Go Back   HeliFreak > For Sale Forums KNOW your buyer/seller ratings! No Price bashing. NO FIREARMS > Electric Helicopters - Only E-Helis
Electric Helicopters - Only E-Helis *No Commercial Ads - E-helis Only
Closed Thread
Old 07-03-2011, 07:08 PM   #1
mtnbike101
Default Miniature Aircraft Furion 450 BNF
I'm rebuilding my Furion 450 to replace main bearings, main gear, tail rotor pulley and kevlar belt after a season of flying. I'll be going through the entire kit replacing anything questionable with new parts and it will be like new upon completion. There's well over $1K in everything, selling for $550. More detailed pictures available upon request. Everything was purchased new by me and assembled with detail following the excellent build videos here on the Freak.
  • Fully assembled Furion 450
  • Align aluminum case with modified foam to fit heli
  • Hitec 5065MG (x 3) Cyclic Servos
  • Futaba 9257 Tail Servo
  • Futaba GY401 Gyro
  • XCell (Scorpion) Motor
  • XCell (Scorpion) ESC
  • Wireless Programming Card
  • Spektrum AR6011 Receiver
  • Fusuno FG Canopy
  • Curtis Youngblood CF Blades
  • Foam Blade Guard (1)
  • Manual on OEM CD
  • OEM Canopy Stickers
  • OEM Box
Spare Parts:
  • XCell Crash Kit (1)
  • HeliDirect CF Blades (1 pair)
  • HeliDirect Wooden Blades (3 pair)
  • 3D Pro CF Blades (1 Pair)
  • Tail Boom (1)
  • Main Gear (2)
  • Hardened Main Shaft (2)
  • Kevlar Belt (1)
  • Flybar (1)
  • Hardened Head Axle (4)
  • Threaded Control Rods (2)
  • Boom Support (1)
  • Main Bearing (1)
Thanks for looking!
ID:	238200   Click image for larger version
Name:	Furion Parts.jpg
MSH Protos CF Stretch FBL - Mini VBar, Spartan DS760\9257\9650's
T-Rex 250 SE FBL - Mini VBar, KDE Bottom plate, KBDD tail blades
mtnbike101 is offline
Old 07-25-2011, 04:29 PM   #2
mtnbike101
Finalizing the build tonight (setting pitch, checking for CCPM, etc.).
Also, there are many more extras than I previously noted. This will be one heck of a deal for someone wanting the best 450 class helicopter out there. I have only hovered this heli, no FFF, no 3D, just hovering. I went through everything end to end to ensure all bearings were smooth and it was as close to new as possible.
The following components were replaced with new:
Main Bearings
Lower Bearing Block (messed up the original removing bearing)
Main Gear
Main Shaft (Hardened)
Autorotation Hub
Autorotation Sleeve
TailRotorPulley Hub
Tail Rotor Belt Pulley Bearings
Tail Rotor Pulley
Belt
The following are included on or as part of the heli:
Align aluminum case (never used)
Hitec 5065MG x 3 Cyclic Servos
Futaba GY401 Gyro
XCell (Scorpion) ESC Wireless Programming Card and IR Remote
Fusuno Canopy
The following are the spare parts included with the purchase:
XCell Crash Kit (1)
XCell Carbon Fiber Flybar Lock
XCell Carbon Fiber Pitch Gauge
XCell Foam Blade Guard (1)
Tail Boom (1)
Main Gear (2)
Kevlar Belt (3)
Carbon Fiber Boom Support (1)
11T Pinion (1)
13T Pinion (1)
Head Axles (3)
Tail Rotor Blades (2)
Flybar Control Link (2)
Plastic Ball Links (numerous)
Carbon Fiber Blade Grips (1 complete set)
70 Durometer O-Rings (4)
90 Durometer O-Rings (4)
Canopy Grommets (4)
New Style Head Shims (2)
Threaded Control Rod (2)
Original Canopy Decals
OEM Manual on CD
OEM Box
OEM ESC Metal Box
ID:	242348   Click image for larger version
ID:	242349   Click image for larger version
ID:	242350   Click image for larger version
ID:	242351   Click image for larger version
ID:	242353   Click image for larger version
ID:	242354   Click image for larger version
ID:	242355   Click image for larger version
Old 07-29-2011, 04:56 PM   #3
mtnbike101
Flying High Again
Old 07-30-2011, 11:05 AM   #4
mikestiles
Will you be up to trades.
mikestiles is offline
Old 07-30-2011, 02:33 PM   #5
mtnbike101
PM me with what you're thinking.
Thanks!
Old 08-13-2011, 07:16 AM   #6
Supersix1
Still for sale?
Supersix1 is offline
Old 08-13-2011, 07:58 AM   #7
mtnbike101
Yes, it is still for sale.
Old 08-24-2012, 10:20 AM   #8
mtnbike101
This heli has been sitting on my desk and has not been flown since the major rebuild last year. Thought it was time for a bump. lol
If anyone wants just the airframe and parts, let me know. I can always use the electronics on another project or sell separately.
Closed Thread
Tags
450, bnf, furion, miniature aircraft
