Old 08-05-2011, 03:27 PM   #1
lcc014
Question What kind of oil used in building the 450 Pro ?
When looking through the 450 Pro manual, it mentioned that oil to be used in building the head - feathering shaft and damper. My kit did not come with any oil. What kind of oil should be using ?
Thanks,
Ching-Ho Cheng
Hirobo Quark - Aluminium rotor head and swashplate upgrade
T-Rex 450 Pro, zyx-s, T-Rex 250 SE, BeastX, DFC head, Warp 360, Scorpion 1360KV
lcc014 is online now        Reply With Quote
Old 08-05-2011, 03:45 PM   #2
froghammer
I think it's grease, isn't it? Lots of people use white lithium grease but really, any will do. I use a good bicycle grease for those spots as well as my thrust bearings Be careful not to get any on threads or into the ends of the feathering shaft or your threadlock won't work well (or worse, at all).
froghammer is offline        Reply With Quote
Old 08-05-2011, 03:48 PM   #3
lcc014
Got it. I will get the lithium grease.
Thanks,
Ching-Ho Cheng
Old 08-06-2011, 09:42 AM   #4
Finless
Team Taco VP
The kit should have come with a tube of clear looking silicon grease?
Align supplies that as other grease can effect rubber like the dampers.
Bob
"Don't Taco My Pack Dude!"
Old 08-06-2011, 11:20 AM   #5
lcc014
Bob
Bob,
My Pro kit did not come with any grease at all, only 2 small bottles of thread lockers (green and blue). That's why I asked.
BTW, I am thinking of getting Triflow synthetic grease - clear color and should be rubber/plastic safe.
Thanks,
Ching-Ho Cheng
Old 08-06-2011, 11:25 AM   #6
Ebartolome
Use Triflow or Rock n Roll.
I like Rock n Roll because it doesn't get sticky and messy. It's all about the bicycle grease and oils
Ebartolome is offline        Reply With Quote
Old 08-06-2011, 12:36 PM   #7
froghammer
If you get Triflow, I find that the little pen sized one is good. Since you're only using it a drop at a time it lasts quite a while and takes up very little space in your toolbox.
Old 08-06-2011, 09:08 PM   #8
lcc014
Yes, I have the pen size for lub. my FP helicopter's bearings. However, for the thrust bearing, I am going to use Triflow synthetic grease. Triflow website sells it for $10 per 3 oz tube. I got mine from local bicycle store for $$6.99. Synthetic grease is not supposed to harm the rubber too.
Thanks,
Ching-Ho Cheng
Old 08-06-2011, 10:23 PM   #9
mtuccio
I use Triflow oil (pen lubricator) and Scorpion oil on the bearings, Triflow grease on the trust bearings, and a silicone spray lubricant for belt deressing (if the machine has a belt drive).
mtuccio is online now        Reply With Quote
Old 08-07-2011, 01:43 AM   #10
isogloss3d
Thanks,
I feel your pain. As a newbie building my Sport super combo in January I had the same frustration (no grease in kit and what to use?) and the wording in my manual is "Oil" not grease. Just purchased a Pro kit and no "oil" or grease either.
I've been using white lithium grease this entire time which will hopefully has not done too much damage to my dampers.
Sigh....the little things that make a big difference, usually learned the hard way but not for lack of trying.
Compass Atom 6HV, Torq Servos, BeastX
TREX 450 Pro 6S, Scorpion 2010, C.C. ICE 50, MKS DS95, JR 3500G, BeastX.
TREX 250, ZYX FBL/ mcpx V1/ Nano cpx
DX 8
isogloss3d is offline        Reply With Quote
Old 08-07-2011, 05:54 AM   #11
lcc014
Thanks, I am feeling much better now. So many support from this forum.
Ching-Ho Cheng
