Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite)
Blade Helicopters (eFlite) Blade Helicopters (eFlite) CP, CX, mCX CX II, CX III. and others
Old 03-27-2007, 09:32 AM   #1
rstacy
Default Blade CP - The GOOD setup - Your mileage may vary
We have been pretty successful at getting our Blade CP to give decent 3D performance. In fact it is one of Kyle's favorite helicopters to fly. I am asked daily what mods we did to achieve this performance.
Here it is
Let me know if this helps or if you have any questions. - Ray
Here it is in action
This flight shows the trnsmitter stick movements
http://www.raymondstacy.com/pics/kylecpinset.wmv
http://www.raymondstacy.com/pics/bladecppro31107.wmv
rstacy is online now        Reply With Quote
Old 03-27-2007, 09:41 AM   #2
DebianDog
Cool!
Where can you buy all these upgrades?
Dan Da Dawg - JR X9303
Hexa F550 on 3S + 6S TREX 500 + 6S TREX 600 + Blade mSR + Blade mCPx2 Brushless + 12S Rave FBL ENV
DebianDog is offline        Reply With Quote
Old 03-27-2007, 11:07 AM   #3
rstacy
Everything except the paddles and fly bar came from Horizon Hobby.
The paddles came from Modefo's and the flybar stock came from the LHS.
Old 03-27-2007, 11:14 AM   #4
Skiddz
Which GWS motor are you running on the tail??
-Kevin
Skiddz is online now        Reply With Quote
Old 03-27-2007, 11:28 AM   #5
rstacy
The GWS EDP-50XC/CN12-RXC motor and EP-4530 prop with adapter is a good DD combo.
GinoCP who has experimented with different tail options more than I have has this to say about the DD tail
I had gone back to dual motor recently just to compare. The DD tail is really better than the dual motor. It runs solid in fast backward flights and does funnels better. Of course flying reverse with a stock or dual motor tail can be done, but with effort.
Old 03-27-2007, 12:13 PM   #6
slikrx
Awesome post!
Thanks!
Did you need to use the tail motor controller to eliminate motor burnout? I'm trying the DD setup from bladecprepair.com and I just burned out my first motor. (after ~20 minutes use)
Maybe sticky this?
Jeff MacDonald
SoCal
Blade CPP - mostly stock + G90
300 size frankenchopper
slikrx is offline        Reply With Quote
Old 03-27-2007, 01:02 PM   #7
rstacy
Originally Posted by slikrx
Awesome post!
Thanks!
Maybe sticky this?
I need this because we removed the stock receiver and installed our own. eventually the motor will still burn out but it should last longer than 20 minutes. They wont take any stalling. If the heli falls over and stalls the motor, you can almost count on a failure in the near future.
We have only had one fail and it showed itself in the form of starting to drift.
Old 04-01-2007, 02:31 PM   #8
chopperdudes
i might have missed it, what main esc r u running? eflight 20A?
also, r u running the 4100kv motor or the 3600? i'm guessing 4100?
chopperdudes is offline        Reply With Quote
Old 04-02-2007, 05:43 PM   #9
wick246
Thanks for the post Ray... I'm impressed with Kyle's ability and even more impressed with your support of him. Is flying your hobby as well?
wick246 is offline        Reply With Quote
Old 04-03-2007, 04:08 PM   #10
jorgy23
From the looks of it, you are using the stock tail for the CP and just attaching the rotor directly to the motor.
Actually making the rotor not as far out on the tail, Correct????
jorgy23 is offline        Reply With Quote
Old 04-05-2007, 06:23 PM   #11
chopperdudes
oh, and ray,
i've heard that john adam's or somebody has reversed the blade grips so that the leading edge is the control side and he said that collective was smoother. have you given that a try?
Old 04-05-2007, 06:42 PM   #12
rstacy
Eflite 20A controller and 4100 motor
Yes it. I have been flying one thing or another for 40 years.
Not exactly. We run the GWS EDP 50XC motor.
John Adams wrote in one of the latest heli mags. I have not tried it yet.
Old 04-06-2007, 01:12 PM   #13
Funky
Are you running the G90 in digital or standard servo mode?
More helis than brains
Funky is offline        Reply With Quote
Old 04-07-2007, 06:16 PM   #14
jorgy23
Can you give a little more detail on how you installed the bearing where the O-rings used to be???
Jeff
Old 04-07-2007, 06:54 PM   #15
rstacy
Digital mode
This mod is nice for extreme 3D response. It works best with high head speed and wood blades. You could get a wobble at lower head speeds.
Remove the existing o-rings and press in a bearing. Make sure the bearing is seated. Do this to both sides. Reassemble everything and see if you have any in/out play on the grips. If you do have play, take the grips back off and install a spacer on each side between the bearing and grip. I think we ended up with one spacer on each side.
Old 04-14-2007, 07:14 PM   #16
DannyCrane
What prop adapter did you use. I searched horizon for it but could not find anything that looked like it would work.
Danny Crane!
DannyCrane is offline        Reply With Quote
Old 04-15-2007, 04:22 PM   #17
futura
Look for the GWS DD tail set, the addaptor comes with it. or this one or such like it...
I can't vouch for the online dealer but I here lots of people buying from them with limited issues.
http://www.heli-fever.com/product_in...roducts_id=192
futura is offline        Reply With Quote
Old 05-10-2007, 01:40 AM   #18
WhirlingBladesOfDeath
My 3-in-1 pooped out on me yesterday. I had already converted the receiver to an AR6100, so the failed 3-in-1's only real job was as speed controller for the tail motor. Rather than paying $45 something for a new one, I just picked up a little GWS speed controller to replace it with. I wired everything up, and actually much to my surprise, it worked just fine!
My only problem is once the tail motor ESC arms (it appears I have to give full left rudder to show the ESC 0 input before arming) my G90 starts trying to move the tail gradually more and more to the left. If I just let the heli sit there at 0 throttle, the tail will eventually start rotating to the left all on it's own! So while everything works fine in air, it's a bit awkward on the ground. I have to hold left rudder to be able to stop the tail and unplug the heli when I'm done flying. :? I've tried trimming the rudder, and that will stop the movement on the ground, but then I have to counter the trim when in the air. Setting the G90 to HH or not doesn't seem to matter either.
Just curious if I'm missing something here? The stock 3-in-1 must have used it's main throttle input to counter this behavior? Hey, can I use Revo mixing to fix this! Hmm, did I just answer my own question?
WhirlingBladesOfDeath is offline        Reply With Quote
Old 05-10-2007, 02:08 AM   #19
OK, I was able to fix it sort of. I added a prog mix for Aux1 -> Rudd. When Aux1 is on, rudder is +40%. About 30% seemed to stop the tail motor, but it was still humming until about 35%, and I just kept going to 40% to be safe. I just need to remember to turn off Aux1 before liftoff or I'll probably have no tail response.
This can't be the "proper" fix on this? I'm curious how others have programmed around not having a 3-in-1, but still using a separate tail motor?
Thanks,
Jason
Old 05-10-2007, 08:43 AM   #20
jorgy23
Ok.. I have been trying to get all of the pieces to this setup but I can't seem to find anybody that has the DD tail motor. I can get the speed controller and all of the other parts but not the motor itself. does anyone know where I can find these easily. or does anyone have an alternative???
