Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 07-09-2011, 01:19 PM   #1
nukesrus
Default 550 in phoenix
Does anyone here use phoenix sim and fly the 550e 3g? I was curious how it flies compared to the real one, if so have you tuned it up to fly like the real one?
Sent from my DROIDX using Tapatalk
"it will be there in 30 min or less or the next 10 are free... courtesy of the 90th MW"
nukesrus is offline        Reply With Quote
Old 07-09-2011, 10:25 PM   #2
rxdi
Its pretty close, I have my 550 pitch set a little lower to tame it out a bit. So I normally use the 700 3g model on phoenix which is real similar to the way mine fly's in real life.
TREX 500 3G
Trex 550, AR7200BX, Jive 100 LV
rxdi is offline        Reply With Quote
Old 07-10-2011, 12:29 PM   #3
nukesrus
Ok thanks will be getting one real soon and just wanted to get the one on the sim as close as I could so I could practice some while im waiting
Old 07-10-2011, 04:16 PM   #4
mkovalcson
Are you using a USB adapter to your trainer plug so that you are using the same transmitter when training?
Mark
2011' Protos 500, 2014' Logo 550SX, 2012' TDR, 2015' Protos Max V2, 2016' TDR2
2013' Jeti DS-16
mkovalcson is offline        Reply With Quote
Old 07-11-2011, 10:35 AM   #5
nukesrus
Yes I am, using ny dx6i with the cable that came with the program
Old 07-11-2011, 11:01 AM   #6
dct
I have been flying helicopters for years.... No one ,,, I repeat ,,, no one should judge how a REAL rc helicopter flies,,, using a sim!!!!
No way no how!!!!
**Now doing EASY 3D!! And having a Ball !!**Trex 550e FBL V2 AR7200BX with CC BEC PRO ,And
T-rex 450 Pro, DFC with AR7200BX , Blade 300CFX, and Two, Blade 130X , Blade 350QX .!
dct is offline        Reply With Quote
Old 07-11-2011, 12:44 PM   #7
markleyland
No Sir-ee Bob, not the same, it is was it is and it aint what it aint.
"Sort your head out and fly with your heart"
Trex 450 SE V2: 9257 tail, Spartan Quark, HS65mg cyclic, DX7-AR7000, NEU 1107h/2y, Jazz Esc,
Trex 550 FBL: Jive 100+LV, KDE/NEU 1907H/1/N42, Vbar 5.3, Futaba BLS 251
markleyland is offline        Reply With Quote
Old 07-12-2011, 02:22 PM   #8
trickybit
Anybody else have odd problems with the tail on the 550E in Phoenix, when doing extended piro maneuvers?
PRTOS 500 Plastic, Logo 550SX/600SX, PRTOS Max2 up and flying!
Team MSH USA, Team Cyclone, Team Xnova
trickybit is offline        Reply With Quote
Old 07-12-2011, 04:25 PM   #9
Raptorg2zman
+1 on that, Mine is an all stock 550e 3G. I think the real thing flys better, then again my laptop is REAL OLD Anyway Pheonix is great !
Jimmy R
SE Mass
Trex 450 / HK pro ,500esp, & 550e FBL
Blade MSR
Raptorg2zman is offline        Reply With Quote
Old 07-14-2011, 05:58 AM   #10
Simsel81
Same here when doing extreme maneuvers requiring high tail performance. Not nice, but can be fixed if you play a bit with the model parameters.
Best regards,
Simon
Simsel81 is offline        Reply With Quote
Old 07-14-2011, 01:02 PM   #11
Louie T
Best regards,
Simon
how did u fix it...can u post the settings on the perameters that u changed?
Louie T is offline        Reply With Quote
Old 07-14-2011, 02:02 PM   #12
whoodie
Change the tail fin area to that of the T700e. It fixed all funky tail behavior for me.
whoodie is offline        Reply With Quote
Old 07-14-2011, 02:41 PM   #13
trickybit
thanks... would be very happy to get this working, as the 550 seemed to fly pretty close to real.
Old 07-15-2011, 10:01 AM   #14
breathe rc
Yeah I get tail kicks in funnels. I will have to try your fix. IMO The sim is not the real thing, but it's close enough to save you a lot of money. The biggest difference is knowing when you crash there is a reset button, so you will fly more aggressive on the sim.
If there's better, I want it.
HDCell 500, Scorpion HKIII 4025-890,
Compass 6HVU, Scorpion HKII-4225LE,
9K4O
breathe rc is offline        Reply With Quote
Old 07-17-2011, 10:13 AM   #15
Simsel81
Problem nearly disappeared when I adjusted the "tail power tuning" parameter in the "fine tuning" menue to 150%. But I think there are different possiblities to fix it.
Regards,
Simon
