Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCP X Brushless Mods
mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions
Old 08-11-2011, 08:10 AM   #1
utrinque
Default BL hiccup - problem SOLVED
I have startedto experience a hiccuo of my BL motor.
My setup:
- ADH50 11500kv 1mm shaft
- stock 8 teeth pinion (I removed it from brushed motor)
- EA-048 Xtreme Production Brushed to Brushless Signal Converter
- Walkera CB100 regulator HM-4#3B-Z-34 (WK-WST-10A-L) - unfortunatelly this one is not programable.
After dozens of flights, most often in full throttle, engine breaks periodically.
I do not blame motor because I tried two of them.
Should I blame regulator timing or EA-048 signal converter?
I have ordered programable regulator form China... but you know, it is difficult to be patient.
I put brushed motor in mCP X. I was surprised how WEAK it is. After I got use to BL there is no way back. I became power hungry
SOLUTION:
I do not have another regulator yet so I decided to use another signal converter. I do not blame converter. Probably soldering was not perfect. Now it flies very well.
utrinque is offline        Reply With Quote
Old 08-11-2011, 08:21 AM   #2
tntburnett
Blade Forum Support
My setup:
I had the same issue I found that my main board positive wire was loose. So I gave a very lite pull and the wire came right off of the board. So I resolder it and she is good as new :-).
Have a blessed week
Isaac
Sent from my DROIDX
Jesus Rep Its all Good,Its all GOD
FPV Everything Now
GOD BLESS
tntburnett is offline        Reply With Quote
Old 08-11-2011, 11:21 AM   #3
utrinque
Have a blessed week
Isaac
Thank you. Your solution also worked for me. Probably due to vibrations some points can require resoldering from time to time.
