| Skookum Robotics Skookum Robotics SK-360 SK-540 & SK-720 Digital Flybar |
A bit off topic but I ordered DSMX satellites with my new Skookum for the 600E PRO build.
I have DSM2 on my 600ESP and 500. In my DX8 can I run DSMX under one model setup and DSM2 under the other two? Or do I have to transfer them all to DSMX? Thanks Scotty
Goblin 700 HK 4525-520LE, SK720, Bl 9180, 9188, YGE160HV Goblin 630 Quantum 4135-530, SK720, Bl 9180, 9188, HeliJive 120HV Goblin 500 HK 4020-1350, SK720, Graupner HBS 660-770, YGE120LV, Trex 250, HK 2206-3900,SK720, DS95i YGE16A |
you can run dsmx remotes in dsm2 mode and tbh i would recomend this as dsmx has serious issues and my dx8 caused my fusion to go in !! as it has range issues
Fusion 50 sk-720 ,Fusion 50 v-bar , Velo 90 v-bar To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Outrage uk field rep... |
DSM2 is notorious for having lots of crashes in heavy use areas. DSMX is supposed to have solved that problem.
I recommend only running DSMX unless you live out away from any other radio traffic or cell towers. . |
#4 | |
georgi UK |
I don't see a diffrence in the 2
My larger heli is on dsm2, my 2 small helis are on dsmx Im not switching my large heli to dsmx, because what's the diffrence? I don't see, feel, a diffrence??? Ok so dsmx is faster, so I should feel that? 11ms ? Really ?? well i don't have super human speed, or the ability to slow time. So dsmx does nothing for me
Dx8 mCPX bl v1 hp05s130X GauiX2FESds11,ds95i beastx Gaui X5FES,AR7200BX,Xera4020Torq9088,9188 |
#6 |
because what's the diffrence?"
DSMX is supposed to work better, from an interference standpoint, in very high traffic areas (IRCHA for example, where the flight line is very long and several hundred transmitters may be on simultaneously. I have not used it, at this time. I am waiting for the dust to settle to see if it truly represents and improvement.
KBDD-Team Pilot Team Compass / ProStar Hobby Gens Ace Field Representative Warp 360, 7HV,Knight Pro,Knight 3D, Atom 500, Odin II, 6HV, 3D Plus, Knight 50 |
#7 |
ok I never fly at ircha, or anywhere with a lot of transmitters on.
The signal loss on dsm2 is so rare, I think it happened to me 1 time In thousands of flights over the 3 years I have benn flying. So how would we, the consumer really test this out, in a way that we can see the results? And then we can say, " oh yeah dsmx is better" until then I stick to my original statement " I don't see, or feel a diffrence"
#8 |
fusionsx00,
I am right there with you. I find DSM2 to be very reliable. If you never go to IRCHA, or one of these huge events (or indoor events), I don't see any issues with DSM2. "So how would we, the consumer really test this out, in a way that we can see the results?" I want to see what the track record is on DSMX a year or two from now. A lot of people will have DSMX by then (or, at least, I think they will), and we should be able to get some kind of data (albeit pretty subjective) as to how well it works. Again, I am interested in hearing what happens at IRCHA this year.
#9 | |||
One detectable difference I found: DSMx finds Rx faster on initial powerup, and so presumably also on lost Rx link recovery.
Jerry Trex 700N Pro fbl, 600N Pro x 2, 450SE v1, 250 v2 fbl, Compass 6HV fbl, Blade 450x, 400, 300x, 130x, mCPx, 120SR, mQx, mSR, Rotor Concepts HPQ1, Walkera CB180Q, CB100, Novus FP, CP, Esky Hunter, Big Lama. |
#10 |
Thanks Jerry,
I certainly didn't want to start a war with the post. ![]() Scotty
#11 |
DX8 with DSMx sats are working great so far on my 600ESP. And DSMx does indeed seem to connect faster than DSM2.
I think you've got nothing to worry about. |
#12 |
Hehe,
Dsm war Well, it did draw out how people really feel about it. I hope he got the bulletin about dsmx recalls
#13 | |
There was one DSMx recall so far (to my knowledge) and it had to do exclusively with backward compatibility with some of the single antenna DSM2 receivers; they actually have to switch back and forth between the 2 selected channels on the same antenna. I will send my DX8 to HH for update, even if none of my RXs are affected, just for the peace of mind.
#14 |
I must be living in a vacuum - I swear - I had no idea there was a recall.
Worse still, my PID is part of that recall. However, it sounds like the problem has to do with the backward compatibility AND the use Spektrum receivers. Question is this: If I am using the Skookum 720 and relatively new DSM2 satellites, Is the recall actually necessary?
#15 |
I just bought my first Spektrum radio ever, a DX-8. It is waiting for me at the post office when I return home tomorrow. Had Spektrum continued to use DSM2, I would not have touched them with a ten foot pole.
DSMX is a frequency hopping scheme that is more like FASST and the Hitec schemes and is superior IMO. |
#16 |
#17 |
Well actually if you want a warrenty on your dx8
And your unit is part of the recall, they have a disclaimer that says if you ignore the recall, you void your warrenty Plus, you get a free ar 6115e rx
