Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 07-21-2011, 08:51 AM   #1
chilling
Default 560mm blades??
I accidentally picked up a set of rotortech 560mm blades, instead of the 550mm.
1) I've read the reviews and with the stock tail blades the consensus was mixed if the stock tail blade length was ok. Now with 560mm is this ok or should I just change it??
2) can I have definitive feedback for the stock electronics with 550mm and 560mm blades? I do have an external bec.
Many thanks
chilling is offline        Reply With Quote
Old 07-21-2011, 07:02 PM   #2
dct
??? The stock main blades are 520 not 550? The 520 are what are in my kit.
**Now doing EASY 3D!! And having a Ball !!**Trex 550e FBL V2 AR7200BX with CC BEC PRO ,And
T-rex 450 Pro, DFC with AR7200BX , Blade 300CFX, and Two, Blade 130X , Blade 350QX .!
dct is offline        Reply With Quote
Old 07-21-2011, 07:27 PM   #3
RC Mike
You will need to use shorter tail blades to keep the tail and main blades from hitting during 3D. You may also need a smaller pinion. Going from 520 to 560 is quire an increase in disk area so you won’t need as much headspeed for the same lift.
RC Mike is offline        Reply With Quote
Old 07-21-2011, 11:25 PM   #4
Wolfpackin
...and do not run the 560mm blades on a 17t pinion with the stock ESC.
Jonathan Livingston Helicopter
Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.)
CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG.
T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades.
Wolfpackin is offline        Reply With Quote
Old 07-22-2011, 12:38 AM   #5
see_e_oh
Definitely 85mm tail rotor blades. I run the 84.5mm KBDDs on the tail with the Edge 553's main blades on stock 16T pinion.
Flys like a banshee .... but very stable!
Team Futaba, Team Thunder Tiger, Team Switch Rotorblades
TT E700 v2 (x2) (VBar Silverline, Scorpion 4235-520, HeliJive 120), TT G4 720 (CGY750, OS105HZR/Hatori), Futaba 14SG, SBUS, and Futaba BLSHV Servos all around
see_e_oh is online now        Reply With Quote
Old 07-22-2011, 01:16 AM   #6
Mr Nice Guy
You actually have better blades there. The 560s are higher performance 3D blades than the 550s.
Mr Nice Guy is offline        Reply With Quote
Old 07-22-2011, 06:14 AM   #7
RC Mike
I agree those are excellent blades. I have a set on a non Trex helicopter and they do have fantastic performance.
Old 07-22-2011, 08:45 PM   #8
chilling
Ok, so I think the consensus is shorter tail blades.
How bout the stock align esc with the 560? Will the higher load of longer blades be too much for that esc? Note I'm no 3d beast, just learning to fly right now. I intent for bigger blades for the more stable feel.
Many thanks
Old 07-22-2011, 11:09 PM   #9
Mr Nice Guy
When I went from 500s to 550s I started really heating up 75 and 80 amp ESCs. In the summer my 80 Amp CC Phoenix would shut down on me. I was really only sport flying at that time. I went to an CC Ice 100 and it comes down cool every time no matter how hard I fly it.
Old 07-22-2011, 11:14 PM   #10
jchen
Hi Chilling,
Where you flying in Sg ? When I bought my 550, the first thing that I did
was to replace the Esc with an CC Ice 100. So far the CC Esc has been
working good for me. Have not utilize the Gov mode so can't comment on
that. With longer blades perhaps you could go with the smaller pinion &
take it from there.
jchen is offline        Reply With Quote
