| Newbies: Tips and Information Section of HF, specifically for Passing along info to newcomers to the hobby. Setup, tweaking, orientation practice, etc. |
Motor speed - Pinion - Main gear
Quick and dirty video but from gasser tuning video. But easy to understand
Dan Da Dawg - JR X9303 Hexa F550 on 3S + 6S TREX 500 + 6S TREX 600 + Blade mSR + Blade mCPx2 Brushless + 12S Rave FBL ENV |
Thank you DebianDog,
I like! Simple and to the point. It would seem that using the same formula would be good for calculating headspeed on electric helis as well. |
Your Video for calculating head speed is very helpful. Its really very easy to understand. Thanks!
I found that there is a HeadSpeed calculator from Scorpion, can make a try.
http://www.scorpionsystem.com/news/headspeedcalc/ |
Nice tip..
#6 |
Excellent. Thank you
#7 |
This is great.Thank you!! I am all new to this, so forgive me if this is obvious...
So how do we determine motor speed? It woud seem to me we would start with that number, and solve for the correct pinion gear to get the head speed we are targerting? No? |
#8 |
#9 |
Thanks for your sharing!
It`s useful for us. |
#10 |
thans a lot mate!!!!!!!!!!!!!
#11 |
merci pour l'info
#12 |
How do I know what rpm should I have on my heli?
I'm having a Falcon 3D electric heli with wood blades. In the heli instructions there is nothing written about this. |
#13 |
how do you know what the engine rpm is
#14 |
yes, thank you.
#15 |
Very useful, thanks.
#16 |
Found this interesting:
#17 |
Very good, but complicated, I used it (among others) to doublecheck the results of HeliPort, which is free and does a lot more than only calculating headspeed.
www.helisoftware.com for all of you freaks ![]()
TDR - Logo 600SE + 500SE + 400 - Furion 450 6S mini-V - 300X - 2 x mCPX - Schluter Bell Huey Cobra '74 - Aura 4 hotliner FAI world record longest electric RC heli flight: 1h 46m 22s |
#18 |
i have a question. when i was doing my gp780 gyro setup, in heading hold mode i would turn the rudder stick to the left or to the right and let go of the stick and the rudder does not come back to center. is that normal? i also grab the heli and turn it left and right and the gyro does move the servo. but when i put the gyro in rate mode and i move the rudder stick and let go of the stick, the rudder does come back to center by it self. im new at this so your help would b nice.
#19 |
yes...what you are experiencing is normal behavior by gyro.
what you need to make sure is that the correction it is doing, is in the correct direction. |
#20 |
very helpful!
thank you |
