Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 07-18-2011, 01:21 PM   #1
mkovalcson
Default OK, when is an accessory too much?
So I've been thinking about my DX8, which I originally got because I wanted telemetry.
Now I'm thinking get a used iPad/iPhone/iTouch and a Telemetry reciever, and then get the JR I would have purchased instead.
Thoughts ?
Henseleit TDR, Synergy E5, MSH PROTOS 500, 130X
Jeti DS-16, Skookum SK-GPS
Last edited by mkovalcson; 07-18-2011 at 04:09 PM.. Reason: added iTouch and iPhone
mkovalcson is offline        Reply With Quote
Old 07-18-2011, 01:43 PM   #2
Nko15
Thats not an ipad..
Designing/Building the HEX Helicopters
Sponsored by Gens Ace Batteries, RCbearings.co.uk, Rapideyewear.co.uk
Nko15 is offline        Reply With Quote
Old 07-18-2011, 03:46 PM   #3
chrismechanic
well i dont know about how useful telemetry is i have never used it, i have an ice100 which logs the data. i do find it useful to a degree.
my thought is.....its too much when it has no use... and an after thought is how are you going to look at it while you fly ?
chris
trex 450 pro-fbl-scorpion 2221-8-custom motor mount-beastx-tarot head-beam e4 swash
trex 550e-castle 100 ice-bec pro-alloy tail control arm- 550mm blades-beastx-compass 6hv head-2mm side frames
futaba T8FG--R606FS/R617FS
chrismechanic is offline        Reply With Quote
Old 07-18-2011, 04:10 PM   #4
mkovalcson
Honestly the only time I would look at it is to see if my head speed looks good or to see how the flight pack is doing.
I would set an alarm on the Flight pack and BEC voltage and just have it with me for that. That's basically how it works on my DX8
Old 07-18-2011, 04:53 PM   #5
raptorz499
In my mind I am thinking...it is a toy helicopter!!!! COME ONE PEOPLE JUST FLY THE DAMN THING!!!!! LOL
raptorz499 is offline        Reply With Quote
Old 07-18-2011, 06:30 PM   #6
dct
Buy more batteries instead ...!
**Now doing EASY 3D!! And having a Ball !!**Trex 550e FBL V2 AR7200BX with CC BEC PRO ,And Trex 450 SA / SE metal head and carbon boom with V2 canopy, 430L motor, Hitec 65mg servo's, Futaba 401 gyro !
T-rex 450 Pro, DFC with AR7200BX
dct is offline        Reply With Quote
Old 07-18-2011, 07:10 PM   #7
gmoetech911
I think that's sick I've got an iPad and iPhone and a dx7 what do I need to hook that up a telemetry receiver? Where? How much? I want one!
gmoetech911 is offline        Reply With Quote
Old 07-18-2011, 08:36 PM   #8
mkovalcson
You need a TM1000 whatever sensors you want and a TR1000
Start
http://www.horizonhobby.co.uk/aeroon...telemetry.html
Old 07-18-2011, 11:06 PM   #9
breathe rc
OK, so you are either going to crash your heli trying to look at your iPod, iPad, or iPhone to check your telemetry. Or you are going to drop whichever one you have trying to save your heli from crashing while taking a peak at this. In my opinion, its a waste. Unless you have someone who wants to be your navigator, and keep you informed of your telemetry readings.
If there's better, I want it.
Kasama Dune 600: Pyro 700-52, Jive 80HV, V-Bar, BLS451's, BLS251
breathe rc is offline        Reply With Quote
Old 07-19-2011, 06:00 AM   #10
halfcab
I have yet to find any need for Telemetry on a elect heli. Because the voltage is constantly decreasing.
halfcab is offline        Reply With Quote
Old 07-19-2011, 08:14 AM   #11
nycheli
I bought the airspeed sensor even though I wasn't sure it would work on a heli. It works very well as far as I can tell. So I just bought the altitude sensor too... Is it useful? Not really, but it's pretty damn cool!
nycheli is offline        Reply With Quote
Old 11-13-2011, 04:46 PM   #12
johnahamelv
Thoughts ?
The Spektrum telemetry is neat as it allows the DX8 and the new DX7 to follow in real time whatever metrics you have configured. Currently, these include battery pack voltage, RX voltage, RPM, altitude, air speed, temperature, signal strength, as well as Holds and Fades. However, looking at these values in real time would need you to take your eyes off the bird. Other than having an assistant looking at the transmitter values, the main practical use of real time telemetry is to have audible alarms and/or vibrations go off to alert you to land the bird soon. Other than that, a quick peak at the battery voltage can let you know if you can get another 30 seconds safely out of your pack. At the end of the flight, one can check the log for maximum and minimum values, but all data is lost once the transmitter is turned off.
The TR1000 and iOS4/iOS5 STi app combo, allows an assistant to look at these metrics on the iPhone (not sure about iPad), allowing one to concentrate on flying the bird. A big limitation of this app is that it currently does not allow you to record data for later viewing. Other than taking occasional screen shots for later viewing, you are limited to real time data only.
Unfortunately, the telemetry measurements tend to be off too. The RPM is only accurate in steady state conditions, and is very inaccurate whenever significant RPM changes take place. When first spooling up in soft start, it is not uncommon for the RPM to read higher than 3000 RPM when the throttle curves are set for around 2100 RPM. The temperature measurement is limited to the external surfaces, but one is really interested in internal temperatures. The battery voltage normally measures 0.2 volts less per pack (not per cell) when compared to voltage taken with a professional volt meter.
At this point, I would only consider getting the TR1000 if Spektrum revises the iOS app to allow for data recording for later viewing.
Whiplash E--ICE2HV160/KDE-495/MKS HV's, Synergy E5/S--ICE2HV120/KDE-530/Futaba HV's
T-Rex 600Pro XT--ICE2HV120/KDE-530, T-Rex 550--ICE100/KDE-1175, B130X, mCPx
VBar Silverline x4, Lots of KDE, DX8, Sims: Aerofly5.7 /RF6.5/Phoenix 4
johnahamelv is online now        Reply With Quote
Old 11-14-2011, 09:42 AM   #13
Lunar Wolf
these things need to be audio not visual - an ear piece just to let you know if certain preset values are exceeded - high temp... low battery... etc.
Lunar Wolf is offline        Reply With Quote
Old 11-14-2011, 10:05 AM   #14
felborn
Originally Posted by Lunar Wolf View Post
these things need to be audio not visual - an ear piece just to let you know in certain preset values are exceeded - high temp... low battery... etc.
Indeed, who has the time to check your iThing for readings during a flight? I really love what they have done here, but I would not spend money on it as I dont really see the big pratical advantage. But it would be nice to have a reliable way to time your flight, say to set it so that when your at 80% drawn Ah of your pack, you get a warning instead of just using the time as sometimes flight can be very different debeing on if your working on a piro hover or perfecting tic-tocs.
felborn is offline        Reply With Quote
Old 11-15-2011, 06:01 AM   #15
Danny_Swe
anyone that needs a TM1100 or a TM1000? I'm selling it now.
TDR, 550E, 450Q | VBar, YGE, DX8 | Olympus OM-D
http://dannesholk.se/rc.shtml
Danny_Swe is offline        Reply With Quote
