Go Back   HeliFreak > R/C Helicopter Support > JR Helicopters
JR Helicopters JR Vibe and Vigor Helicopters Discussion
Old 07-29-2011, 12:18 AM   #1
Phoenix Flyer
Default Gear Mesh on SG E12 Help
Hi Guys,
Ive done three flights with my SG E12 so far, and on the third flight stripped the main gear. The first two I just flew around got comfitable and dialed in the vbar. the third flight i started to do some hard 3d and the gear stripped.
How tight should the mesh be? piece of paper ok? and also should I run the gear in a few flights before doing hard 3d?
running a Kontronik set up with 65C packs, no shortage of power so im sure the gear needs to be set up perfectly.
Thanks in advance, any help will be awesome
Cheers
Phoenix Flyer is offline        Reply With Quote
Old 07-30-2011, 10:43 PM   #2
Bobcat_rt
Strange! I just stripped a main gear too. I had many flights on mine but it was very hot outside - 100+ degrees. I think I might have had the mesh too tight. I wasn't flying 3D but doing a hard pull up at the beginning of an FAI flight.
I've loosened the mesh slightly but haven't flown since.
I should mention - This is the original main gear - flew it for nearly two years. 1 year on Nitro, converted to electric over the winter and flew many more flights before it mysteriously just failed. Nearly smooth - no teeth left to speak of. Just a shallow line at the depression between where the gears used to be.
Bobcat_rt is offline        Reply With Quote
Old 07-31-2011, 12:28 PM   #3
Bodyshop
Guys. That sure is strange. I've been flying my native E12 since February. I strictly fly it contest style with about 10.5 degrees of pitch. Almost all vertical climbs are at full stick. Haven't' had mine strip yet. I run mine with the smallest amount of backlash possible.
Vibe E12, FBL Logo 500SE, Rave 450
Bodyshop is offline        Reply With Quote
Old 08-01-2011, 04:50 PM   #4
Phoenix Flyer
Hi guys,
I have fixed the problem, Im running a little bit of backlash and did some flights checking through them to see if the gear still had backlash when it was hot,
Ive done 20 packs with it now and going strong. I will post some vids soon
I am now testing the JR TAGS system so I will let you all know how I go with that
Hamish
OMP | RCBITS | JR Japan | Spektrum RC | Kontronik | Thunder Power RC | SG E12 FBL | SGNitro FBL| NEX E8 FBL
Old 08-05-2011, 03:21 AM   #5
Gorgin4325
Hi,
I apply a little grease on all the gears of my E12 (and recently on my nitro SGs) It reduces gear noise and possibly helps reduce heat caused by friction.
Regards,
G
"I'll be there when you fall" (Ground, 01/01/0001)
Gorgin4325 is offline        Reply With Quote
