| Beam E4 Beam E4 Support Forum |
Are you guys doing any checks to the head/screws etc after running a few packs through the heli? I'm new to this and wanted to ask before it was too late. No craches after 5-6 packs but now i'd like to make sure that there is anything I should be checking about now to make sure it hasn't come loose/etc.. Only thing i've been checking is the blade grips.
DX7 Beam E4Hitec 5065MG on cyclic - Hitec 5083MG on tail - Spartan Quark Gyro Align 430XL motor and Align 35 amp ESC MCPx Microheli CNC swash - Ext tail boom mod |
In general, you should put a little pressure on every single linkage you can get your hands on. visually check for any screws backing out and feel for excessive slop in any linkages, bearings, servo arms/wheels and make sure no servo connections are backing out.
I ALWAYS do a thorough bench check before heading out and a quick preflight check before every single flight. It only takes a second to look everything over and every once in a while you will catch something and be extremely thankful you checked. It only takes one link, screw, or connector to ruin your entire day.
TREX 700 Helibug GASSER 16t | µBeast | JR8717 | TRM 270TT | GV1 | R921 X9303 TREX 700 Helibug GASSER 20t | µBeast | DS610s | Hanson 29 3D Max | GV1 | R921 X9303 TREX 550 V2 DFC | AR7000 | µBeast | CC Ice 100 | CC BEC Pro | DS650 Tail | 520 Blades |
#3 | |
![]() Boom, shaft, spindle, flybar...
Dany Synergy E5 in the works Furion 6 Flybarless, Skookum 720 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Beam E4(v1) FBL, Skookum 540 |
well glad I asked! I'm trying to upload a video now of a simple hover! Just checked all the items listed and all look to be tight and secure!. Thanks for the reply's all
I am a newbie too! I purchased a used heli from a local guy and noticed the belt was loose. Well the next time we met up he helpme on tightening it. This was all before I flew it. Well after 15 flights I say it was loose again. Now I will check it after every flight. I need to get into these preflight checks myself and make it part of my normal routine.
#6 |
I generally do a pre flight and post flight check.
Mind you, most of my post flight checks are post-mortems!
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Prôtos 500 - MSH Brain Tarot 450 Pro - AR7200BX Spektrum DX8 |
#7 |
![]() I know all to well what you mean
