Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450
Blade 450 Blade 450 Helicopters Information and Help
Old 07-20-2011, 05:31 PM   #1
kevin2569
Default Blade 450 Tracking
Can you guys help me with my tracking issue, my tracking is off so I kept adjusting the links and finely no more tracking issues, but my problem is now is that my blade pitch is off. One blade will be at 8+ at full stick and other blade is like at 7+ full stick.
As soon as I make both blades the same pitch my tracking gets off again?
kevin2569 is offline        Reply With Quote
Old 07-20-2011, 06:07 PM   #2
jdFin
I can't get my setup right either, but fortunately I'm too sloppy in the air to notice. Makes me a better pilot, right? I have not messed with any mechanical setup yet, just the subtrims, then when I can't improve things, I give up and set them back to zero.
But to the point of this thread, my tracking is right on, then if I switch the main blades (so each is in the other grip), the tracking is off by a quarter inch or so. That is repeatable, obvious, and seems kinda weird. I can't figure out what could possibly cause that.
In your case, and this is of course well beyond my experience but I've read about such mysteries, it may be that the geometry farther down the shaft is off. My understanding is that you have have to have, in this order (1) 90* servo arms (2) level swash (3) zero pitch at midstick. So maybe your swash is not level; I know mine isn't.
John
Protos 500 - HC3SX; Trex 450 Pro DFC - Ikon; 300X
jdFin is offline        Reply With Quote
Old 07-20-2011, 06:16 PM   #3
bradharvy
I posted a thread on the different heads between the 400 and 450. Not to hijack your thread, but the 450 has no adjustable washout linkages in the flybar/wash-out box. I am in the same boat trying to track with non adjustable pushrods, I'm talking about watching the head setup for the 400. It goes into detail about getting the pushrods leveled out, in witch the 450 does not have! Has, but non adjustable.
So to sum it up the 400 had the same looking setup but with adjustable links, not plastic. Does any one know wth i'm talking about???
Happy flying ....Brad
Trex 550e v2,BLADE 450X ,130X NEVER! McPX BRL, 120DO2s, McPX, Stryker , Edge 540qq,UMX BEASt, Crak Yakx2,
YAK 55M 35CC,A.W. yak 54 20CC,3dhs 330sc 57inch, ALL ON MY JR9503
bradharvy is offline        Reply With Quote
Old 07-20-2011, 07:40 PM   #4
kevin2569
I just noticed that the links you would adjust for tracking are not adjustable? They are just plastic
Old 07-20-2011, 11:27 PM   #5
bradharvy
yes, it seems ta be more of a pita! Anyone with sugestions? put adj. ones in from 400 or is it a diff. set up?
Old 07-27-2011, 08:34 AM   #6
Roblucky13
If your tracking is perfect, then the pitch should be the same! Make sure you check the pitch from the same position for each blade. I always check with the blade lined up with the tail boom. If the shash is not completely level, the pitch will change as the blades swing around...so always level swash and always check pitch in same position.
I would check with throttle hold on and pitch on TX at 0...mid stick for me. Unplug motor for safety!
Trex 600EFL PRO (BeastX, Rail 606 blades, Kontronik 80HV)
Trex 450 PRO FBL (BeastX, HS-5065/BLS257, CC ICE Lite 50,)
mCP x (KBDD blades and tail)
Roblucky13 is offline        Reply With Quote
Old 07-27-2011, 09:58 AM   #7
whoanelly
sounds like you need to check your swash for level not only at center stick but at top and bottom as well.
700LE : 105HZR AR7200BX JR8917 Multi gov , JR9503
600ESP : 100AMP Castle. Scorpion Motor . AMA #962896
400 Blade : Scorpion 2221-6 ,Castle ICE 50 Sonix Head and t
Align 450 pro V2 3G MKS DS95 MSR , 2 x MCPX (brushless C05 & HP05), Blade 130X.
whoanelly is offline        Reply With Quote
Old 07-27-2011, 10:10 AM   #8
johnsma22
It's funny that you mention that. My B450 was tracking perfectly out of the box. I mean, perfectly! I was surprised by this. After many, many flights I decided to remove the blades to check the blade grip bolts. I marked the blades so that they would go back into the same grips. Put everything back together confirming the blades were in the same grips as before, and lo and behold, my tracking is off. Not sure what happened, but I'm not going to chase it down. I'm just going to fly it, as it still flies great!
johnsma22 is offline        Reply With Quote
Old 07-28-2011, 02:12 PM   #9
bradharvy
level at top AND bottom, man I'm such a noob! Never intered my thoughts, My mind is full of garbage I guess! Makes since!
Old 07-28-2011, 03:09 PM   #10
bradharvy
Default witch side?
When adjusting tracking is it best to start with low blade and raise. Or check pitch I guess and see If high side needs ta go down?
Old 07-28-2011, 03:35 PM   #11
Luvmyhelis
Yep, this actually is a copy of some of the trex heads. You actually don't need the additional 4 adjustable links around the flybar cage if all the parts are straight. And it greatly simplifies the setup. Now pitch can be adjusted with the two uplinks.
Jeti//800Triabolo/Gob700/SHS800/Frankenheli600/Chase420/Compass/Coax/Sk720B/540/360 YGE/YEP/HW/MKS/Outrage/Turnigy/Mibl/Soko/KollDubroRcTek/Boca/Herc/Gryphon/ScottGray Scorp/KDE/Kontronik/TP/Tenax/Lynx
Luvmyhelis is offline        Reply With Quote
Old 07-28-2011, 06:12 PM   #12
bradharvy
Again thank you for the reply. What is your thoughts on tracking? Adjust up to the high blade or.....
