Old 07-25-2011, 06:01 PM   #1
jcflyer
Default Tail Control Rod Guide
What would cause the front guide to break? I have broken three of them and don't know why, it seems that they are breaking when I land the heli.
Jay
jcflyer is online now        Reply With Quote
Old 07-25-2011, 06:51 PM   #2
skered53
there's been threads about this, usually blamed on vibes
T-rex 500FBL BeastX, I2 MRH & Swash, I2 tailboom holder TT version,( Bob's the Mahn ! ) DX7s. Gaui 550 FB, T-rex 550 I2 FBL head.
CH-53E's 83-87. MCAS New River. FAA certified Airframe & Powerplant license holder since 1992
skered53 is offline        Reply With Quote
Old 07-25-2011, 07:00 PM   #3
jcflyer
Vibes caused by what?
jay
Old 07-25-2011, 07:36 PM   #4
grawyl
A vary fast oscillation causes vibes.
The art in flying RC Helicopters lies in learning how to throw it at the ground and miss.
Tarot 450 Pro - Chaos 500
grawyl is offline        Reply With Quote
Old 07-25-2011, 08:01 PM   #5
WyDiablo
After breaking several of the stock guides I started using these and so far so good. They will hold up on those big punch outs of the 500. That's why I was breaking so many of them.
WyDiablo
http://helidirect.com/microheli-tail...500-p-7769.hdx
WyDiablo is online now        Reply With Quote
Old 07-25-2011, 10:02 PM   #6
fvdriver
I had the guides break too and made a CF rod that has survived several crashes, does not need guides, and has no vibrations.
fvdriver is offline        Reply With Quote
Old 07-25-2011, 10:14 PM   #7
jcflyer
WyDiablo
Thanks my friend I have already ordered these.
Jay
Old 07-25-2011, 10:15 PM   #8
jcflyer
Exactly what material did you use and where did you get it from???
Jay
Old 07-25-2011, 10:24 PM   #9
fvdriver
There is a thread here some where about making them. What I did was use a scrap piece of CF rod that had an ID close to that of the stock rod. I checked the length of the stock rod and cut the CF so that the threads from the stock rod would stick out the same amount. I then cut the stock rod about an inch in from the threads and dremmeled some small notches in the rod. I used 5 min epoxy and just glued them in the ends, making sure they were straight. The notches in the rod help provide grip so they don't pull out. Easy, quick, strong and light.
Old 07-25-2011, 10:37 PM   #10
craymanus
listen jay next time when u r with the heli??hover for a few minutes then bring it down and grab the tail boom by the tail rotor i'll bet its super hot!!! why????? beats me ...thats y i changed to torque tube... i think that belt has to be just right.for those guides not to break...
craymanus is offline        Reply With Quote
Old 07-26-2011, 02:13 AM   #11
flerpie
Heat means friction. Tail case bearings.
HK Best Of Custom 450s & 500
Build Different!
flerpie is offline        Reply With Quote
Old 07-26-2011, 08:00 AM   #12
helihaven
Default no more tail rod guides....
this is what i wound up using to solve the issue... quick uk 600/700 rod ends with 3/16" carbon rod inside 7/32 aluminum tubing...i have a 4 bladed tail rotor with raptor 30/50 blades on one end and a full size ds-650 on the other...no rod guides..and no flex either....you could push a small truck with it...weighs 19 grams...but its also 110mm longer than stock, so a stock length should weigh 16 grams or so, only 4 grams more than a stock rod and 2 metal rod guides.
helihaven is offline        Reply With Quote
Old 07-26-2011, 08:52 AM   #13
jcflyer
I like the idea but the weight!!! The tail is already heavier than I like. I found a couple different things to try first.
Jay
Old 07-26-2011, 08:54 AM   #14
jcflyer
You know it's funny that you mention that, the other day I thought it felt a little warm.
Jay
Old 07-26-2011, 08:55 AM   #15
jcflyer
Could the belt be too tight??? as apposed to the bearings???
Jay
Old 07-26-2011, 08:57 PM   #16
flerpie
Jay
Well, yes. Too tight pulling on the bearings might cause enuff friction in the
bearings to make heat.
The boom gets hot at the tail end because the tail is attached to the boom.
I bet the tail case is hotter than the boom which means the heat is being
generated in the tail case. Use your sense of touch to find out where the
heat is coming from.
What is in the tail case that moves and can cause friction?
Bearings and tailshaft are what move.
Or doesn't move in the case of a seized up tail case bearing.
I bet if you replace both bearings the heat problem will go away.
Build Different!
Old 07-26-2011, 09:00 PM   #17
flerpie
That looks very nice HH. I might need the weight to offset a bigger lipo too.
Build Different!
Old 07-26-2011, 11:29 PM   #18
horigan
Buy these ends:
http://www.readyheli.com/TXT-242BK-Q...k_p_37346.html
Buy this rod and cut down to the right size and you're done.
http://www.readyheli.com/TXT-241-Qui...d_p_36428.html
Works great, lighter than stock, and not rod guide required.
Rich
Trex 500ESP FBL BeastX
Synergy E5 VBar
Synergy E7 VBar
horigan is offline        Reply With Quote
Old 07-27-2011, 01:37 AM   #19
xJAEx
Originally Posted by horigan View Post
Buy these ends:
I think i'm going to order these, I hate the stock pushrod on my new 500 ESP build. It really bothers me, this seems to be exactly what I need. Thanks.
T-Rex 500ESP / ICE 75 ESC/ 500MX Motor
DEAD Align servos on cyclic and tail / Align 780 gyro
Hitec Aurora 9
xJAEx is offline        Reply With Quote
Old 07-29-2011, 06:25 PM   #20
Wizzard
Buy these ends:
So is the CF rod hollow and you cut the threaded ends from the metal rod and epoxy them into the CF rod? Or, is it solid and you epoxy the ends onto the rod, once cut to length of course.
Align 450Pro FBL, BeastX
Blade 550X Pro
Spektrum DX8
Proudly Sponsored by "MasterCard"
Wizzard is offline        Reply With Quote
