Go Back   HeliFreak > R/C Batteries and Charging Support > LiIon, LiPo, NiCd & NiMh General
LiIon, LiPo, NiCd & NiMh General General Battery Support
Old 03-27-2007, 02:12 PM   #1
DebianDog
Default The basics of electrics - AKA Electricity for Dummies
What the heck is a volt, amp, watt, ohm, mah, C, etc...
Well here it is... all laid out for us thicker headed folks. Plus, it is kind of a fun read.
Dan Da Dawg - JR X9303
Hexa F550 on 3S + 6S TREX 500 + 6S TREX 600 + Blade mSR + Blade mCPx2 Brushless + 12S Rave FBL ENV
DebianDog is offline        Reply With Quote
Old 03-27-2007, 07:00 PM   #2
Jermo
The description of Volts isn't exactly accurate but it's good enough for non-Electronics types. The way it's written follows the analogy of water in a pipe.
Jermo
Jerry Moore, AMA #878954,TARANIS OpenTX- Pantera - Takes a licking and keeps on kicking! KISSAM = Keep It Simple Stupid: Affordable, Maintainable -
Visit Early and often - http://open-txu.org
Jermo is offline        Reply With Quote
Old 06-13-2007, 02:30 AM   #3
celter
The Volt would be the height difference between the water level in the tank and the end of the hose. A bigger tank would not increase the pressure (Volt)
Dragonus II Elite, Logictech 2100 with Futaba 9650
TT Mini Titan with Futaba 401 and 9650
Hurricane EP 550 with Futaba 401 and 9254
DX7 with AR 6100 and AR7000
Phoenix sim.
"I am a hard core 1D pilot"
celter is offline        Reply With Quote
Old 07-28-2007, 12:04 AM   #4
Fox222
Jermo
That is exactly how they teach it to 1st year electronics students. Or at least when I was in school a long, long time ago.
They donít need atomic structure, just how it reacts.
Fox222 is offline        Reply With Quote
Old 07-28-2007, 08:14 AM   #5
Jermo
I went through 2 years of electronics in High School, another 2 years in the Navy, then another 2 years for my associates. I've never heard that presentation.
Maybe it was given in the electrical class?
Old 07-28-2007, 12:23 PM   #6
Fox222
The water analogy has been used for years in electronics. But that doesn't necessarily mean they teach it that way everywhere.
When I was in high school I took an electronics class and the water analogy was the first thing we covered. Then when I went to tech. (also elactronics) I got it again the first day.
Old 08-08-2007, 09:26 AM   #7
6sic6
For those who feel really bright:
http://amasci.com/ele-edu.html
Some outstanding reads in there.
Username: I saw it on a license plate and giggled all the way home
6sic6 is offline        Reply With Quote
Old 08-08-2007, 10:42 AM   #8
DominicD
The Capi
Hmmmmmmmmmmmmmmmmmmmm Dog hmmmmmmmmmmmmmm. The analog is fine but there are alittle bit of misunderstanding or misleading sentences, but it's fine for our purposes. One thing that is really wrong is your discription of a watts "...Watt is a unit of work done over time". Work over time is Energy and has units of joules (Integrals !!! Hurray for calculus). BTW If the water in the hose is suppose to be the electrons then technically the water should be flowing from the ground back through the hose and into the tank.
DominicD is offline        Reply With Quote
Old 09-08-2007, 09:05 PM   #9
jance445
Default using the water, pipes, etc analogy...
What is the mechanical (using the water analogy) equivalent of a switching regulator vs a linear?
jance445 is offline        Reply With Quote
Old 09-08-2007, 10:20 PM   #10
DominicD
The Capi
A linear series regulator - A globe value that would let you control the volume of water (no this is not technically accurate but it works for the comparison to the others)
A linear shunt regulator - A little valve that drains the water from the main pipe so you can control the flow in the main pipe
A switching regulator - A ball valve that you open and close fast. The longer you leave it on compared to when its closed the more average water will flow.
While the flow of water is the analogy is current and regulator uses voltage just think of the current being converted to voltage by a resistor or something.
Old 11-23-2007, 10:39 PM   #11
alex_p_kiel
Volts in the electromotive force in a current or how fast it is moving. Amps is the electric potential or ammount of power. Watts is is volts x amps. Ohms is electrical resistance. From my own calculations, a "C" is about 2 or 2.1 amps. A miliamp is one-thousandth (0.001) of an amp. I don't know if I am forgetting anything.
alex_p_kiel is offline        Reply With Quote
Old 11-23-2007, 11:16 PM   #12
DominicD
The Capi
Amperes ARN'T the amount of power. Power is volts x amps.
Old 11-23-2007, 11:18 PM   #13
alex_p_kiel
Yes, amps is the amount of power, watts is a measurement of both amps and volts, the term watts is just a more general term.
Old 11-23-2007, 11:24 PM   #14
DominicD
The Capi
Sorry this is incorrect. Amperes is the measure of the number of coulombs per second through a surface. Power is the measure of energy over time or volts x amps.
Old 12-02-2007, 06:29 PM   #15
Pinecone
Amps is a measure of the the flow of electrons. How many flow ina given period of time. That is not power.
Volts is how hard the electrons are pushed through the circuit.
Power is the product of volts and amps.
Watts are not a measurement of volts and amps, it is measurement of the power. 10 amps at 1 volt is the same watts as 1 amps at 10 volts.
And 746 watts is 1 horse power. Again POWER.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote
Old 12-16-2007, 06:08 PM   #16
supergenius
What does the C stand for on ly-po pacs? Also, the S?
supergenius is offline        Reply With Quote
Old 12-16-2007, 06:40 PM   #17
wecoyote
C = Capacity
S = Series
P = Parallel
There is a very fine line between "hobby" and "mental illness".
Tom
wecoyote is offline        Reply With Quote
Old 12-16-2007, 09:52 PM   #18
supergenius
Originally Posted by wecoyote View Post
C = Capacity
S = Series
P = Parallel
...how do I know which one to buy? If I go up from a 10C 3S 2200mah to a 20C 3S 2200, will my speed-control have a heart attack? SC is a 30A Walkera. If I need to upgrade, what should I get?
Old 12-16-2007, 10:00 PM   #19
DominicD
The Capi
The C rating only determines how much maximum current your battery can supply. You motor determines how much current is drawn. Your esc doesn't care the least bit. If you motor doesn't need more then 10C your new 20C pack won't make any difference. If you motor was trying to draw more then 10C with your old pack your new pack will be able to provide the current your motor demands. As an example lets use a 3S 2100mah pack on a 35A esc.
35A / 2100mah = 16.7C max
which means going from a 20C to a 25C lipo is a big waste of money.
Old 12-16-2007, 10:23 PM   #20
spork
HFG,
I'm guessing there's a semantics issue here, because...
Watts is a measure of power, which is work (or energy) per time interval. Energy or work are measured in joules, and a watt is a joule per second.
Energy and work are synonymous (you say "work over time is energy").
As I said, I may just be misunderstanding you, because I suspect you know all this.
EDIT:
Looking back at this I think I see the problem. Is it possible you're confusing "work" and "power"? Work = Energy. Power = work/time (or energy/time same thing).
Nothing is ever as good or as bad as it seems.
spork is offline        Reply With Quote
