Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > NextD - Rave 450 and 90
NextD - Rave 450 and 90 CJY Rave 450 and 90 Helicopter Kit - ND-YR-K001
Old 07-25-2011, 07:46 AM   #1
Sao
Default Slipping one way ENV Nitro
The one way on my Rave has started slipping, is it just a matter of cleaning out the oil and re-greasing it or does the sprag clutch need replacing. I've only ever had one ways with roller bearings in them before so this is a bit new to me. Or is it slipping in the hub itself.
Goblin 500 V-Bar, Goblin 380 V-Bar,T-Rex 500 V-Bar Align Cobra Fuz, E-Flite Blade 180CFX, TBS Gemini FPV, CYE Stingray FPV, some planks.
Sao is offline        Reply With Quote
Old 07-25-2011, 08:05 AM   #2
Sky Dancer
I've also seen one slipping. It was the "outer race" of the sprag bearing slipping in the auto hub not the sprag one way itself.
Just dissassemble (with some heat), clean and reassemble the outer race into the hub using 648 Loctite and you'll be good to go.
Don C
Sky Dancer is offline        Reply With Quote
Old 07-25-2011, 09:33 AM   #3
Sao
Cheers Don. I will give that a go
