| Hurricane 255 Discussion and support of the Gaui Hurricane 255 |
I have hyperion ds11 amb
and im disappointed,the case cracked on 2 of them with 2 flights no crashes and one is really weak. These are brand new. the jr 285's I have in my 200 are working great. im gona try the savox metal gear digitals. http://www.amainhobbies.com/product_...ed-Micro-Servo
Dx8 mCPX bl v1 hp05s130X GauiX2FESds11,ds95i beastx Gaui X5FES,AR7200BX,Xera4020Torq9088,9188 |
Savox 0257mg's on cyclic (aka the infamous Align DS410's) been working perfect but may upgrade to MKS DS92's in the future.
MKS DS95i on tail & I am in love...
Compass, ProStar Hobby, Giant Power, OnlyFineHelis, Protek/Amainhobbies 7HV, Warp, 3D+ Lincoln To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. ):> |
Hi Lazor22,
Not liking the x2?? Notice you are loving the 95i but have an X2 for sale, let me know please as I'm thinking of pulling the trigger on an x2... |
Going to be going with DS95i on tail and will be trying the new DS92 on cyclics... Should be good!
Blade mCP X - Brushless, XP-7A, HP05S Gaui X2, BeastX/Scorpion 3400kv/YGE-30A/GS-093/DS95i Align AH-1 Cobra (T-Rex 500) Align T-Rex 600 EFL Pro, SK720/600MX/YGE-90HV/BL9180/BL9188 |
Yea the DS95i is freaking awesome. I'll send you a PM about the X2.
#6 |
Thanks for the stickeys nexgen
this thread needed them . Here a update to my post hyperion ds11-amb cyclics. There a tight fit, but Working great, no more cracked cases Outrage os7654 tail, mini servo, kinda big but works great
#7 |
Running Futaba 3156mg on the swash and innolab 261 on the tail in my X2.
//Dennis
Mini Protos FBL Stretch - 4s MSH Brain : Protos FBL Stretch - SK-720 : Protos FBL Stretch Night flyer SK-720 SAB Goblin 500 Ikon : Logo 600 FBL V-bar, 10s : SAB Goblin 700 Vbar, HK5020, Hawk 120A |
#8 |
I have Ino-Lab HG-D202MG on the swash and MKS DS95i on the tail.
Ino-Labs have been more crash-proof than I have expected. I haven't stripped a gear yet but two cases have broken (mounting tab broken). MKS DS95i is an awesome tail servo!
Gaui EP200 FES & V-Bar Mini Gaui X2 & V-Bar Mini MiniProtos stretched 6S & V-Bar Mini Blade 130X & Walkera Mini CP sub-micro FPV setup |
#9 |
Ahhh,
I have to get one. I think I wore out my outrage tail servo. It did really good for a while. but flying 6 packs everyday for a few weeks, well its not holding anymore. It doesn't wag, but on inverted backwards flight, I go to flip upright half way I do a pitch stall, and bam full blow out. I had 3 hard blowouts today, I disected the tail and its fine. gotta be the servo, I want a brushless servo , is the ds95i brushless?
#10 |
#11 |
3 x Inolab D202MG on swashplate and Inolab D201HB on the tail
Ciao, Egidio
GAUI addict: EP100 PRO, EP100 V1, EP200 V2 BeastX/satellite, EP255 BeastX/satellite. Now, TREX 250 SE BeastX/satellite as well. |
#12 |
Hey guys have just brought the X2 FES with beastx and im having troubles, heli just seems unstable.. and is not liking tail bit wobbly/waggy, if possible would someone please post a beast x setup and just general do and donts, ideal 3d pitch range ect with the heli.
thankyou |
#13 | |
You will probably get more info on the beast forum, as the tuning instructions are the same for pretty much all helis.
-DX8 -MSH MiniProtos Stretched, SK720, DS95/DS95i, Hyp 4S 25C 2500mAh -MSH Protos Stretched, Brain, Hyp DS16/BLS251, 6S 3000mAh |
#14 |
So can someone with a x2 beastx post there setup?
Give him a starting point, and then he can tune it in. I know for smaller helis, the pots are going to be lower than Stock(9o'clock) The tail has to be tuned by setting it in the lowest headholding gain In the parameters, get the highest gain without wag, in flight. This part is best to get help in the beastx forum, if the tail mechanics Are the problem, this forum is best. Make sure it is bind free, and moves really smooth. End points must be before it maxes out, servo ball on horn must be right too. I get as close to center as possible, while still getting the full throw left and right. Just post your questions in this forum and we will help you out.
#15 |
My 255 (almost X2) with Microbeast V3 has the Pot.1 and Pot.2 a bit under 9 o'clock and Pot 3 at 9 o'clock.
The 255/X2 rotor geometry is perfect for the Microbeast and does't need mods. See the attachment for my other setup/parameter points.
#16 |
Will these work on the cyclic of the X2?
Hyperion DS09SMD
Gaui X5/AR7200BX Nano CP X BL |
#17 |
Hope so as thats what i'm using
X2 SK720 MINIJAZZ 20 / WARP 360 SK540 KOBY55 / E5 SK540 YGE120LV / LOGO 550SX SK540 HELIJIVE 120 / 7HV SK540 YGE160k / 7HV SK720 YGE 120k / TDR SK540 POWERJIVE 120 / Futaba18mz / Skookum support rep |
#18 |
Yep, thats what I am using.
#19 |
Thanks Gents
#20 |
Anyone using the stock servos that come with the combo? How are they performing?
