| CAD/CAM R/C Helicopter CAD/CAM |
So I always wanted a CNC machine and a few months ago I converted an old Mill/Drill over. Here is the
build thread if you are into such things. http://www.cnczone.com/forums/bencht...selection.html I have been playing with a couple of projects to help me learn the CAM software. This Heli frame is one of them. The idea was to design and build upper and lower frame half's with the lower frame being sacrificed in a crash most of the time, I hope! :-) Since I Fly 12s A123 packs another advantage for me would be a wider lower half for batteries to slide into. This is a direct servo to swash conversion. The upper frame is .1 oz heavier then a Rotoworks frame half. Once you factor in the other weight savings from hardware it should be close to even in the weight department. Again flying 12s A123 packs I am not all worked up about weight. I just though I would share my project with all of you.
Kelly -------------------------------------- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. www.facebook.com/CNCEffects |
Wow! that's pretty neat looking. Not too shabby
Hirobo Evo .50/Futaba 9C/OS 50 Hyper & Hatori/Radix/GV1/GY401&9254/9252s/Arizona Heli Canopy Trex 500 FBL/Futaba 8FGS/CGY750/CC ICE 75 & Scorp 1400 16T/Radix/9650s/9256 Trex 450 Pro/Futaba 8FGS/450M 14T/TP Blades/ 3156s/ Futaba GY520&9257 |
Awesome! Now, make some more and sell those puppies!
Blade MCPX BL Rakon MCPX BL Rakon MCPX V1 Rakon NCPX-TDR, DX7. Rakon Rep. |
i see you strayed away from the frameplates, i like this
Brian Tran Amainhobbies.com Protek R/C ( ͡° ͜ʖ ͡°) |
Thanks Guys,
It takes about 45 minutes to cut but I picked up some 3 flute end mills and might be able to speed it up a bit.
#6 |
Next trick is to learn how to anodize them in custom colors!
#7 |
What heli is that? Align?
What CAD/CAM software do you use? Looks pretty slick man. I'd be proud. |
#8 |
that is awesome! great work.
However, I would be concerned about crashing and bending the frames compared to CF plates. |
#9 |
That is a Trex 600e.
I draw with Autocad since I am used to it from work and purchased a very inexpensive Cam software called CamBam. Pretty nice for the price. I run Mach3 on the mill. I cranked up the feeds a little when I cut this part for the mill yesterday. If I can up the RPM on the mill past 2580 I can go even faster. I am hoping the lower G10 fiberglass frames break before the aluminum bends... Will see when I crash it! I don't/can't do wild 3d (unless i'm crashing) so I mainly do loops, rolls, FFF, just fly around. I only have the natural color G10 right now but I plan on purchasing the black for the final build.
#10 |
Man, that's just awesome, go ahead and let that creativity flow
.Regards, Homer.
DX7, Futaba FF10, Mode-2 Trex 250,Trex 450Pro FBL MiniVbar Blueline, Logo 600SE, Trex 500ESP FBL MiniVbar,Trex 550 FBL MiniVbar, Trex 600Pro FBL MiniVbar, Trex 700E FBL MiniVbar Blueline, Phoenix Sim. Sponsored by EP-Fun. |
#11 |
I think the g10 is stronger than the aluminum. But you are doing good making those, even If im right you could also machine g10 frames. Looking it over, you need to fill in the gaps with bracing, theres not enough structural integrity to it.
#12 |
Very nice! .. I like the video .. using the machine to manufacture new parts for it's self
Dave.
Arriving Somewhere. The butterfly sailed on the breeze Past a field of barbed wire trees |
#13 |
I sit in an office and push paper around all day, so seeing someone actually make something is refreshing!
Compass Atom 500, DJI 450 Flame Wheel, mCPX Brushless, Nano CPX, T-28 Trojan, "Crash Proof" Hawk Sky, DX8, overinflated sense of self worth! |
#14 |
Excellent job, I am jealous - I still have to turn the handles on my Bridgeport.
#15 |
Thats awesome man. I went through your build thread on the other site and its pretty impressive. What did it cost to turn your mill over?
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#16 |
This video made me reflect on the bad choices I made in my life. Well not all bad but this is something I would have loved to do so much. Your mill works great and being a DIY CNC convert is very impressive. You seem really good at what you do and I applaud your skills and determination
No brain, no headache. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#17 |
Awesome!
Synergy e7, Vbar, HeliJive 120, Hacker 12L, JR 8917 HV, BLS251 Logo 400, Vbar, Jive 60+lv, S9650, BLS251, Pyro 600-09 TRex 450 Sport, MiniVbar, 5065MG, DS420, 450MX |
#18 |
Looking good!! I've been CNCing for years in RC. Bought my TAIG for doin car parts. But then the Chinese got into it and can't compete. When I get it back up and running in my shop, I will do some Heli parts too. cnczone.com a great site as well
Dan Pesonen FBL, Don't think about it, DO IT. mCX2, nCPX, mCP X, Blade 400, MSH PRÔTOS "Tri-Flow" I put that S*** on everything!" |
#19 |
Very Nice set up... good job.. like to see the finished bird
MSR, MCPX, 450s, 600, 650, 700, 800, 900, 1000 Assorted Mix Fixed Wing. AMA # 972083 |
#20 |
Nice...need some for nitro.
Aliuminum is a great choice, if the proper aluminum is chosen, I like 7075 t6. Some of the other alloys are just too soft. the great thing is that when you do crash, you just hammer the bends out and get back to flying...no need for a new frame in many cases. In a bad crash you may tear the alloy but that is easily fixed too.
X-cell Fury 90: 601/9251, 8231's Cyc; DS650; OS 91MP-6; Jr Vibe 90; OS 91RJX Pipe; Jr 8231 cyclic, 770 3D/G8900, Prfct Reg. CCPM; T-Rex 600 NP: 6965HB, 425MG Throttle GY 520/9254; OS50 Hyper,MP-5, Prfct Reg; 600E Bstx, nue1910 |
