Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 08-10-2011, 12:13 AM   #1
RichMaty2010
Question Anyone Try the Gens Ace 5300 30C batts in the TDR?
Does anyone know if these batts will fit. They say 63.2 mm high. But the TDR website says 60mm x 60mm packs. Does anyone have an actual measurement for the area that the packs fit into? I have a TDR on order and have been thinking about diff options for batts.
Any help is appreciated.
Blade mCPX Hoped Up / DX8
Phoenix v3.0s
RichMaty2010 is offline        Reply With Quote
Old 08-10-2011, 02:08 AM   #2
shaman3
Hi,
the battery tray dimensions are exactly as specified by Jan, so these batts won't fit
Cheers, Daniel
shaman3 is offline        Reply With Quote
Old 08-10-2011, 02:09 AM   #3
RichMaty2010
Thanks, Just checking
Phoenix v3.0s
Old 08-23-2011, 01:59 PM   #4
esmoglo
What packs fit well in the TDR? My del date Sept is around the corner...
Angelo
esmoglo is offline        Reply With Quote
Old 08-23-2011, 02:06 PM   #5
jointer
Unfortunatelly Gens Ace 5300mAh are really too big.
The biggest capacity (which fit) i was able to find is Billowy 50C 5200mAh, 780-790 grams.
I have some on the way and one other member here ordered them too.
Every LiPo i seen was swelled over time, so i recommend max 56mm width.
One of my Hyperion packs have a problem to fit already (300 cycles on it).
- TDR #2, Hacker Turnado, YGE 160HV, MKS HBL950/980 (JR MP82S=crap), HV2BEC mini (Quasar died), Vbar NEO, 16S Revolectrix 3200mAh, Radix V2, EDGE 105mm, Jeti DS14
- TDR #1 sold (standard setup, 700+ flights)
- HPI e-Firestorm FLUX + DX3S
jointer is offline        Reply With Quote
Old 08-23-2011, 04:12 PM   #6
jstarks
A friend of mine is trying out a set of Maxxamp packs in a L600SE. Only a few cycles but so far so good.
They are pricey but seem to have a good warranty and for the c rating and mah, they are pretty light in weight.
http://www.maxamps.com/Lipo-5450-222-Pack.htm
Definitely thinking of trying a set, when my TDR comes!
J.
700LE Vbar-YS91SR, SB-19 / 700LE Beastx-OS91HZ non-pumped, SB-20 / Henseleit TDR-Vbar, Jive 120/Pyro 700-52, 8917/9188 / Logo 600 SE-Vbar, 12s, 4035-3Y, Jive 120HV / Logo 600 3D-Vbar, 12s, 4030-3Y, Jive 80HV / Compass 3D+-Beastx, YS56, Outrage H56
jstarks is offline        Reply With Quote
Old 08-24-2011, 01:53 AM   #7
spdntckt
I am using Thunder Power 65c 5000 6s packs in mine.. they fit nicely and provide excellent performance. I have some of the 45c packs from last year with >100 cycles and they still perform like new...
spdntckt is offline        Reply With Quote
Old 11-09-2011, 08:12 AM   #8
jyheli
Default not sure if this is still useful
Just saw this email...the Gen Ace 5300mah does fit into the TDR.
ID:	265715   Click image for larger version
DX18 ; Forza 450 , Energic Slope/E glider , Snipe DLG
jyheli is offline        Reply With Quote
Old 11-10-2011, 05:12 PM   #9
Z900
Wow ...how could that be possible ?!?!?!
| mCPX BL@DX6i | Trex700N-LE@BX | TDR@BX || FunJet 2W20@4S | SwiffieII || FF10 || 720i DUO3 | ALC8500
Z900 is offline        Reply With Quote
Old 11-11-2011, 02:44 AM   #10
jointer
Did you used some spacers to make the frame wider or the dimensions of the packs are not correct?
Old 11-11-2011, 04:35 AM   #11
clayboy
I think there is a few mm space. Not enough for me who fly when it is 33+ Celsius
When they puff a bit
clayboy is offline        Reply With Quote
Old 11-14-2011, 03:31 PM   #12
heliaddict2424
My experience with Gens Ace packs the are never the same size I have 4 6s 3800 for my Logo 600 they are all different sizes some by 1/8 of an inch. I know it make no sense but true and my 5300 do not fit in my TDR I have tried.
Team MikadoUSA Team Scorpion
Logo 800,700,600,400,Diabolo,TDR,NX4,UVR
heliaddict2424 is offline        Reply With Quote
