Old 07-21-2011, 10:24 AM   #1
Ampdraw
Default Swash - Rakonheli or Microheli and why
As per title. Currently flying stock swash strengthened with cotton and ca.
Anyone tested both and prefer one?
Rakon is 1.29g website
Micro 1.35 website
Stock 1.20 measured
Looking for performance.
Amp
Ampdraw is offline        Reply With Quote
Old 07-21-2011, 04:09 PM   #2
CX2Pilot
Hey Amp, I am looking for the same info as you, which one to get.
I read a post where there was a issue with the Rakonheli swash.
"The balls on the RH swash were glued in"
http://helifreak.com/showpost.php?p=...4&postcount=25
Tom
CX2Pilot is offline        Reply With Quote
Old 07-21-2011, 05:15 PM   #3
liftbag
Micro 1.35 website
Stock 1.20 measured
Amp
Both are much more precise than the stock.
I've never had problems with the aluminium riveted balls of the RKH swash, but one can assume that those steel balls of Microheli swash will last longer.
The Microheli swashplate tilts slightly, but in a flybarless system this is not an issue.
Rakonheli told me that they could review their swashplate (SE version with steel balls? I don't know).
Gaui 200 Beastx - An unknown number of bl converted Blade mCP X.
liftbag is offline        Reply With Quote
Old 07-21-2011, 05:39 PM   #4
NCcraig
I have a MH swash on my mCPX and have no complaints.
Craig
Team Newb pilot
All my helis and quads were lost in a tragic boating accident.
DX9, AMA# 966513.
NCcraig is offline        Reply With Quote
Old 07-21-2011, 06:51 PM   #5
plexus
I purchased the MH swash over the RKH because of the MH swash has threaded ball arms (apparently) rather than press fit ones on the RKH (apparently). The MH balls are slotted which is a good indication they are threaded and possibly replaceable if MH carries them.
plexus is offline        Reply With Quote
Old 07-21-2011, 07:19 PM   #6
Punkin71
I have only flown a few times with the rkh swash and can say slop is very minimal of the stocker.
Trex 250se 3gx
Trex 500 Beastx, Ice 75 9650's & 9257 500mx, Edge main & Kbdd tail blades
Mini Titan e325 Beastx Airtronics 94809 cyclic, 9257 tail, Ice lite 50/scorp 2221-8 Edge mains, Kbdd tail blades
Jr Vibe 50, Beastx, all Futaba servos OS55hz, Hatori sab 50, Radix
Punkin71 is offline        Reply With Quote
Old 07-21-2011, 07:21 PM   #7
CX2Pilot
That is good to know that they are not glued in but riveted. Aluminium balls are
fine with me.
I am in contact with Mr. Rakon now to order some parts so I am watching this thread
to see how this swash is.
I would like to get the CNC frame also due out July 22th or 23th.
I may offer to do a review for him also.
Tom
Old 07-21-2011, 08:37 PM   #8
Berchico
Default Microheli swash
I'm using the microheli swash and am quite impressed with it. It removed a lot of the shaking that was happening with the stock one.
Berchico is offline        Reply With Quote
Old 07-21-2011, 11:04 PM   #9
jim_stoll
I've never tried the Rakon swash. I had the MH swash for 4 days and absolutely loved it - right up until the bearing refused to turn any further. (That's not entirely true, it would still turn, but head speed was way down because it was so stiff, and it was difficult to turn the main shaft by hand when the main gear was removed.) I think I ended up with a bum bearing, but the swash itself was very, very nice. No wandering around the sky when trying to do precision work, would hover hands-off for several seconds, inverted was very stable and predictable. I have failed to get any response from MH despite repeated messages, IM attempts, etc (vs I've seen several folks referring to having a conversation w/ the fellow from Rakon), so customer service clearly isn't a priority. All that having been said, I've ordered another MH, and since so many others have had good luck with theirs, I'm hoping my 2nd one will go better than the first one. (I continue to try to contact MH to get $$ back or at least get them to send me another swash)
So, despite the setback, which I take to be an unusual occurrence, and the complete lack of any level of customer support thus far, I'd optimistically recommend the MH just based on 3-4 days of really nice performance. (if this one fails, I'm clearly going w/ the Rakon next. :-)
jim_stoll is offline        Reply With Quote
Old 07-22-2011, 03:24 AM   #10
TurboProp
I wanted the rakon one for the sweet red color, but alas they are out of stock. ( through cusker) I figure if there is something that causes the aluminum balls to fail then it might be a good idea to change the swash plate anyways. Plush the rakon one is advertised slightly lighter.
I'm pretty sure I saw a ball kit for the MH swash when I was looking though. Dunno, 6 of one half a dozon of the other if you ask me.
DX6i
mSR
mCPX
HK450GT 3G
TurboProp is offline        Reply With Quote
Old 07-22-2011, 11:46 AM   #11
bbdmarch
I've just fitted the MH swash and love it!
I usually focus on the swash when flying and having a silver blur to follow in the air makes life a bit easier. But the main benefit is that you get more precision.
If you hold the heli and run the motor to max and watch the swash you can see the stock one flex as it moves!
Now can some one make links out of carbon ?? Even less flex!
I've just fitted a MH swash and first flight was great!
I like the fact that you can follow the swash more easily in the air - I usually focus on the swash when flying, is that the best point to follow ??
If you run the motor up to full speed and move the sticks you can see the stock swash flex underload! Now can you get links of carbon fiber ?? For even less flex in the head!
bbdmarch is offline        Reply With Quote
Old 07-22-2011, 03:45 PM   #12
JoeW
I did a full RKH upgrade... unfortunately, my 3-in-1 fried between the time I ordered the RKH parts and when they arrived... So it's been sitting on my bench blinged out
Still no word from HH when they're going to have stock on the 3-in-1 replacement.
JoeW is offline        Reply With Quote
Old 07-22-2011, 04:08 PM   #13
bbdmarch
Last post was done twice as I thought the first on failed! Oops!
Old 07-23-2011, 08:58 AM   #14
Ampdraw
Thanks for the replies gents.
Liftbag, you refer to the Microheli swash as having a tilt...can you please elaborate?
Looking very closely at my strengthened stock swash...there was a bit of play between the ball and the shaft, I resized a new "oversize" solid mainshaft with 700 wet'n'dry to solve that. Looking at it again after the newly sized shaft it seems most of the play is due to the swash "turning". The anti-rotation pin has too much tolerance in the guide and that is where most of the "pitch" play is.
Anyway even if I fix that the balls are too loose, yep loose balls is a condition (affliction) that can be band-aided with grommets but that is only a solution to an existing issue rather than re-engineering the swash so the problem is non existent.
Looking closely at the RKH it doesn't look like they use a metal swash ball, rather a nylon tapered tube?
Anyone do the calculation on the geometry of these swashes? Distance between the lower balls and more importantly the width of the upper?
Amp
Old 07-23-2011, 10:18 AM   #15
liftbag
Amp
I mean that the maximum possible angle of the rotation plane of MH swash is lower than that obtained from the stock swash, while RKH swash is capable of higher inclination.
This is due to the placement of the ball joint.
Rakonheli swash have the lower placement, while Microheli has the higher.
In their view, this is an advantage. This is what they say in the description:
Originally Posted by Microheli
More than that, the Precision CNC Aluminum Swashplate is technically re-engineered center ball in line with swash arm balls to allow swashplate tilting linearly and precisely which produces the most accurate and fast cyclic response and cyclic power on Blade mCP X flybarless head system.
Honestly I can not enjoy this advantage, but probably those who have more precise thumbs of me, it would be good.
On the other hand, Rakonheli refers:
Originally Posted by Rakonheli
- Maximize swashplate tilting angle up to 24.7 degree.
I think it's possible to appreciate this advantage only in self-stable 4-channel helicopters.
I am convinced that one reason for the greater precision of the flight of the CNC swashplates than E-flite is the much more accurate ball joint.
Microheli has metal ball in delrin joint, Rakonheli the opposite.
The antirotation pins are thicker than the E-flite. The MH carbon pin is thicker than RKH.
You need to enlarge the guide of RKH cnc carbon main frame to accomodate the MH swashplate.
The swashplate guide of E-flite main frame has too much flex.
You can reinforce it like this picture
The geometry, understood as the distance between the balls (upper and lower) is identical to the E-flite swashplate in both CNC swashes.
Old 07-24-2011, 01:42 AM   #16
Ampdraw
Thanks for the detailed info liftbag.
Leaning toward the Microheli swash due to the metal swash ball. Figure the delrin in the rakonheli will wear faster. Hope I get a good bearing in the Microheli.
Last aspect, the available swash travel for cyclic...24.7 on the Rakonheli. You mention that it is capable of more than the Microheli.
I fly with 100 endpoints on aile / elev, 20% expo and 100% DR. 78 endpoint on pitch. Stock swash can handle full collective and full cyclic...just.
Is the microheli swash capable of this amount of travel?
Amp
Old 07-24-2011, 02:21 AM   #17
liftbag
Amp
In a flybarless system the commands given with TX sticks does not correspond to a servo arm position, but instead define a rate of rotation.
Only if the helicopter is locked you can achieve servo endpoint.
During the flight, the slightest servo movement corresponds to a rotation that stops when the angle reach the position required by the gyro.
During the rotation, the swashplate is inclined slightly with respect to the main shaft because the variation of position with respect to the rotation axis meets the requirements of the flybarless stabilization system.
Only if you lock the helicopter, the servo arm continues to move to the endpoint and then taking the swash at maximum tilt. Is a condition that does not happen during the flight.
Is for this reason that a good ability to tilt is more important in a flybarred helicopter, where the sum of the cyclic and collective is immediately reached leading the tx sticks to their fullest extent.
English is not my language, so I hope to be able to explain what I mean in some way.
Paolo
Old 07-24-2011, 02:44 AM   #18
jim_stoll
I'm back on an MH swash today and I feel whole again! :-) (I also finished and flew my brushless conversion today, and I have to say, I'm extra glad to have the cnc swash - I'm not sure I'd want to fly the brushless setup w/ the stock swash...)
Old 07-24-2011, 06:48 AM   #19
Ampdraw
Thanks for the feedback liftbag. This is my first FBL heli however I'm familiar with HH tails and setting them up for both servo tails and dd motor tails.
I presume that just like a HH tail the FBL initially accepts your stick command and then has both acceleration and decelleration profile that gets your request done. So initially the servo moves full deflection to get the command started and then as the heli responds it starts reducing deflection as required. Currently I am just able to do poor half piro flips. Punching full forward cyclic and then "stirring" forward cyclic to full right aileron i'm pretty sure the swash deflects at least 75% collective, 100% elev and 100% aile for a moment then the ratio of aile to elev would change.
Anyway...is the microheli swash capable of both 100% endpoint (100% DR) Aile and Elev command without the lower swash touching the shaft?
Amp
Old 07-24-2011, 07:09 AM   #20
liftbag
Amp
I say that the Microheli lower swash touch the shaft when you reach 100% Aile and a value from 60% to 90% Elev or 60% to 90% Aile with 100% Elev, depending on the four corners of the cyclic stick.
Rakonheli lower swash never touch the shaft.
