Go Back   HeliFreak > R/C Electronics Support > JLog - The JIVE logging stamp
JLog - The JIVE logging stamp JLog - The JIVE logging stamp - Official English Support Forum
Old 07-20-2011, 04:42 PM   #1
jointer
Default HeliJive
Hi Tom,
do you have any idea if the JLog will work with the new HeliJive?
It is not available yet, but the manual is online and i have a plan to use it.
If it will not work, then i will choose YGE.
Thanks.
Petr
- TDR #2, 4525LE, YGE 160HV, MKS HBL950 (JR MP82S=crap), Outrage BL9188, Gryphon Quasar, silver Vbar + 2x sat, 12S Billowy 50C 5200mAh, Radix V2, EDGE 105mm, DX7
- TDR #1 sold (standart setup, 700+ flights)
- HPI e-Firestorm FLUX, Spektrum DX3S
jointer is offline        Reply With Quote
Old 07-20-2011, 05:12 PM   #2
dl7uae
Hi Petr!
Works.
Cheers. Tom
Tom (http://JLog.hacknet.eu)
dl7uae is offline        Reply With Quote
Old 07-26-2011, 08:35 AM   #3
jointer
Tom, i see you implemented a new feature - RPM output for Vbar.
I was thinking about asking you if this can be done.
It cannot be tested until someone will have JLog2 and HeliJive, but i think it is nice idea.
Old 07-26-2011, 03:06 PM   #4
dl7uae
Well, Uli told me that he will not have the time right now for testing of it. I should test it by myself. But, you name it, I'll need a HeliJIVE for that, will take care of it.
The question is whether an update rate of 100ms for the pulse frequency may be sufficient, given the inertia of the controlled system..?
That was just a spontaneous idea..
Tom
Old 07-27-2011, 03:00 AM   #5
jointer
It might work, but i think it will not be as good as classic sensor.
The Vbar gov need to have fast feedback, to see if the applied change had any effect.
Here will be 100ms delay and the value will stay the same for next 100ms.
Need to be tested.
Would be very nice if it would work.
I am considering waiting for YGE with RPM output, but HeliJive have all i might need, so i think i will get that again. Only the prices is higher again.
Old 07-27-2011, 04:21 AM   #6
dl7uae
Not sure.. That w'd be the V-Bar governor in a normal control loop (like JIVE's governor), reacting, not preventive acting. As I mentioned: No idea how the inertia of the control process is. Needs to give it a try..
Tom
Old 11-18-2011, 01:54 AM   #7
morrolucky
Hi Tom
Jlog 2 can work with new HeliJive (Version 11)?
What I need for it except Jlog2 and HeliJive?
Thank You!
morrolucky is offline        Reply With Quote
Old 11-18-2011, 03:28 AM   #8
dl7uae
Yes, works.
What do I need for it except of Jlog2 and HeliJive?
Nothing, SM#2800 (JLog2), that's all.
If you want to use JLog-own sensors (external to the JIVE), look here as well as here.
Tom
Old 11-18-2011, 03:39 AM   #9
morrolucky
Thank You!!!
Old 11-19-2011, 04:31 PM   #10
Magneto
The jlog is a great add on for the helijive.
Team
USA Team Minicopter
www.peakaircraft.com
Magneto is offline        Reply With Quote
