Go Back   HeliFreak > R/C Helicopter Support > Gasser Helicopters
Gasser Helicopters Gasser Specific Discussion
Old 07-13-2011, 06:55 PM   #21
kdsalas
Charging the battery to take it to my Friend Sana for the set up, the battery is permanent there with a strap for secure the dean, I charged the battery true the Gryphon Voltage Regulator I don't need to take it out, just plug & play.
KS
ID:	239792   Click image for larger version
ID:	239793   Click image for larger version
T-REX 600e DFC 3Gx /FUTABA 8FG
kdsalas is offline        Reply With Quote
Old 07-13-2011, 09:01 PM   #22
f22warzone
is that greas on your main gear, or why is it so black
also heli is looking good would be nice to have a gaser some day but i am adicted to the power of the electric lol .... but man the flight times you may have to get a chair
TRex-800E /Scorp 5035-478 5+5YY 1.8mm/VBar Blue Full 5.2Pro /CC Hv160/WR-Herc Super BEC/RJX 810mm 3D /RotoTech 115 + QuickUk Tail/ Hitec 7940th HV/TP 5000 65c
f22warzone is offline        Reply With Quote
Old 07-13-2011, 09:22 PM   #23
kdsalas
Thumbs up
THK, Yes is grease just a little but is fine there, the power of electric are awesome take a look of my Friend Sana, the one will set up my VBAR, all them have Electric, but I like more the Gas, maybe some day I get a TREX 600e
KS
Old 07-14-2011, 02:27 AM   #24
Azalin
Very nice. What conversion was that?
Trex 700 Gasser FBL | HeliBug HB7-RC 17T | Silverline V-Bar| TRM VX270TT | SG | RJX Gas muffler | JR x9503
Trex 600 Gasser FBL | HeliBug HB6-RC7 20T | Brain | GV-1 | Stock Zenoah G290RC | RJX pipe | JR x9503
Azalin is online now        Reply With Quote
Old 07-14-2011, 10:14 AM   #25
kdsalas
Thumbs up
HELIBUG MERCURY 800 HB8-RC YOU CAN CALL TREX 800
http://www.helibug.com/HB8.htm
THK for Ask
KS
Old 07-14-2011, 11:53 AM   #26
kdsalas
IS DONE !
THK TO ALL YOU LOL'S FOR LOOK
KS
ID:	239917   Click image for larger version
ID:	239918   Click image for larger version
ID:	239919   Click image for larger version
ID:	239920   Click image for larger version
Old 07-14-2011, 12:27 PM   #27
Azalin
Cool. Do you have any flight videos?
Old 07-14-2011, 12:40 PM   #28
kdsalas
Thumbs up
Soon, first the VBAR set up
KS
Old 07-14-2011, 05:43 PM   #29
kdsalas
Thumbs up
The Working Station for the Gasser is Ready she ask me for Gasoline
THK
KS
ID:	239971   Click image for larger version
ID:	239972   Click image for larger version
ID:	239973   Click image for larger version
ID:	239974   Click image for larger version
Old 07-15-2011, 06:34 AM   #30
Rototerrier
The gasoline is going to eat through and melt that nitro fuel line in about 5 minutes and you are risking a major fire hazard using a NITRO ONLY fuel pump.
Electric gas fuel pumps are usually very costly which is why most of us stick with manual. You need to get rid of that pump and swap out your lines with Tygon.
This is a disaster waiting.
TREX 700 Helibug GASSER 16t | µBeast | JR8717 | TRM 270TT | GV1 | R921 X9303
TREX 700 Helibug GASSER 20t | µBeast | DS610s | Hanson 29 3D Max | GV1 | R921 X9303
TREX 550 V2 DFC | AR7000 | µBeast | CC Ice 100 | CC BEC Pro | DS650 Tail | 520 Blades
Rototerrier is offline        Reply With Quote
Old 07-15-2011, 06:42 AM   #31
Bob8crow
Wink
Glad you are about ready to fly. Yea there will be a learning curve. But you will succeed.
fred
Bob8crow is offline        Reply With Quote
Old 07-15-2011, 07:03 AM   #32
kdsalas
THK for the info, I imagine about the Nitro Line I will replace it today what size do you suggest to buy ?, what fuel pump do you recommended
I find this one: http://www3.towerhobbies.com/cgi-bin...&I=LXB889&P=0#
THK
KS
Old 07-15-2011, 07:16 AM   #33
Rototerrier
Any hand crank pump will work. Just note the specs from the manufacturer, but most hand crank fuel pumps say gas or glow.
For instance, this one indicates for Gas and Glow:
http://grandrc.com/p17501/Ultra-Fuel...duct_info.html
But this one specifically says for nitro only:
http://grandrc.com/p17500/Manual-Fue...duct_info.html
Just have to be careful and get the right one.
Old 07-15-2011, 07:17 AM   #34
Azalin
This is what i use. Dubro Kwik. Works for gasoline and glow fuel.
http://www3.towerhobbies.com/cgi-bin...&I=LXJGS5&P=ML
Old 07-15-2011, 07:40 AM   #35
kdsalas
OK, I will buy ones you said or I can buy this one that said Gas & Diesel and I like the style: http://www3.towerhobbies.com/cgi-bin...&I=LXB889&P=0#
But I am confuse about the Tygon line, I do not know what size will be the correctly betwin this ones : 1/8, 3/32, 5/32 I all ready have a 5mm Gas RJX Line but the inside diameter is to little and I can't used on the fitting and on the fuel pump, maybe will work on my Gasser, please let me know the right size for the fuel pump & fittings
THK 1 More Time Lol's
KS
Old 07-15-2011, 07:53 AM   #36
Rototerrier
yes, the six shooter will work. And you can use 1/8 tygon. You can also use cheaper non tygon line like the stuff sold by Daves. It is cheaper but not quite as flexible. But again...it is way cheaper.
Old 07-15-2011, 08:01 AM   #37
Azalin
KS
This one looks nice.
Old 07-15-2011, 08:01 AM   #38
kdsalas
THK Lol's
KS
Old 07-15-2011, 08:17 AM   #39
kdsalas
I am waiting for some vibration gel for the electronics and next I will take my Gasser to my friend Sana for the VBAR set up, he know a lot of Electric & Nitro but I believe we don't know a lot about Zenoah Engine (G270RC).
I am wondering what HP do you suggest we need to star for my 800mm MB:
Head Speed:
Normal- ?
Idle 1- ?
Idle 2- ?
Throttle Curve:
Normal- ?
Idle 1- ?
Idle 2- ?
I read that the Nitro Curve is not the same from the Gasser Curve, let me know some suggestion and will star from there !
THK 1 More Time lol's
KS
Old 07-19-2011, 05:42 PM   #40
kdsalas
Waiting for the GasPump......
KS
ID:	241142   Click image for larger version
