Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite)
Blade Helicopters (eFlite) Blade Helicopters (eFlite) CP, CX, mCX CX II, CX III. and others
Old 04-06-2007, 05:34 PM   #1
DavZee
Default Blinking 3 in 1
Hello, I just replaced the 3 in 1 on my BCPP. Now when I connect the battery with the transmitter already on I get blinking red and green lights. I've checked all the usual stuff like throttle hold switch and making sure the throttle stick is down and trim down. The servos all move when I move the sticks but there is no motor control to the main or tail. Any ideas on whats going on?
Thanks.
DavZee is offline        Reply With Quote
Old 04-06-2007, 05:51 PM   #2
slikrx
I'd check to make sure the connections betaween the 3 in 1 & the receiver are good. Sounds like it itsn't seeing the transmitter.
Jeff MacDonald
SoCal
Blade CPP - mostly stock + G90
300 size frankenchopper
slikrx is offline        Reply With Quote
Old 04-06-2007, 07:26 PM   #3
Gino CP
Or reseat your crystals.
Gino CP is offline        Reply With Quote
Old 04-06-2007, 09:14 PM   #4
DavZee
the weird thing is the 3 in 1 is blinking and I have control of all the servo's but no throttle. Thats the only function thats not working. The main and tail motor don't spin up.
Trex 600N Super Pro, 9452's, G770/DS8900G, AR7000
Trex 450S,HS46HB,401/9650,AR7000,430X
CX2 on 11.1V,3s,1000mA, Extreme 180 BB motors
Blade CP Pro
Maule MXT-7-180A
Happy hour has come and gone, much to short and much too long.
Old 04-07-2007, 12:00 AM   #5
Gino CP
That means, rx is seeing the tx. Disconnect your motors and servos and see if it arms. If it does, reconnect one by one until problem comes back.
Old 04-24-2007, 01:18 PM   #6
suzukiman650
My CX2 did the same thing excep I had no servos either. The light would come on red and then start flashing red-green. My issue was a faulty bettery. I think the red-green flash means a low voltage threshold has been exceeded.
CoryB
suzukiman650 is offline        Reply With Quote
Old 04-24-2007, 05:19 PM   #7
txflyer
i had the same problem. took it to my heli guy there he looked it over. then just swapped it for a new one.
trex 450 sa 70% converted to se
401
9650
3x65mg
eflite 40amp dual bec esc
ar6000
430l
txflyer is offline        Reply With Quote
Old 05-21-2012, 06:22 AM   #8
spython
I'm having this exact problem.. any update on the solution?
spython is offline        Reply With Quote
