Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > 4G6 / V120 Series
4G6 / V120 Series Walkera 4G6 / V120 Series Helicopter Support
Old 07-11-2011, 08:29 PM   #1
w4llet
Default V120d05 action shots
Helo pilots.
After reading several threads on this forum, trying to learn how to fly a 6ch, I start training in a simulator.
After some work, I decided to start with fly at open area.
Theses are a few action shots from my 3rd flight.
Btw. This heli is just awsome. And fly like the big ones.
w4llet is offline        Reply With Quote
Old 07-12-2011, 08:14 PM   #2
rhaybr
E ae cara blz ?!? então to querendo comprar um heli igual ao seu só que to com o pé atraz.... mta gente falando mal dele =/ por causa do Belt Tail que tem uma resposta lenta.... dai eu queria te perguntar o que vc ta achando dele ???
rhaybr is offline        Reply With Quote
Old 07-12-2011, 08:42 PM   #3
Creaky Cactus
From Google Translate
Portuguese - detected to English translation
E ae blz guy?!? then wanting to buy a heli like his only contact with the foot Ago .... mta people talking bad about him = / Tail Belt because of that has a slow response .... there I wanted to ask you what you think of it ta??
The Cactus - Just pick up the sticks, and FLY!
Blade (mCX, CX2, mSR, mCP X, mCPX BL; 180 CFX, 400) * T-Rex (450SE2, 600E)
Blade (Nano QX, 200 QX) * DX7 * Phoenix v5.5k
Helis and MRs wrecked while-U-wait since 2008-05-27
Creaky Cactus is offline        Reply With Quote
Old 07-13-2011, 01:37 PM   #4
raptorddd
wow nice pucs man
raptorddd is offline        Reply With Quote
Old 07-15-2011, 11:33 AM   #5
milliotseb
I hope that my V120d02 will fly so nice one day
By the way, is the V120d05 flybarless/receiver module better than the one from v120d02?I heard that the one from 4F200 is better.
milliotseb is offline        Reply With Quote
Old 07-16-2011, 12:21 AM   #6
w4llet
Cara,
Eu nao tenho muita experiencia para te aconselhar sobre isso. Eu saí de um 4 canais direto para este de 6 canais. Treinei por 3 meses no simulador e as fotos foram feitas no meu terceiro voo. O trava cauda é perfeito e realmente a cauda realmente não é muito rápida. Se aumentares o rpm a resposta é bem melhor.
Talvez não seja o mais indicado para 3d extremo, mas é excelente para vôos ágeis e com velocidade. É ágil também. Bem ajustado é extremamente estável e responde muito bem aos comandos.
Até agora só posso apontar dois defeitos: É um pouco chato de achar o centro de gravidade, porque a cauda é um pouco pesada. Você tem que posicionar bem a bateria. E o segundo, o trem de pouco é muito fraco, quebra fácil. Tirando isso, é um tanque. Voar sobre gramado é quase indestrutível. Em uma batida não chega a estragar nem as hélices que são de isopor endurecido. Com baterias de 900mah eu consigo voar cerca de 8 minutos, o que considero excelente.
Dou nota 9,5.
Mas se teu receio é o comportamento da cauda, olha para o m120d01.
Eu recomendo e compraria outro v120d05. Quando ele começa a voar, todos param para ver ele voar e ficam admirados. E se fores comprar, gaste um pouco mais com radio 2801-pro. Realmente é bom e podes configurar todo o helicóptero através do tx.
English:
Dude,
I do not have much experience to advise you about it. I left a 4-channel direct for this 6-channel. I trained for 3 months in the simulator and the photos were taken on my third flight. The gyro is really perfect, but tail really is not very fast. If you increase the rpm the response is much better and holds better in throttle kicks.
Maybe not the most suitable for extreme 3D, but is excellent for speed and agile flight. Well trimmed and set is extremely stable and responds perfect to commands.
So far I can only point out two flaws: It's a bit annoying to find the center of gravity, because the tail is a little heavy. You have to position the battery well. And second, the landing skid is just too weak, break easily. Apart from that, it's a tank. Flying over lawn is almost indestructible. A crash is not enough to spoil even the blades that are made from hardened foam. With 900mah battery I can fly about 8 minutes, which I consider excellent.
I rate 9.5. I know people will crucify me.
But if your concern is the tail behavior, look at the m120d01.
I recommend and would buy another v120d05 if needed. When he starts to fly, everyone stops to see him and are amazed. And if you're buying, spend a little more with 2801pro tx. Is really good and you can configure all the helicopter through the tx.
Old 07-20-2011, 12:00 AM   #7
hjns
Very nice pics!!
What camera/lens did you or your friend use?
KR, Henk
Blade MCX, FBL 4G6V-2S Xtreme, FBL 4G6V-1S
Xtreme rewind, FBL 4G6S-1S Bell 222 Darthdark, FBL V120D02S
hjns is offline        Reply With Quote
Old 07-20-2011, 12:19 AM   #8
w4llet
thank you mate.
It was a nikon d90, with a 70-300mm nikkor vr lens.
Old 07-20-2011, 02:20 PM   #9
ifly_65
Nice shots. I took the three 'Hero' shots and put them through photoshop. I hope you dont mind.
Nikon 'ED' and Canon 'L' series are awesome.
ID:	241387   Click image for larger version
Outrage Fusion 50 Gaui X5,NX4,X2 NX4: Savox sh1250, sh 1257, Ikon, Hatori pipe, OS 37 X5: RJX 0521HV X2:MKS DS 95l Spektrum H3020 7200bx Scorpion HSC MCP X BL NCcraig Flashed TA 915 9t.
DarkMatterBlades.com
ifly_65 is offline        Reply With Quote
Old 07-20-2011, 06:11 PM   #10
w4llet
Wow!!!
Nice treatment!
Old 07-20-2011, 10:16 PM   #11
ifly_65
Originally Posted by w4llet View Post
Wow!!!
Nice treatment!
Thanks, its Photoshop 7 (very old version). I did an unsharp mask to sharpen and curves. On the curves (control M), I use two points on the graph, one high and one low to adjust the exposure.
Here is another...
Old 07-22-2011, 09:26 PM   #12
helimaniac88
I just bought the v120d05 with 2801 for the same reasons. I like the belt, the shaft tail on my two other walkera minis isbt too bad, but wanted to try something different. I don't do 3d but like to sport fly aggressively and the 05 seems strong and stable. I also think that with the mods available it is excellent for everything but extreme 3d. I also figured if it eventually felt underpowered and my skills warranted, there are plenty of reasonably priced monster motors!
helimaniac88 is offline        Reply With Quote
Old 07-22-2011, 09:49 PM   #13
w4llet
I agree with you helimaniac88!
V120d05 is a sweet machine. It can flies pretty fast and incredible stable. And belt driven is not that bad. At least for me.
I start training 6ch heli in this one. So you can imagine how many crashes i did. I can tell you. Its strong, very strong.
I still point one flaw. Landing skids too weak.
Do you know any mod to landing skids to this v120d05?
When I use storm 20c batteries the bird have more power, flight last longer and headspeed is higher since take off. Its a nice battery, much better than the stock one.
Btw, the new stock landing skids are coming with a battery limiter at the end. I think is to force you to put battery a little more to the front (around 1cm) and helps the cg problem... Anyway, its a impressive heli and the all-in-one receiver is very good. You can change the whole heli behavior just turning a few pots.
Old 07-23-2011, 09:00 PM   #14
helimaniac88
I just got the 05, but have a d01. The pots do a lot to the behavior of the heli. Take a picture before touching anything. Small moves and only 1 pot at a time!. I am going to see if I can modify a set of extreme lg for other v series. To be honest I really don't like the battery holder in the 05 lg. I have to put the stock batteries in from the FRONT. Not sure if this is correct but they didn't seem to fit the way the other v120 heli batteries go. I just flew it a second, the tail blades came bent badly so even with bending them back they were not perfect. Helidirect sent out a new set right away no questions asked. I order from them, club heli, and wow normally for walkera stuff. All three are good but heli direct and club heli are fastest. Anyone do any of the mods for the tail yet? I will wait before trying any to see how it is. I have a v120d01 and 4#6 and though they have been reliable and really have given me few problems (keeping the main gear/small tail drive
Old 07-23-2011, 09:07 PM   #15
helimaniac88
Oops ... Continued,
Gear Well lubes keeps the gears from stripping almost 100%). I think the 05's extra mass and bigger motor makes it a bit more stable platform for sport flying and probably mild 3d. I think that it looks awesome also. If I do hot rod it out some time the belt drive has more power handling potential. I don't mind running higher head speed /lower pitch to keep the tail spinning fast enough, this tends to give more stable response anyway. Let keep each other posted on any possible tail issues and tips each other use to help it, I'm sure if there are any they should be fairly easy to resolve.
Old 07-24-2011, 09:52 AM   #16
w4llet
So, do you lug the main gear?
What do you use to lube it?
Silicone grease?
And you are right, battery is loaded in from the front. And you need to remove the canopy. The 4g6 and v100d01 you load in from the back. I am pretty sure they made it with this orientation to force you to leave the battery to the front as much as possible due tail heavy....
Like I said before, if you buy a new LG, it comes with a new battery limiter on the end. So, now, battery stays 1cm plus to the front than stock landing skids. Much better CG balance. Bad news is that I had to make two new little holes in the canopy, 5mm away than stock holes and put new rubber rings to wear the canopy without making that little carbon rod pin (the one that locks the servos holder) forcing in "U" shape.... In other hand, now v120d05 is 1cm longer... ROFL
Old 07-25-2011, 03:23 PM   #17
helimaniac88
Wink
I have tried a few different products for luging the gears. I put a dab of regular lithium grease for auto use on the little gear before putting main gear on, then lightly lube around the main gear and pinion. Because it worked so well and I didn't have to change the gears for so long I occasionally spray a bit of silicone lube through the side of the main gear so I know it gets in to the small gear underneath. I also keep the rear gear lubes, though these usually are not a problem. I wanted to use a 46 canopy until I was comfortable on the 05 and found if I cut the slits out 2here the lg go through the canopy on the bottom it actually works well, no need to make new holes! Give that a try. I have a replacement lg at home, I have to look to see if it has the battery stop, I do not see one ostock lg. They make it so damn tight though to fit even stock battery in! It seems that the wrapping of the lipo gets caught all the time. I hate it!
My little swash phasing thing broke on second flight just the other day. I keep reading how crappy they are but that was ridiculous. Any mods to help that? I ordered the microhelli today.
I ordered a v120d02 from xheli also.....the addiction continues! I just could not pass up $139.99 from xheli. They seem to be stocking less and less stuffs I don't order too much from them. I was looking at the costs of converting my 4#6 to a d02 and added it up, made more sense too just buy new one. Not sure how come they sell that one solo cheap, no one could match price. I'm going to practice with the 02 and mod up the 05 as my muscle mini.
Any one put any thought into motor upgrade?
Lots of threads on best motor for the 02 but not too much on 05.
I'm actually a bit confused. The new spin motors seem great, the 16400 and now the new 14000 kv. From what I read the new 14000 is more powerful than the 16400kv. Supposedly they both make more power than hp08s. I also see the wow 12g motor but have not read much and don't feel like buying one and finding out the version two is the one that really works if I waited!
What I wonder is if any of the old faithfull 1s v120d02 upgrade motors will be big improvement over new stock out runner? I like that they weigh less than stock motors, anyone know if they put out more real power? I don't want to go to 2s if I don't have too. Mind you I don't even fly 3d, just want to own a rad micro that can jump 20 feet instantly on a pitch pump!!!!! I just think it's cool to have the power. Then I can maybe try to find a way to mod my v120d01 or the 02 I have coming with the 05 stock motor, I think there is some frame modification and an esc change to make that work. Anyway if anyone has recommendations for best upgrade d05 motor 1s stock esc let me know. I was going to start new thread but figured while I'm here writing
Old 07-25-2011, 06:19 PM   #18
w4llet
Talking New action Shots!
Hehehhe,
Here goes more action shots!
Look at the wind effect over water! HAHAHHAHA!
Old 07-26-2011, 07:34 PM   #19
ifly_65
Nice!
Old 07-27-2011, 09:18 AM   #20
helimaniac88
Thats some nice flyin!!!! I love how close to the water you come. That takes nerve! I know the thing is stable but wow! how long you been flying cp? what else you fly? Love the shots, keep them comming. Any tips, obsevations, or mods? I dont see a dedicated v120d05 thread active, since weve all been flying this lets try to keep each other updated. I ordered a few new upgrade parts. The swash phase links from microhelli and the tail slider from microhelli are on their way. Also just got in a bunch of 600mah zippy batts last night from hk. my first time soldering and wrapping my own. I did two last night and tested one on my eflite sr120. These batts are awesome. They are also sooo cheap. They definitely dont fit the battery slot so I am going to have to mod that. They are significantly wider. Thinking of modifying my spare LG, cutting out the side where the batteries go, reinforcing above and below with 1mm ccf rod, maybe a bit of extra reinforcment on the front to compensate for the cut out section, and then I could probably still use the regular batts or my new zippies. If the stocks dont fit well after I can still switch betweeen the stock and modified battery frame lg setup pretty easily. Any suggestions?
Tags
action, flybarless, pictures, shots, v120d05
