Go Back   HeliFreak > R/C Helicopter Support > Beam
Beam Beam Helicopters Factory Support Forum
Old 07-02-2011, 12:43 PM   #1
rjathon
Default bearing removal
Is there a trick for removing the bearings from the blade grips?
Thanks,
Russ
rjathon is offline        Reply With Quote
Old 07-03-2011, 05:26 AM   #2
dk31
They are supposed to come out using a feathering shaft and moving it in cycles applying a little force.
Sometimes they are really stuck and they won't come out. If they are damaged and they need change just use a hex driver and a hammer, reach the back side of the bearing through the blade and bang them gently.
If they are not damaged, apply some heat on the bladegrip (use a soldering iron). Don't overdo it or the bearing will be fried and ruined.
dk31 is offline        Reply With Quote
Old 07-04-2011, 12:51 PM   #3
rjathon
Thank you very much for the help.
Russ
Old 07-05-2011, 03:15 PM   #4
helicopter1
They will come out easier if you first use heat on the grips.
helicopter1 is offline        Reply With Quote
