Old 03-25-2007, 10:43 AM   #1
oscar
Default what tailsystem?
hi guys!
I'm looking for a new tail system like the tail system v2 form helidirect but that one is out of stock for over a month now..
I have the GY401 and s9650 combo and I'm flying a bit of 3D, I just want a tail that doesn't has all the slop like the stock plastic version.
What tail system do you have and what is your experience with it?
what is the best tail I can get for my t-rex?
cheers,
Oscar.
oscar is offline        Reply With Quote
Old 03-25-2007, 11:37 AM   #2
Pinecone
The V2 tail is the same as the HS1201-72 except the V2 version is a differnt color blue on the tail blade grips.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote
Old 03-25-2007, 03:27 PM   #3
Gary JP4
I don't think you can buy every thing as one kit. You need the HS1108 metal tail gear unit http://www.rchover.com/inc/sdetail/27926 then you could get the tail hub and holder assy, and slider parts seperatly or get the HS1201-72 all togather.
http://www.rchover.com/inc/sdetail/59593
All these parts came from this page http://www.rchover.com/t_rex_450_parts
T-Rex 450 SE, 430L 13t, Align 35A ESC, 325 Pro, JR 6102DX6, GY401, 9650, HS-65MG'S.
Gary JP4 is offline        Reply With Quote
Old 06-22-2007, 06:20 AM   #4
Funflyer
I just found out that I might be able to get a little money budgeted for the Rex after all. I've got the original plastic tail that comes on the CDE. Can I just get HS1201-72 or do I also have to buy the HS1108 metal tail case? I mean are they independent upgrades so that I could use HS1201-72 with the plastic tail case?
Funflyer is offline        Reply With Quote
Old 06-23-2007, 01:22 AM   #5
Funflyer
Anyone know if I can use the plastic tail case with the HS1201-72 upgrade?
Old 06-23-2007, 01:46 AM   #6
Big Fil
I got my complete V2 tail assembly from Wes over at Modefos. Email them and find out if they have them in stock. The whole assembly is not listed on the sight but when I asked he told me he could do a whole tail assembly.
Pinecone - The V2 tail is a little different than the V1 tail assembly. Different pitch slider and the hub is steel.
Mikado Model Helicopters
Edge Blades
Big Fil is offline        Reply With Quote
Old 06-23-2007, 03:19 AM   #7
Funflyer
I think the HS1201-72 and HS1108 make up the whole tail assembly, right? My point is that I don't want to upgrade the whole thing because of budget restrictions. I want to remove the slop in the original plastic linkages.
Old 06-23-2007, 08:38 PM   #8
Funflyer
Old 06-23-2007, 10:29 PM   #9
SCHWARZ24
The version 1's are now coming with the new slider and steel hub.
SCHWARZ24 is offline        Reply With Quote
Old 06-24-2007, 12:18 AM   #10
Funflyer
Ok, then I should be good to go.
Thank you for the reply!
