Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCP X Brushless Mods
mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions
Old 09-10-2011, 05:23 AM   #281
dna001
Will this fit in a standard frame, Think people would like to know this before they get one :-)
T-Rex 700N LogicTech 6100----Chaos 700FBL KDS Ebar
T-Rex 600N FBL OS55--------T-Rex 550FLB Spartan VorTex
T-Rex 450-6S BeastX ----- Blade 130x ---- Nano cpx BL -- McpX BL
dna001 is offline        Reply With Quote
Old 09-10-2011, 05:32 AM   #282
liftbag
Default Turbo Ace 915 TX settings
I adjusted the throttle curve to have a high head speed and still robust.
Now I can do 3 minutes of full power flight with Thunder Power 325 mAh 65C putting back 260 mAh.
[EDIT]
I fly 3' 30" al full power with wowhobbies linear 400 mAh 20C lipo, putting back 300 mAh.
My Dx8 settings.
Throttle curve
  • Normal: 0 - 33 - 67 - 74 - 85 Expo: ini
  • Stunt1: 88 - 77 - 70 - 77 - 88 Expo: Act
  • Stunt2: 93 - 82 - 75 - 82 - 93 Expo: Act
Pitch curve
  • Normal: 30 - 40 - 50 - 75 - 100
  • Stunt1: 0 - 25 - 50 - 75 - 100
  • Stunt2: 0 - 20 - 50 - 80 - 100
Travel pitch: 70% pos/neg
Dual Rate / Expo
Aileron
pos0: 100 / -20
pos1: 100 / -5
pos2: 100 / +10
Elevator
pos0: 100 / -10
pos1: 100 / +5
pos2: 100 / +20
Rudder
pos0: 125 / -20
pos1: 100 / 0
pos2: 100 / +20
Gaui 200 Beastx - An unknown number of bl converted Blade mCP X.
liftbag is offline        Reply With Quote
Old 09-10-2011, 05:44 AM   #283
liftbag
I just tried to mod an old plastic frame to see if the motor turns freely, and there are no problems in this regard.
If the servos had to touch the motor, I see no particular difficulties in fitting a washer under each screw.
In this case, the angle of the servo that fits in the plastic pin, would not have a solid support.
Is very easy to cut off the pin and make a third hole for the fixing of the servo with three screws, placing a washer again
Old 09-10-2011, 06:56 AM   #284
dna001
Excellent thank you.
