUTABA-- Always Imitated, Never Duplicated
sleddog7 is offline        Reply With Quote
Old 03-25-2007, 03:35 PM   #12
ferincr
Can you just use spray paint and then over coat with the two part automotive clear on top? Or the 2 part clear would make the "cheap" underneath color paint to run?
Fernando
ferincr is offline        Reply With Quote
Old 06-30-2009, 10:22 AM   #13
JC PAINT WORKZ
I spray full cars w/out a respirator.. oh well.. i wouldnt image in a open area the canopy would harm you lol
JC PAINT WORKZ is offline        Reply With Quote
Old 07-03-2009, 12:48 AM   #14
X-Gear
why would you think that its too big? Narrow the fan and don't pull the trigger as far, I only use my big Sata gun for shooting bases and clears no matter what size of piece i am painting. Much better and consistent coverage.
X-Gear is offline        Reply With Quote
Old 07-03-2009, 01:12 PM   #15
X-Gear
by the way, a 50 size canopy takes a little more than an ounce per coat(includes over spray loss), I usually mix up 4 ounces, this will give you a tack coat and 2 wet coats. (I have clear left, but its better than running out). It takes much less base color than clear.
Old 07-08-2009, 03:44 PM   #16
Gregg
I have been told that Dupli Color Engine Enamel Clear is fuel proof. I've cleared a 700 canopy with it and so far it's doing fine with 20% fuel. Will have to let you know later how it holds up in the long run.
Gregg is offline        Reply With Quote
