| RJX RJX Helicopter Support |
hi all,
could anyone help me clarify these for me? I am looking forward to buying a motor for my 50EP and was wondering: a) whats the pinion hole diameter? is that 6mm? (meaning i need to buy a motor with 6 mm shaft?) b) the pinion sizes that RJX has? Is that 13 teeth and 14 teeth? thks a lot cheers |
#2 | |
the pinion hole diameter is 6mm, any 4035 scorpion or pyro 700/650 fits into it. the pinion size is 10t or 12t. you can use 90t, 93t or 100t main-gear. so you can find the perfect setup for you. it depends on LiPo setup (12s or 10s) which pinion/maingear to use.
just make some calculations for the HS you prefer. i think 1700-2200HS should be fine for a 50EP for slow flights and 3D. 4035-560 @ 10t/93t should be a very good setup with lots of power have fun with your new machine! good choice ![]()
Suzi Laos 800, 12s, CC ICE2 120HV, Gryphon Quasar, Align 800MX, RJX HV Servos, VBAR with Gov. RJX Xtreme 90EP, 12s, CC ICE2 120HV, CC BEC Pro, Align700MX 1.32 6+6D, BeastX Outrage F50, 12s, Jive 60HV+, 4025-630, BeastX Last edited by garfield2412; 07-01-2011 at 08:53 PM.. |
thks a lot for the advice..
i am planning to use the align 700MX motor which has a 6mm shaft. The scorpion and pyro ones are more expensive.. i read some good reviews about the Align motor..it should be ok, right? cheers |
whats the kv for your 700mx?
is it 470, 510 or 530? 10s or 12s setup? 510kv@10s@12t/93t should be very good for 50ep
Suzi Laos 800, 12s, CC ICE2 120HV, Gryphon Quasar, Align 800MX, RJX HV Servos, VBAR with Gov. RJX Xtreme 90EP, 12s, CC ICE2 120HV, CC BEC Pro, Align700MX 1.32 6+6D, BeastX Outrage F50, 12s, Jive 60HV+, 4025-630, BeastX |
i was thinking of getting the 510 KV..
i think i will go with the setup you recommended..RJX advises the same setup too.. i am a beginner at flying..So, i am not doing any sports flying etc cheers |
#6 |
readyheli.com/headspeed-calculator.html
Spoolup with Governor @ 65%: 1944 Spoolup with Governor @ 75%: 2061 Spoolup with Governor @ 85%: 2178 calculated with 10s, 700mx 510kv, 12t/93t, and align esc (governed) should be fine with your setup! good choice, 1944rpm for hovering and sports flyings will give you great flight times and smooth flight over all! the rjx helis are great! have fun with your build and i'm looking forward to your maiden!
#7 |
thks a lot..i am actually converting my nitro extreme 50 to electric 50..Just havent had time to do and ran out of funds to buy the parts..
I have spare main gears from the nitro RJX (these are 85 teeth i think)..Does the main gear from the nitro fit the electric one (neglecting the tooth count)? I calculated that if i use a 510KV motor on a 10 s setup, main gear teeth (85) and pinion teeth (12) i get a headspeed of 2264 rpm assuming motor efficiency of about 85%.. If ok, then that should do the work..I dont need to buy the 90-100t maingear.. (i have 2 spare sets from my nitro) cheers |
#8 |
hi,
sorry for the late statement, just some holidays :-) 85:12 should be also o.k. but i don't know anybody who flies this combo, beacuse it's not popular. but the math show's that it might be a good setup: http://www.ecalc.ch/helicalc_e.htm?c...1370&pitch=12° just change the parameters to your exact setup. maybee 85:12 (7.01:1) isn't as efficient as other setups, or the motor is pulling more amps.. but it should be flightable. just try it, if you aren't satisfied you can change main-gear (and pinion) later.
#9 |
Hello,
the 85T nitro gear is NOT good choise for electric.It can not handle the stress from todays high power brushless motors. Best is going with the 90T,93T or 100T gears. for 8S setup you can use a 740KV motor 10T/90 Best Regards Frank |
#10 |
dobble....
#11 |
I've been using a scorpion 4035-400KV on 12s.
12T pinion and stock 90T maingear. Works great and has a much smoother sound then the high pitched 10/100 setups I've seen. I did have to swap the motorshaft to 6mm though as it came with an 8mm shaft.
Faster Lower Harder |
#12 | |
hi,
sorry i somehow missed your post..I havent checked the RJX website these few days.. yeah it seems flyable..But it looks like from what Frank says, the gears cannot handle that much stress..so better not risk it then.. i was having some fun flying my align 250 these days..just got one to bash around.quite fun actually i am not dropping the RJX though..i like it.wish i could just fly a nitro engine around my place..sigh cheers Quote:
#13 | |
cheers |
#14 | |
for now not too sure whether i will go 10S or 12S..still thinking..we'll see what comes by yeah the motor shaft size and RJX pinion are 6 mm cheers |
