Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 08-05-2011, 03:51 PM   #1
Jonnyrl1
Default Slight tail drift 3g v3.0
Im getting a slight tail drift on my 550 with the latest 3g software installed. Tail is drifting right, nose left. Should I change my mechanical setup, or is there something I can dial in, in the software. Or last option should I just give it a few clicks of trim in the radio.
7HV kontronik pyro700-52, ar7200bx
Trex 600EFLPro-BeastX
Trex 600N
/trex450prov2/mcpx's/DX8
Jonnyrl1 is offline        Reply With Quote
Old 08-05-2011, 04:05 PM   #2
bad007
The 3.0 requires more gain, maybe even more rudder gain comp in the software. It doesn't hurt to check it in RM for a mechanical issue to make sure that's ok. go back to basics with the 3.0, drift more gain , wag lower gain
bad007 is online now        Reply With Quote
Old 08-05-2011, 04:41 PM   #3
Jonnyrl1
OK thanks, Ill start by tweaking the gain a little tomorrow. And take it from there, I did bump my gain a few clicks when I DL'ed the v 3.0, maybe just not enough.
Trex 600N
Old 08-05-2011, 07:06 PM   #4
Wolfpackin
Good HH gyros or FBL systems should never need to be trimmed to hold the tail.
I agree, you probably need to increase gain or maybe even tail authority if you're running a low headspeed.
Jonathan Livingston Helicopter
Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.)
CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG.
T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades.
Wolfpackin is offline        Reply With Quote
Old 08-06-2011, 06:36 AM   #5
Jonnyrl1
Its not my headspeed, only fly in idle 2 with 100% flat throttle. Im going to try to get out to the field today, but the weather may not cooperate with me. Ill keep you guys updated, Thanks
Trex 600N
Old 08-06-2011, 11:50 AM   #6
bad007
I had to up the rudder gain comp to 80 and lower the lock to 50 on mine and that get the TX gain up to 30 using endpoints
