Old 04-02-2007, 05:30 PM   #1
johnnycat500
Default blade grips
I upgraded to the all metal head on my sa and found that one of the 3x8x4mm bearings was missing on one blade grip. You could pull the blade grip away from the head block. I have about 4 flights on it like this. any body have this problem?
johnnycat500 is offline        Reply With Quote
Old 04-02-2007, 06:27 PM   #2
kama1
it actually flew like that?
i would get bearings for it asap.
check all the bearings in both grips before you order.
flying with out that bearing could of messed up the others cause of bad vibes.
*** Why dont you go shave your big stink head with your bad self ***
*** It sure does have some power ... but the tail sucks ***
*** Every time I crash a kitten dies......so many lost kittens
*** Dropping the F bomb as much as possible
kama1 is offline        Reply With Quote
