Go Back   HeliFreak > R/C Helicopters > Newbies: Tips and Information
Newbies: Tips and Information Section of HF, specifically for Passing along info to newcomers to the hobby. Setup, tweaking, orientation practice, etc.
Old 07-26-2011, 06:33 PM   #1
aramb
Default Removing Bearings from Bearing Block
What is the best way to remove bearing from a bearing block?
Megavolt 800, Trex 800e, Goblin 770, Fusion 50, Blade Mcpx
Spektrum DX18 / AMA# 959345 / IRCHA #3954
Team Lynx Team HeliDirect
aramb is offline        Reply With Quote
Old 07-26-2011, 07:09 PM   #2
Bob O
What heli? Main shaft?
They should just tap right out. They'll only come out one way though. If there's a retaining ring attached to the block, make sure to remove that before you start tapping.
Warp 360 Spartan Vortex VX1
Bob O is online now        Reply With Quote
Old 07-26-2011, 07:54 PM   #3
aramb
Yes, Trex 700e mainshaft. I got them out. I heated them up using the flame from the gas stove.
Old 07-29-2011, 06:57 PM   #4
wolfdown
Check out this tip from Matt Botos.
http://mattbotos.com/2010/priceless-tool-for-december/
Rush 750 w/ Xera 4530-500 (12T), YGE160HV, WR S.BEC, Torq 9180/9188, AR7200BX
Outrage 550 w/ Scorp 4020-1390 (13T), YGE120, CC BEC Pro, Quark, MKS BLS980, Futaba BLS451
Last Rebuild: 10/15/12 (O550)
wolfdown is offline        Reply With Quote
Old 07-29-2011, 07:32 PM   #5
aramb
Neat stuff there. I ended up using a propane torch and they just fell out. Cool!
Old 07-30-2011, 07:55 PM   #6
Wolfpackin
I heat them up in a toaster oven to about 250°F, then they usually pop right out.
Zen and the Art of Helicopter Maintenance
Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.)
CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG.
T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades.
Wolfpackin is offline        Reply With Quote
