| Castle Creations ESC and Software Castle Creations ESC Software and Hardware Support |
I'm finishing up a Gaui 425 build. I bought a used Ice 100 Phoenix ESC it has two connectors that looks like they plug into the receiver. One of them looks like it is a voltage regulator the other I think is the throttle. Where do they go on the receiver? Anyone have a wiring diagram?
Blade MXC Align 450 Sport Gaui 425 Castle ESC, Align motor, BEC, Align 425 Carbon Fiber blades. (New build) |
You probably have the castle quick connect cable coupled to the ESC.This is just a Y-cable castle came up with to make it easyer to read the data log from your ESC.(You don,t have to unplug throttle cable from the receiver every time you want to read data from the ESC.)One of them is the throttle signal cable and the other is the data logging cable which will not be in use unless you want to read data from the ESC.
